Question about NEC LT 260K Multimedia Projector
NEC LT260 Projector - Picture is dim - Not the lamp
My picture is dim. When taking the unit apart I noticed the wheel to have almost like a smoke film over it. I didn't touch it because I am afraid of ruining it. I looked online and could find no answers. I also haven't found parts for the unit. Can I clean it? Can you get new wheels? How hard are they to replace?
  • 983 Answers
You can clean the film with dry cloth ..... but you must not expose it to light ....
and about the picture check & adjust in the settings the brightness,contrast,etc correctly ....
if previously the picture clarity was very good then i think the lens must have became weak ...
just visit the technician and get cleaned the lens of it ...
if you can do it yourself then you must clean the lens with the spirit or white petrol then reassemble it ...
if you are afraid or if you dont have any idea means then just visit technician and get cleaned the lens,any way it doesnt charge much
Posted on Feb 23, 2008
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Feb 23, 2008
    this will solve your problem for sure.......
    thank you
  • 40 Answers
If You try to fix the wheel by cleaning it that will make it even worse. It is not hard to replace. Yes you can get new wheels at best buy and if not there radioshack might have them. I prefer best buy due to them having cheaper prices on them. If you have any more problems please let me know.
  • 689 Answers
Yes you may clean it, you don't have to replace the parts first
  • ExpressFiX
    ExpressFiX Feb 23, 2008
    please don't touch the image diaphragm as its sensitive. Use dry cotton fabric to clean. I also suggest you to perform full reset so settings will back to default
  • andre_lau Dec 15, 2010
    We have 2 NEC LT260T Projectors, and neither of them will display anything! Usually, a blue screen is projected, but were not even getting the blue screen, or any light whatsoever. We turn on the power, the power light stays lit green, but the status light (green) blinks a few times, then the power light goes orange, and the status light blinks red. What's the problem with our units?
I have an nec mt850, my picture is upside down...how do i fix that?
Unit is probably set for ceiling mount or reverse screen projection. In the options menu there will be settings to alter it back to normal aspect.
Apr 28, 2012 | NEC MT850, MT1050, MT1055, MT1056...
I have three NEC LT 245 projetors, one of them is dim compared to the others even though all setting are the same. How can I correct this?
check the lamp of the projector. around the filament of the lamp, you might notice dark corrosion building around it. this what normally cause dim image.
May 18, 2011 | NEC LT245 Multimedia Projector
Sometimes the NP50 lamp will come on, sometimes it won't. Sometimes it seems like the color out-put isn't sharp or correct, like a faded picture. It's like something is wrong with the color. So it seems...
projectors really don't like hot and humid. they love cool and dry. if the colorwheel is failing, the lamp wouldn't come on. humidity+dust+intense lamp heat=coated components. such as the colorwheel glass, which is clear and coloered. fried dust will cause dimness. you'd have to send it in to nec.
Aug 20, 2009 | NEC NP50 Projector
Red coured picture Nec MT850
I don't think it's globe related, I'd be getting a quote on the electronics.
Mar 23, 2009 | NEC MT850, MT1050, MT1055, MT1056...
NEC LT260's shutting down
I think I have solved this issue with my LT260K. I too had shut downs after 5 minutes of operation. It roughly followed a replacement of the bulb. I repaired stereos in the 70's and 80's, so I was not going to let the projector get the best of me without a tear down. I cleaned the fan blades, checked their operation. I checked the continuity of the thermostat on top of the bulb bracket, but found no apparent failures. I did find a possible loose connector in the middle of the projector as it seemed loose as I was disassembling the unit (see 1st picture). 7c58d4f.jpgThen I checked for cracked or burned areas on the PCB's. During this I scanned as much of the solder joints as I could. In the 'old' days, the power supply area could get hot and make cold solder joints. I found what appeared to be heat damaged solder joints on the auxiliary power board (Lamp power). This is the one that is back right of the projector opposite the power switch. It is a vertical board that solders into the horizontal bulb power board. I resoldered these and I am up and running. USE CAUTION, I would leave this to a trained professional to repair. This requires major disassembly.18d84c8.jpg
Oct 30, 2008 | NEC LT 260K Multimedia Projector
Security code for nec lt 260
The procedure is the same for LT220, LT240 and LT260.
Here is the user manual
LT260/LT240/LT220 User’s Manual
Sep 09, 2008 | NEC LT 260K Multimedia Projector
Dim pisture lt2200 projector
If the picture is dim with no distortion then replace the lamp.Usually when the lamp is used for around 2 years it starts to have dim picture before it stops working or breaks inside.
Jul 19, 2008 | NEC Televison & Video
Nec lt260
Clean optocoupler under pcb 4554B on color disc wheel.
Dusty on this part make not good sincronice with dlp panel.Good luck.
Jun 28, 2008 | NEC LT 260K Multimedia Projector
Nec picture turns megenta
I'm gonna take an educated guess and say this is a DLP projector. Sounds like the DLP wheel is slowing down causing blurriness and Magenta when the wheel stops. It probably needs a new color wheel. Call NEC and see if they have a bulletin or notice on this issue. If you're lucky, you might get a free new color wheel or replacement projector from them.
Jun 12, 2008 | NEC HT1100 Multimedia Projector
Nec LT 240K projector
In general you have to take off the lens and take it to a specialist who repairs gun scopes or binoculars. Me my self would not disassemble a lens unless I was perpaired to replace when it feel apart after removing screws Try calling them at 1-800-338-9549 or contacting www.infocus.com as they sell lens and projectors. Good Luck
Apr 28, 2006 | NEC LT 240K Multimedia Projector
NEC LT 260K Multimedia Projector Logo
442 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
