Computer boot disk problem
Acer aspire SA60/acer power s260.
System has gone down and wants to reboot using system disk.Once this is done a blank screen with a flashing cursor appears and then nothing ???
Can anyone help me please.
  • Hank90403 Apr 09, 2008
    I have a six years old Dell Dimension 4550 PC Desktop with Win XP Home Edition Service Pack 2, and my PC has just got a booting problem.
    When I push the power button I see the DELL logo followed by Win XP logo for five seconds as normal, then I see a blank dark screen with blinking cursor.
    After ten seconds PC attempts to boot itself again, and this behaviour keeps happening again and again as an endless cycle.
    Customer help line was useless after two hours on the phone and advice me to take the PC to a local computer shop !
    Trying to boot it on the Safe Mode did not solved the problem.
    Any ideas or suggestions will be appreciated...
    Hank (from Santa Monica)
    Sergeant:
    Champion:
  • 322 Answers
Yes try f11 when you boot your machine if not then you need a xp disk to install your start up but if new the system is all ready in your computer just tap f11 as you reboot pc
Posted on Feb 23, 2008
My aser aspire say the oprating system not found but the hard disk has the oprating system and ot works properly what can i do to fix this and how can i enter in bios mode
Shut down your Acer Aspire if it is running. Once the computer is off, press the power button to start it. Press "F2" immediately while your computer is booting up and displaying the "Acer" logo. Keep pressing "F2" until the BIOS Setup screen appears.
Aug 16, 2016 | Aspire Computers & Internet
Acer aspire PC model M3470G with error msg:can't find reboot disk or it is damaged
check bios at boot for any 'hard disk detection' options to see if the drive is actually getting power and being recognized by the system. If it is, it may likely be the boot record, which will require a reload or restore.
Jan 10, 2014 | Acer Computers & Internet
Acer aspire boot
Try starting in safe mode to see where the issue is.
Apr 13, 2017 | Acer Aspire Computers & Internet
Why is my laptop is stuck in start up mode
Hi bungee221,
You can try to boot the system using Safe Mode and try to see it it will be able to boot so that you will be able to backup your file. In addition to that you disable other programs that might be causing the system not to boot up. Go to Safe Mode by reseting the computer then tapping F8. If your able to acces safe mode follow these instructions:
1. Go to Start then click on RUN.
2. Type MSCONFIG.
3. Go to Services Tab, click Hide Microsoft Services then click Disable All.
4. Reboot the computer and see it it will go to normal mode. It you will be able to boot to normal mode it only means that one of the installed software is preventing windows to load.
5. if still cant boot you neet to reformat the system. Take note that if you reformat the system all the files will be deleted so its better to back up the files first. You can use a Recovery Disk that came with the system or you do a Acer Disk Recovery.
Acer Dsik Recovery Steps:
1. Power on the Machine
2. At the white ACER BIOS screen, hold the Alt key and press the F10 key simultaneously to start Acer eRecovery
3. Once eRecovery has loaded, click Restore to Factory Default Settings
4. Click OK to continue
5. From here, the eRecovery process will update all the data on the C: drive and restore a fully functional factory image (approximately 10 minutes).
6. Once eRecovery has run, press OK to reboot unit.
If you think this helpful rate me and dont forget to say thanks. Thanks for using Fixya.
Feb 05, 2011 | Acer Aspire 5920-6335 Laptop
Hey there! Can anybody help me about my acer aspire 8920g media console is does not work, it will response by touch, showing lights on etc. Play button, volume, nothing does not work. I have try reboot...
I think I have managed to solve this problem
POWER ON THE LAPTOP
whilst its booting up, you can use the FOLLOWING KEYS TO see picture on the screen:
FN + F6
Whilst its booting, also HIT F2, once your in the bios
Go to:
EXIT > LOAD SETUP DEFAULTS
EXIT SAVING CHANGES > SELECT YES
It should then reboot and ... now its working...SO FAR.
After doing this, the screen stays on, operating system loads up fine.
And I have done approx 10 restarts and also approx 5 power downs and then power on.
Hope this helps
Sep 24, 2010 | Acer Aspire 6920 Notebook PC
Acer not booting properly.
I would suggest you start the computer with a Windows disk and (depending on your operating system), run a scandisk.
You have some corrupt files that need to be fixed.
Once you have done that, you will be able to restart the system.
Dec 23, 2009 | Acer Aspire 6920 Notebook PC
Acer computer is frozen on screen which reads press f12 or del to enter setup. when computer comes on it does not beep so i cannot use keyboard all the lights on the keyboard aare off. HELP!!
From the description you are giving, it appears that the system is not detecting a bootable hard disk drive. Hold the power button on the system till it powers off. once system is off, try the following:
  1. Ensure no floppy diskette is in the A: if system has a floppy drive
  2. Disconnect all external items (Printer, scanner, network connection) leave only video and keyboard connected to system.
  3. Try powering system on again
If the system gives the same message, try rebooting and pressing F12 ONCE at the ACER screen and see if you can get a 1 time boot menu. If you can get the boot menu, select CD-ROM, and put you WINDOWS CD in the optical drive, see if system will boot to the CD. If you can, then at the first prompt, press R to enter recovery console, and see if you can run the command CHKDSK /R (then press enter)
If chkdsk runs, then reboot and see if the error has gone away. IF you cannot run CHKDSK then the hard disk drive has likely failed and will need replacement.
Nov 01, 2009 | Computers & Internet
Acer laptop stuck on Aspire screen
i/run operatin disk take prompt comman and type chkdsk/rr 2-3 times it can be repair your system 2/ repair by operating disk if not work by two methode reinstal operating system.
Oct 14, 2009 | Acer Aspire 5500 5570-2609 Laptop
Shuts self off during start up
Sounds like there could be a major problem with the hard drive.
Have you got an XP or Vista cd? NOT a restore cd.
Mar 10, 2009 | Acer Aspire 5610-4648 Notebook
Tried rebooting from the disks, but...
I had this problem with my Acer Aspire 5920. What I had to do was use GPLCD which is a linux utilty to format the disk as NTFS. It is available here. http://gparted-livecd.tuxfamily.org/
For me it was easy as I have another computer here. I downloaded the iso file and created a CD which is bootable.
I put it in the drive for the laptop when the computer was on, turned it off and then powered on. The cd loaded GPLCD and I selected the format disk option. NTFS was what I used.
I then put in my ACER recovery CD for the Acer Aspire 5920. All worked ok from this point onwards.
Hope this helps.
cheers
Robert
http://www.robkeating.com
Jun 22, 2008 | Acer Aspire 4520-5582 Notebook
Computers & Internet Logo
125 people viewed this question
David Payne
David Payne
