posted by Gibber on Feb 23, 2008
My Bissell Pro Heat 7901 will not put out any spray. I Took the pump out so I could get at it and disconnected the hoses. I put the one on the input side and the other in a bottle of water. Put the belt on the pump and turned on the machine .Nothing at all coming out of the pump. Where can I get a new pump? Also the lever that goes to the little flapper at the top under the clear plastic piece on the front that connects to the knob that changes from tools to floor broke off. Where can I get one of those? Thanks Gary
Comment by Gibber, posted on Mar 05, 2008
THANKS EVERYONE
2 Other Users Have The Same Problem
Comment by Guest, posted on Jun 06, 2008
I have the very same issue. Has anyone found a solution? I cleaned it and I'm not sure where to go from here.
Comment by Guest, posted on Jun 03, 2008
Same thing no spray. Replaced the pump and checked all lines, cleaned unit....
Best Solution
posted on Mar 03, 2008
You can to bissell.com and order them thru them, or they can tell you where the nearest place is for parts by putting in your zip code.
Rating Locked! (?) Gibber has rated this solution as FixYa!
Suggest a new solution for this problem
Post a New problem for Bissell 7901-1 ProHeat Scotchgard
Email this problem
Email this problem
Can you Help with these Vacuums problems?
Bissell 7901-1 ProHeat Scotchgard Upright...
Lost part that holds shampooer....
Source for part that holds... Answer This...
Repair Service
Find Vacuum Repairman Near You:
