Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
No picture ; no sound
I had this Akai PDP4294 for 3 years and seldom used it. First the sound went out ...about 1 year ago...used my sound system and the tv was just a monitor. But a few days ago; the picture went out all of a sudden...red blinking ligt on the from and that's all...I don't think this unit was usedmore than 200 hours. AKAI is JUNK!!!
    Sniper:
  • 67 Answers
The red blinking light usually has a pattern that gives you a code to the possible problem.
Maybe you have a bad power supply board. You have to open the panel and do a few tests on the power supply's outputs to be sure.
It produces a variety of voltages for different parts of the tv ie. the plasma display panel and the audio system. The components supplying power to the audio system may have failed a year ago and recently the pdp.
plasma tv's are expensive to repair, most of the time you can get a better tv for the same price. You can reduce that cost by learning and troubleshooting it yourself.
Posted on Feb 24, 2008
The picture on my akia flat screen went out it still has sound . Is it worth fixing or throw it out? its almost five years old. It was a sudden loss of picture, not gradual
You need to replace the Lamp this set has 2 Lamp #numbers
Look at the serial# on back of TV for either a J or Z in it that will tell you which Lamp you will need to order
Encompass Parts Distribution list this Model#.
Mats Electronics has Lamps for $99.00 1-800-628-1118
Oct 24, 2010 | Akai PT46DL10 46" HDTV-Ready Television
Authorized Repair Centers for Akai Flat Panel TV
first try to reattch all coneection to your televison.
then open the back side cover of your tv then reattch all connectiuon there .
Also clean dust from all circuit.
Apr 23, 2009 | Televison & Video
Akai LCT3201AD 32 in. LCD picture stretched around the corners
This set has several differant aspect ratios, could you have unwittingly change it to a zoom or expand by mistake?
Feb 07, 2008 | Akai LCT3201TD 32 in. LCD Television
Akai PT4298HD..Please help!!
Normally, yes.
Make sure you get the CG Board Part number:
BP94-00155A
There are other boards in this set that say convergence, but, they are not the boards you want.
Available at:
Andrewselectronics.com
Easy to replace.
Any questions, reply to this post and I will respond.
Jan 13, 2008 | Akai PT4298HD Rear Projection Television
Akai PT5598HD
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 17, 2007 | Akai PT5598HD 55" Rear Projection...
My 42 inch Akai is about 6 months old,, and is showing green where black should be..
BUt there is help for you all.. Call Verizon, sign up for their "Expert Care" program. it's $10.00 a month, and active after the third month.
with a $75.00 deductable. THey will fix or Replace (give you choice of three alternate models/brands).
Free services under this plan are adjustments, and One FREE remote per year!.
i recomend you sign up for this program, and after 90 days. call for service. They more than likely will replace your TV's.
This is what they did with mine..
ALSO.
it doesn't matter how old your TV is, the plan is applicable to all TV's in your household. So one plan, one monthly payment of $10.00, covers all the TV's you own!!
Dec 09, 2007 | Televison & Video
Picture went out on Akai
I have the solution.  Call me  910-8936663
Oct 15, 2007 | Akai PT5492S 54" Rear Projection...
Won't power on, no picture or sound
I just got done fixing an Akai LCT2660 that had four bad capacitors on the power board.Works perfect now.Hope this helps.Thank You very much!
Tyler
Sep 03, 2007 | Akai LCT2060 Television
Akai pdp4292 42in
Repaired one of these with the same symptoms about two weeks ago. My guess is that the SMPS has failed. In laymen's terms the power supply, Samsung p/n#Bn96-00249a and you should be able to purchase it at Vance Baldwin http://www.vancebaldwin.com/ and just sign in as a guest, select parts# and input the number above (no dashes). Be seated when you do they're a bit spendy - - about $270.00 dollars plus shipping and a $50.00 core... You get that back when you send them the old one.. After you get the back off the PS is located in the middle of the unit at the top of the screen. If you need the service manual to help just let me know. It's actually an easy plug and play repair... Good Luck Bill premtech@willapabay.org
Jun 07, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
203 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
