Question about Ovens
Kenmore Elect Built-IN Oven Model 790
Oven control beeps and displays F code error - will not re-program. House had major power surge and oven was disconnected while new service we installed. This oven had only been used 3 or 4 times. We purchased it new in fall 2004. Unfortunately this oven is in our house in Mexico, state of Sonora, near Navajoa and there are no Sears repair services nearby. PLEASE HELP! Thank you
  • Gary Davd
    Gary Davd May 11, 2010
    What is the F code you are getting
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 68 Answers
You don't say what specific F code error. If it is an F7, go to the following link for my solution.
http://www.fixya.com./howto/h155060-dreaded_f7_error
I have shared my fix with over 1570 folks and most report success. I hope that it works for you too. Please let me know at:
hutchipop@yahoo.com
Posted on Feb 24, 2008
    Problem Solver:
OLD MODEL KENMORE STOVE.....THEOVEN DOOR IS LOCKED AND WILL NOT OPEN....NO F7 OR BEEPING SOLUTION....IT IS TO OLD...WE TRIED UNPLUGGING AND REPLUGGING. NADA!!!
Posted on Jun 23, 2008
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Tip
Related: F2 E6 on Whirlpool RBD305PDS14 double oven - blank display
Equipment is Whirlpool double oven RBD305PDS14 built-in.  After a very stormy summer 2007, I thought a power surge may have zapped the control board.  Problem initially presented on display as error & fault "E6 F2"; simply pressing "Timer Off" would usually clear this error & fault code.
However, some months later, the display would often go completely blank followed by the beep sequence "short-long-short-short-short" (Morse code: dit dah dit dit dit).  No error & fault code would appear.  Pressing any keypad oven control did not work at all in this condition.  When power was cycled at the breaker panel, the usual "PF" with clock display did not appear.
[TURN OVEN POWER OFF AT BREAKER!!!]
After following the excellent information on "how to remove the control panel" posted in this forum, I first tested the "control panel thermal fuse" (refer to the tech sheet that should be behind the control panel once it is removed).  It showed a closed circuit.
I turned my attention to the "flexible" keypad connector cable (error & fault code "E6 F2" is a keypad or keypad connector problem; again, refer to tech sheet).  The control panel has a board mounted female connector with two tabs that may be gently pulled upward to release the flexible cable.
I cleaned the flexible cable contact area (it seats into the board mounted female connector) carefully with a Q tip and some isopropyl alcohol.  I reinserted the flexible cable and gently pressed down on the two tabs (noted above) on the board mounted female connector.  VERY GENTLY tug on the flexible cable to insure it is gripped by the connector.
After all of this monkey business, I re-mounted the control panel display panel on the oven and restored power.  So far, so good.  After applying power, the "PF" with clock display always appears.  I am able to set the clock and press "Start".  Over functions normally.  The clock displays as normal and I no longer observe the problem I described above.
BTW, I noted the incoming 240V has transient suppression (no surge protection, however).
on Oct 21, 2007 | Whirlpool RBS245PDS Electric Single Oven
My Kenmore oven, model 790, displays and beeps the F10 Fault
June 8, 2010
Same thing happened to mine this morning....cut the circuit breaker for a hour....open oven and let it cool....
mine stopped, finally. Dont know if its a long term fix yet.. but at least it stopped the beeping.
May 06, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
F1 error code on 790 model range
Electronic oven control fault
Oct 06, 2009 | Kenmore Ovens
I have a 8 month new elect built-in oven, model 790, Kenmore. The door wont open and giving a F-9 fault indications on the control panel display. Tried everything to get it to unlatch so i could open the...
should still be under warranty- contact your kenmore repair center or dealer where you purchased it. might be a failed safety interlock switch.
good luck! hope you sent in your warranty reg. card, or still have your receipt! if you have your owners manual, it may have a list of fault codes, and what they mean, and possibly explain how you can clear them! when in doubt- try unplugging it and plugging it back in- carefully! you're dealing with 220V! turn it off first!
Sep 24, 2009 | Kenmore 30169 Electric Single Oven
The oven was continuously beeping last night. Hit everything on the display setup to try to get it to stop. Eventually it shut off all together(the beeping and display) not the only thing that is showing...
Ok. this is a control fault. the chip set is damaged. this will usually happen when there is a surge or power failure during a storm or faulty transformer on the outside pole. you Will need to replace this damaged Electronic control board if possible . it has failed.
You can confirm my diagnosis by cutting the power to the oven for 5 minutes. this will reset the control. if the oven continues to react this way with the constant beeping and, non action, this will confirm major control failure..It is possible that this reset will recognize the program and fix this fault but, normally, a fault of this nature will require the replacement of the Oven control board.
Jun 18, 2009 | Jenn-Air JJW8230D Electric Double Oven
Kenmore oven error code f10
on that type of range F10 indicates a problem within the electronic control, but it could possible be caused by a faulty temperature sensor.
I would recommend service from a technician
May 27, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore oven F1 error code
I have a whirpool oven that won't self clean anymore and it comes up with a FSE 1 error which is a factory service error and the code is a 1 . You need to call them to come out and have a tech fix it as it's digital
Mar 10, 2009 | Ovens
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 16, 2008 | Ovens
My kenmore electronic stove is having a beep with code F1 on the
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
629 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
