Question about Bosch 24 in. SRS43C12 Classixx Slim-Line Free-standing Dishwasher
Bosch classixx dishwasher not draining
My dishwasher does not want to drain water lays in the bottom of machine suspect pump has died checked filters for blockage blown back down the outlet pipe and is clear is pump replacement easy and cost effective the machine is 5 years old
  • n193uz Sep 08, 2008
    yes, I have exactly the same problem, but havn't been able to find access to & remove the pump. It would appear this is a common problem, is it worth getting it repaired or would you suggest replacement?
  • Christian Nov 13, 2012
    Hi there. I just went through the same problem. What I did was empty the machine completely with a mug and ended off with a sponge. In the drain there is a white clip on the left hand side. I took it off with my thumb nail. It looks like a pipe holder. Once that was done I moved the impeller backwards and forward a couple of times and the then lifted the float (dome shaped thing just next to the drain. The impeller started to turn but not so well. So I thought there should be a blockage some place. I went under the sink were the dishwasher is connected to the outlet pipe. I took it off and used a plumbers split (drain cleaning wire)(all hard wares have them for very cheap) I pushed the round end of the split as far up the pipe as possible, pulled and pushed, pulled and pushed until it felt unblocked. I then connected it to the outlet pipe again. I ran a rinse cycle and then checked. The machine was full of water again. So I put the white plastic clip back, then lifted the dome once more. The machine emptied better than ever. It may sound complicated but it is not... its very easy and saved the call to the plumber. Good luck.
  • 105 Answers
Try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
Posted on Feb 24, 2008
Bosch dishwaser. starts and stops, it will say clean. leaves water in the bottom. we purchased a new pump and still not working? :( :(
All dishwashers leave a little water in the bottom. However, I suspect there's an appreciable amount in the machine. I'd suggest you lift out the filter and check the drain port.
Feb 11, 2015 | Bosch Dishwashers
How do I resolve f17 error message on bosch classixx 7
F17 is a time out fault on drain pump. Check all water hoses and drain pump for either blockage or restriction. Failing that, check your waste pipe is clear.
May 29, 2014 | Bosch 24 in. SGS43C12 Classixx...
Bosch classixx dishwasher sgs43c12 not draining.
The only way to eliminate a pump issue is to actually remove the pump and check it internally, it doesn't take much to block them and also the impellers can come loose, It sound like you are handy with tools so i suggest removing the drain pump and while it's off check the hoses that run to and from the pump for obstructions and make sure the impeller is not loose.
Mar 05, 2012 | Bosch 24 in. SGS43C12 Classixx...
Bosch classixx dishwasher wont drain
Ive had this happen on mine too. remove the filters in the bottom. squirt washing up liquid into the space-- liberally dont be shy!
Boil pans of water, boil the kettle. pour water into the space where the filters normally are. Fill the base of the dishwasher completely. Next close the door and repeatedly use the Reset feature. Eventually the pump will clear and kick back into life. Its a build up of fats, and sludge that causes the pump to appear to seize--the washing up liquid and boiling water see to that.
Feb 05, 2012 | Bosch 24 in. SGS43C12 Classixx...
Not draining and check water light on
you have a blockage in drain pump consult manual for cleaning process when water drained away check water light will go out.
May 27, 2010 | Bosch 24 in. SGS43C12 Classixx...
How do you check if the pump is blocked on a bosch classixx washing machine manual? Bottom right at the front, I guess. What do I do? How much water will come out - a towel's worth? Should I place a tray...
The pump is as you say located at the bottom front right of washer.
Remove the bottom cover if there is one, unscrew the filter handle to the left, and remove same.
There will be some water, but not a lot.If there is al ot of water in,before you remobve filter , lay the drain hose down low to syphon the water ou
It is a fairly straightforward procedure.
Please rate my solution.
Thanks.t.
Nov 24, 2009 | Bosch Classixx WVF 2402 Front Load...
Water not draining from the machine
If it IS the pump, it’s often because some relatively minor item (piece of cocktail stick/bit of nutshell/etc) has found its way past the filters and is blocking the blades of the pump. It is relatively simple to remove the inlet hose to the pump and clear the blockage (a pair of grips to pinch and remove the retaining clip, then the hose will slide off the fitting on the pump). I did this several times on my previous (Hotpoint) machine – and suspect it is no harder on the Bosch (which I now have). If that doesn’t work, you are half-way to replacing the pump, which is not a difficult DIY job and I’m surprised any competent professional repair man wanted to write off a machine where the pump had failed. A new pump should cost around £40-£50 – less than a quarter of the cost of a new machine. DIY fitting would maybe take a couple of hours; a pro ought to do it in less than an hour.
Mar 08, 2009 | Bosch 24 in. SGS43C12 Classixx...
Water leaking from dishwasher
check the hose in the back to see if it split could be dry rotted
Jan 09, 2009 | Bosch 24 in. SGS43C12 Classixx...
Bosch SHV 4303 Dishwasher not draining
I have a Bosch Classixx with what sounds the same problem.It would not drain properly and hummed even when the front door was opened.After a couple of days it ponged a bit.This is what I did.Sypnoned off yukky water with a short length of hose (fill pipe with water from tap don't **** on it!!).Cleaned filter under cutlery tray at bottom.Then put a TEASPOON of bleach if on main drainage or dishwasher cleaner if septic tank.Ran on a hot wash and see if it sorted problem-it didn't but did clean system.
Syphoned off again -take care.Isolated electric and water supply.-Should do that first perhaps Pulled out from under counter undid drain hose at sink end and water at machine end.I then put machine on side and undid bottom silver plate.Note position of polystyrene float switch cover.I then followed drain hose to drain pump and undid it by twisting it like a bayonet light bulb undoing clip levering with screwdriver (not for feint hearted as easy to break) -I then checked little impeller for foreign object-found none so pulled off pump housing by rubber hose to bigger pump thing next to it and found small bit of plastic put it back together and hey presto problem sorted-I was told it might take two hours for the expert to do it once on his workhop bench-it took me about 30 mins plus a bit of head scratching and a yank and push or two which could have been rather expensive -I was lucky!
Aug 19, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch classixx slimline dishwasher not running through cycle
fault is that there is a leak. the tray at base of dishwasher is full of water which operates a float and turns on drain pump. tilt over 45deg and water will run out and then it will work or remove bottom front panel and mop out (better). then find leak
Mar 17, 2007 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Bosch 24 in. SRS43C12 Classixx Slim-Line Free-standing Dishwasher Logo
3,139 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
