Question about E-Machines eMachines Desktop PC
Shut down model T2792 When I shut down my computer the power supply fan continues to run and the yellow light on the front stays on.Everything else seems to be working fine, I'm using it now.
  • MrButch Feb 24, 2008
    I double checked. I,m not going into standb-by mode. I saw where someone else had this problem and was told the operating system was corrupt and needed to reboot . Is this possible ?
  • 37 Answers
Check to make sure you're not going into Stand-By mode. Click on the Start Menu....Shut Down and make sure you're not clicking on Standby.
Posted on Feb 23, 2008
My pc is shutting down and I can't wake it up without shutting down the power from power supply. The Antec 300 tower has two blue lights- the top light starts blinking when it has shut down and I
sounds like a power supply problem
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive power and data cables IDE SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
hope this helps
Oct 13, 2012 | Antec Computers & Internet
Does this refrigerator go through a shut down cycle where the light and everything go off?
Most do not... the compressor will shut down, but the fans will stay running...
since you did not list a make and model I cannot say about yours for sure...
heatman101
Jul 28, 2011 | Refrigerators
When I turn on my computer it runs for a couple of seconds and then stops.
Unplug everything inside the computer, except the motherboard and the front panel power on switch. Power up the computer. If the PS fan continues to run, (power supply doesn't shut down)and the CPU fan runs, then power off the unit and reinstall each device, one at a time, turn the power supply on after each device is installed (and off, before installing the next device).
You can not easily start the power supply if it is not connected to the cpu motherboard.
If the power supply shuts down with only the motherboard attached, then you will need either another power supply, to test the MB, or another MB to test the power supply.
R
Feb 02, 2011 | Acer DPS-420GB (dps420gb) Power Supply
Fan works randomly....when it's not working plug
Hi, If the computer is hot near the electrical plug in the back of the computer then the power supply needs to be replaced. This will also cause overheating problems if the fan does not exhaust enough air. You should not run the computer in this condition because the power supply can short out and take other components with it. Also there is a risk that it will burn up. Power supplies are very inexpensive and can be changed by anyone with basic computer repair knowledge. Hank
Jul 26, 2010 | eMachines T5212 PC Desktop
My XPS 200 keeps shutting down and power light blinks
During when does your computer shutdown? Please check the diagnostic lights at the back as well which ones have light on it during the time it would shutdown.
Since you said that the light is blinking yellow it just says that your power supply is running outside its normal operating range. So most likely you would need a change of power supply. Maybe a higher wattage would be better.
Apr 28, 2010 | Dell XPS 200 PC Desktop
Temp fault
check all the internal fans, if even one does not start, the projector will soon shut down!
every fan has three wires, one is the stop signal, that should stay "low" in most models.
this wire might be white or yellow, the red is + supply/blue or black is -supply(or gnd).
Sep 17, 2008 | Office Equipment & Supplies
Processor?
The power box is going bad. It's a matter of time before it will not turn back on. you will see. i would get a new one from ebay and replace it.
Apr 04, 2008 | E-Machines eMachines Desktop PC
Power of
This happens because your CPU is overheating, open your PC and blow any dust off the openings and CPU/Power supply fans, if you think one of the fans is not working... replace it.
Jan 24, 2008 | Computers & Internet
Hard drive light stays on and system freezes
You may have a hardware problem of some sort. The first place I'd start is to check the power supply voltages. If one or more voltages is off tolerance, this will cause all sorts of symptoms. if you have a voltmeter check especially the +5, +3.3, +12, & +5 standby voltages. Use this site as a reference http://pinouts.ru/Power/atx_v2_pinout.shtml If the supply checks out faulty, buy a replacement, or, if tech savvy, you might repair it-- probable component defects= one or more electrolytic capacitors. Other possible problems are Memory errors (try subbing a RAM stick), hard drive developing errors, or a bad chip on the motherboard. If you have some spare parts, RAM, hard disk, you can try subbing parts and narrow down the problem.
Apr 27, 2007 | E-Machines T2792 PC Desktop
E-Machines eMachines Desktop PC Logo
138 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
