Question about Texas Instruments TI-5006 II Calculator
Calculator The display on my calculator is only working pasrtially. Numbers in the display are not complete. Can this be repaired?
  • 682 Answers
Yes it can be repair but better in service center because it needs special skill in soldering and in electronic troubleshooting.
Posted on Mar 11, 2008
Screen does not display complete numbers
Half of the display is only working, the problem is in the driver ic that drives the display, it is simply not cost effective to repair the item, further ahead to replace the calculator.
Mar 06, 2012 | Texas Instruments TI-30X-IISTK Scientific...
I want to enter in numbers for L1 and L2, but when I go the TABLE there is no L1 or L2 column, only X, and there are numbers entered in the X column that I want to delete. How do I clear the X values,...
The table is where the calculator displays values from functions entered in the Y= page. To enter numbers into lists, press STAT and select Edit to get into the list editor.
Dec 21, 2010 | Texas Instruments TI-84 Plus Calculator
I am trying to use this calculator to do Organic chemistry and general chemistry problems which involve very large numbers and very small numbers or various numbers to both negative and positive...
Make sure you use the (-) key in the left column above the RCL key to enter negative exponents, not the - key which subtracts.
Do get all results in decimal instead of fraction notation, press SHIFT [SETUP] 2 to select LineIO mode.
Sep 12, 2010 | Casio FX-115ES Scientific Calculator
Please help me to use my TI - 84 so I can get a radical number when working with larger numbers. the steps I must take and having the TI - 84 set to the right function
I am afraid I do not completely understand what you want. This calculator does not have a Computer Algebra System or CAS. So the results of all calculations will be displayed as decimal numbers, and that includes the square and other roots that are irrational numbers (square root of 2, 3, 5 7, etc.)
You cannot manipulate radicals on this calculator, whether for small numbers or large numbers. Sorry.
Sep 09, 2010 | Texas Instruments TI-84 Plus Silver...
HP12c showed expected display for low battery (star in lower left), put new batteries in and could not get any display at all. Took betteries out of mine (working great!) and now the one not working shows...
Resetting the calculator using the keyboardThe easiest reset is done from the keyboard. To reset the calculator, follow the procedures below in the order presented.
  1. Press ON to turn off the calculator.
  2. Press and hold [ - ] .
  3. Press and release ON .
  4. Release [ - ] .
  5. The screen will display “Pr Error
  6. The calculator will reset to the default settings, and the memory will be erased.
Aug 04, 2010 | HP 12c Calculator
The screen does not display the numbers correctly or completely. I think it's because I haven't used it for a long time so now the screen has many "dead" spots. Can this be repaired?
yes this problem is when you dont use for a long time
you can try to give contrast all the way up and keep it for 15 minuts
sometimes it help
Hope it will help
Mar 31, 2010 | HP 10bII Calculator
I want to complete normal calculations. the default says it is set at D for angles in degrees or something I just want to balance my check book and everytime I put in the calculations I get a fraction for...
OK,do not worry. Press [2nd][MODE] to access tghe (SETUP) options. Then press 2 to select [2:LineIO]. from now on all your results will be displayed as decimal numbers. Do not pay attention to the D for degrees, if you are not doing angle calculations or trigonometry.
Another point. Since you only want to balance the checkbook, all your numbers have at most 2 decimal digits and it might be less tiresome for you if you configure your calculator to display just 2 figures after the decimal mark.
To do that
  1. Press [2nd][MODE].
  2. Enter 6 to select [6:FIX].
  3. Then enter 2.
Feb 18, 2010 | Casio FX-115ES Scientific Calculator
My 12c fin calculator will not come on even with a new battery.. help
you should perform calculator tests to verify the good working order of the calculator.
  1. With calculator OFF, press and HOLD the [X] key, then press [ON]
  2. Release the [ON] key, then the [X] key.
This sequence initiates a complete testing of the circuits. If all is well., the calculator should display -8,8,8,8,8,8,8,8,8,8 and all indicators should be lit for about 15s. The calculator displays running.
If calculator displays Error 9, another result, or displays nothing it needs to be repaired.
Hope it helps.
Thank you for using FixYa.
Nov 21, 2009 | HP 12c Calculator
Texas Instruments TI-5006 II Calculator Logo
166 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
