Question about HP Compaq Presario v3000z Notebook
Boot Up issue in Laptop
I have a COMPAQ PRESARIO V3000 Laptop.
When i start my computer the windows logo and eveyrhing load normal as it is supposed to load. Before the desktop load i get a blank yellow page. This yellow page stays and I am Unable to do anything after that. How do i fix this issue.
I pressed F8 when in boot up process and i have tried with restore factory defaults, System restore and all the options its giving me. Nothing fixed the issue.
I have removed all the hardware devices connected to the laptop. Still nothing...........
Please give me a solution.
  • 37 Answers
Try booting in safe mode (Tap the F8 key on startup until the menu loads). Let me know what happens.
Posted on Feb 23, 2008
I cant connect to my home wireless broadband after i format my laptop, how can i down load network driver for COMPAQ PRESARIO V3000 notebook.
You can download the LAN and device drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the Windows drivers you require and install them. Click on this link to download the drivers: -
www.compaq.com/country/cpq_support.html
Feb 11, 2013 | HP Compaq for Presario V3000 Motherboard
Compaq presario has fedora needs to get back to windows 7
What you need to do is put in the first restore disc. Turn off the PC. Then when you start you will see the compaq logo there should be an option to boot to boot order. Usually F12. If not there should be an option to go to BIOS. F2. You need to boot to disc first. Once you boot to disc follow the instructions to reinstall Windows.
Jan 19, 2013 | Compaq Presario CQ56-115DX Laptop
I have celeoron M presario v3000 compaq laptop .Is windows 7 is compatible for that>
veena:
I just checked the HP-Compaq web site for Windows 7 drivers (click here for the site), and they do not provide Windows 7 drivers.
There are Windows Vista drivers that may work with Windows 7, but it will be hit or miss.
Thanks for using FixYa.
Feb 16, 2011 | HP 417065-001 - HP Compaq Presario V3000...
Compaq Presario being stuck on Windows XP logo, attempting to repair Windows XP, but gets stuck on setup is starting windows, attempted hard drive self test, but self test failed, attempted F11 at the...
I would be willing to bet that your hard drive has gone out.This frozen screen usually means hard drive is bad at the boot sector.Take your hard drive to certified repair shop for testing.
Apr 29, 2010 | Compaq Presario M2000 Notebook
I have a compaq presario v3000 i remove the vista now xp is running on my laptop but drivers are not working after change the os.
The model "V3000" is a generic term for a bunch of different models. To make sure you get the right drivers for your specific model, start at HP's site here and pick yours from the list. Then pick the Windows XP operating system and you'll find the drivers they have for download.
Mar 08, 2010 | Compaq Presario R3000 Notebook
Reformat
(A) Try interrupting the boot sequence and telling the computer to boot using the last known good configuration. Here's how: 1) Turn the computer on, and press F8 repeatedly until the boot options menu appears (the menu items include "Start Windows Normally," "Use Last Known Good Configuration," etc.). Use the arrow keys to select "Last Known Good Configuration" and press ENTER. The computer should boot correctly.
if it dont this is the procedure given below to format the whole operating sys 1) Put the CD in the CD drive and turn the computer on. 2) As the computer begins to turn on, you should see the message "Press __ to enter setup" (it's usually F1, F2, or F4 - models vary). Press that key.
3) You should then see the Setup screen for the BIOS ("Built-In Operating System") - using the arrows, find the "boot disk priority" settings and select your CD Drive as the first priority.
4) Exit setup, saving changes (usually by pressing F10). The computer should then boot normally using the CD.
Jun 18, 2009 | HP Compaq Presario v3000z Notebook
Hp compaq presario v3000 is not loding the OS, show an error
  • as you boot the computer, start tapping the F8 keys
  • From the boot menu, select Safe Mode
If this seems to work, you can try restoring the computer to an earlier point from Start > All Programs > Accessories > System Tools > System Restore.
If Safe Mode also fails to load, you would have to check your disk for errors or you may have to install XP all over again.
Please get back, if you need any further help.
Jan 09, 2009 | HP Compaq Presario SR1920NX PC Desktop
Not opening my laptop
Here's what you need to do to fix it: Find some way to get Partition Table Doctor (http://www.ptdd.com/download.htm) and put it on either a live boot CD or from a secondary hard drive installation. Once you have that, Scan the partition for errors and select fix boot... Then if you're running Vista get a copy of Vista Recovery Disc (http://blogs.techrepublic.com.com/window... burn yourself a copy of the disc, and run it at the boot of your computer. Once the cd is loaded, click on REPAIR WINDOWS, select COMMAND PROMPT, then use this command: bootrec.exe /fixboot
If that doesn't work use: bootrec.exe /rebuildbcd
and see if your windows boots.
IF you have windows XP, boot up with the Windows XP cd, select Repair (R), go into the command prompt (selecting which windows installation you want to modify) and then type this command: fixboot c:
See if your computer boots now.... The important thing is to try to repair your boot which has been deleted or corrupted, that is why it gives the error: err2err3
Try different recovery tools like Table Doctor http://www.ptdd.com/ in conjunction with your recovery cds (windows xp installation CD and Windows Vista Recovery Disc)
Jul 17, 2008 | HP Compaq Presario v3000z Notebook
HP Compaq Presario v3000z Notebook Logo
119 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
