Magellan RoadMate 700 GPS Receiver Logo
Anonymous Posted on Feb 23, 2008
Power wont come on
Dear Friend,
My unit roadmate 700 wont power up when button is clicked, before that it was tempermental with the power on.
Thank you
Joe
  • brenlyn1 Feb 24, 2008
    Unit was working fine one day and the next it would not power up. Everything is upgraded on the unit. The power cord for the auto blew two fuses as well.
Anonymous
Level 1:
  • Contributor 50 Answers
  • Posted on Feb 23, 2008
Anonymous
Contributor
Level 1:
Answers
50
Questions
Helped
13185
Points
52
Get a new unit like any magellan mastreo series 4000 or higher or roadmate 800 or higher,i had a 700 they start having alot of problems after i did my research on here.i have the mastreo 4000 and the roadmate 800 both work great.
2helpful
My Roadmate 700 will not stay on. It loses power
if its the port on the cradle, you can buy them on ebay cheaper then fixing it.
2answers
Repair Roadmate 700
You can try first updating the firmware of the unit and reset it after that..
Hope that helps.......
Wont power up on car adpt. i ccecked power to end of adpt. with meter but unit wont power up
what was the dc voltage ????? sometimes like on my tomtom i have to hold down the switch a little bit longer to fire her up......
1helpful
Blue screen with magellan logo , this is what I see after turn on my gps receiver, I tryed to push any button but anything change on the screen, to shut it off i have to use 'enter' ,'cancel' and power...
This is the boot screen, Remove the power connection, and reinsert while you press the "Cancel" button at the same time, if done correctly, your Roadmate should continue to boot and enter the user mode.
1helpful
2answers
Power adapter for Magellan 700 is broken
Connector J1 is the power connector. The left post corresponds to the center lug. The middle post is the outer connection. The right post closest to the USB connection is just an anchor - no connection.
Magellan RoadMate 700 GPS does not work properly
It seems that Magellan is not good with the power connectors on their units, I believe the problem is with the power adapter plugged into the cradle. Sorry I have no information about a repair center. Usually for an absorbent amount of money, Magellan will repair.
Magellan roadmate 700
The battery looks like a Lithium battery and it should be 3 volts or close.
I to loaded new maps and am not autherised to use them. What a joke! Looks like a case of to much security to protect Magellian's already to high of a profit!
2answers
Magellan Roadmate 700
J...
at the user menu press the "-" zoom out key the "+" zoom in key and the repeat button which is on top of your unit. Once your in the "hidden" menu, select reset user data.. your unit will reset and everything will be clean. If your trying to delete specific addresses I would use software to sync up and explore your MRM's files.
- If needed please ask more questions prior to rating -
Road mate 700
The flash card hole is supposed to be empty - all you need should be on the hard disk BUT the first Roadmate 700 I purchased was empty i.e. no software loaded. The second failed due to bad power connection, the third worked but was factory refurbished! what a crass organisation Magellan is!!!
Try fiddling with the power connection that goes into the cradle that the unit sits on. The power connection is ultra sensitive. BUT, if you've only just bought the unit then you are in luck - return it and get your money - back Magellan Support is extremely poor.
I am binning my Roadmate and getting a Tomtom720 Go series with maps and cameras preloaded - it auto updates when it is on its cradle attached to my PC/internet.
Bin the Magella - 4 years of problems!!!!
Roadmate 700 wont power up anymore
I had the same problem. At first intermitant and then permanent. The power connector inside the based that the head unit snaps onto had the center post fall out. You need to removed the 4 small screws located in the threaded reseases. Then using a knife I pried the plastic halves apart. You need to break the ultrasonic bonding on the plastic, but everythign seperated where it should. Now you have access to the circuit board. I soldered in 2 wires which I brought our and soldered to a cigarette outlet cord. Then I screwed it all back together.
Top Magellan GPS Experts
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Magellan GPS Expert? Answer questions, earn points and help others
