Question about Digi 002 Rack FireWire-based Pro Tools LE External Sound System
002 rack red light only
When i turn on the unit all i get is a red light on the mute
any idea i am and service tech for a lot of things is there any wiring solution
for this situation
  • 6 more comments
  • blues12 Mar 22, 2008
    Yes, I've had my rack for a couple of years, no problem until now.
    Description of problem: I turn on the power to the 002 rack system, there will be the usual clicking sound before it begins to operate and the green light on the sample rate indicator on the rack will light up (44.1), then the light will shut off, like the rack has gone dead, only the red mute light will remain on.
    Then after a moment (a minute or thirty seconds) the rack will make the clicking sound again like it is trying to start up again but fails to catch on, the red mute light still remains on through this whole ordeal.
    All my connection are working (firewire external drive, connect from Digi 002 rack to firewire card). I will launch the Pro Tools software and it will say that the Digi Rack (hardware) is not connected. It seem to be an internal problem inside the Digi 002 rack.
    Anyone have this same problem? Help!
  • Anonymous May 26, 2008
    I have the exact same problem. What was the solution? Thanks.
  • dsqrd May 31, 2008
    I have the same condition. It occured after I had installed a Western Digital mybook external firewire hard drive. My friend (an Mac tech) hooked up his external drive and it did the same thing. Also the green link light on the rear of the panel comes on for one second then goes off when you plug the fire wire cable in. The protools program cannot find the dae etc.
  • Anonymous Jul 17, 2008
    i have the same problem minus the clicks. the mute light turns on and thats all the unit will do
  • Anonymous Aug 05, 2008
    I too have the "Red Light Only" problem. Upon starting one time it clicked and clicked trying to get started. I ppowered down and tried again, annd now I have the dreaded red light only....
    I tried unplugging annd re-plugging the wires from the power cable, but still the same problem. I can't seem to find any other forums talking aboout this either. Does anyone have any OTHER solutions?
    Thanks Chad
  • Chadfish Aug 05, 2008
    I too have the came problem, and tried thhe fix below, but stimm the same problem...
  • nuflow Sep 04, 2008
    Does anyone have a solution for the red mute light on the digi 002 whats up with this.  Is the unit malfuctioning or what......
DSQRD here...
After disconnecting power source, I went back in and unhooked and rehooked the white plastic connector located at the front of the unit. It's in between the power switch and the mainframe and has about 6 wires through it. This time it worked and the 002 lit up. It's kinda humid in my studio and I think the connections film up easily. I plan to address that issue as well. It was a coincidence I guess that all this started the same time I hooked up the external drive. It through us off as to what had happened.
Good luck
Posted on Jun 01, 2008
  • 4 Answers
It worked!!!
You're a genius and I am forever indebted to you.
Posted on Apr 26, 2008
I just had the same problem... It has to do with the connectors from the power harness. Found this on the internet and it did the trick for me...
It seems like it's only a matter of time before the digi002 (rack and non-rack) have this problem. You'll go to turn it on and the mute light turns on and nothing else. You don't hear the 3 clicks that you usually hear when turning it on. Your computer doesn't recognize it. Then you start swearing and promising to quit recording forever. After all that happens, you have 2 options:
1. call digidesign. they've been replacing the power harness (source of problem) for just about everyone, even if you're out of warranty and it's free (including the tech support over the phone). don't pay them anything. maybe shipping.
2. most people seem to have the same problem after a while after getting their new power harness. lots of people are saying it's not even the harness - just the connectors. so last night i had this problem and i opened up the top of the box and unplugged and plugged back in the little rubber-covered wires going from the power cord to the rest of the 002. turned it on. works fine. i may try to use some of that connector-cleaner from GC if it happens again.
so if you find this happening, don't panic. try the above. takes 5-10 minutes (only because of all of the screws)
Posted on Mar 26, 2008
  • jpbergmans Oct 16, 2010
    Worked for me also.
    JP
  • daveinob
    daveinob Jul 31, 2012
    worked for me too
My Digi 002 Rack is "Clicking" (the actual unit).
Hi
First thing to do is a hard reset. Merely unplug the power cord for 4 hours, then power up again.In order to dissipated the remaining current stored in the memory and disconnect all unit connected.
Regards:
votit
Feb 08, 2011 | Digidesign Digi 002 Rack FireWire Pro...
Only the mute button comes on on my digi 002 rack
first right click my computer in the desktop then properties then hardware then device manager then expand the audio,vedio and game controller see wether the driver is installed properly if not installed it will show yellow question mark the reload the correct drives from the cd which you recived with your computer install the audio software and restart the system then in the taskbar you will see the speaker icon right click them click adjust audio properties in volume move the slisders to full on uncheck the mute then restart your computer
Jan 21, 2011 | Digi 002 Rack FireWire-based Pro Tools LE...
My computer won't recognize my 002 rack. Just
probably too late..but the internal power harnesses go bad on the digi oo2. I bought mine from sweetwater and they sent me a new harness for free.
good luck
Feb 19, 2010 | Digidesign Digi 002 Rack FireWire Pro...
Turn digi 002 on and the mute light keeps stay on
Jan 26, 2009 | Digi 002 Rack FireWire-based Pro Tools LE...
Macbook pro does not detect digi 002 rack
yeah i have an intel imac and had the same problem. I upgraded to pt le 7.4 and now pro tools recognizes the 002 rack and it works fine, but still the core audio manager does not recognize the hardware. It says in "use" when I first turn on the 002 rack, then it says not connected after about 20 seconds. I don't think this really matters though because I have beeen able to do everything fine without having the core audio managr recognizing the 002 rack. I hope that helps
Dec 04, 2008 | Computers & Internet
Digi 002 rack firewire
Hey -
Unplugging the harness and reconnecting only worked for a couple days. It turned out that I had to call digidesign and they sent me a new power harness for free. That fixed it for me.
Jun 01, 2008 | Digi 002 Rack FireWire-based Pro Tools LE...
Digi design 002 rack
Is your firewire cable good? Sorry, I know this is obvious.
May 08, 2008 | Digi 002 Rack FireWire-based Pro Tools LE...
About Digi002 rack..
no worries..when you talk about a rack, are you speaking about a mounting rack? can you provide the full part/model number for this device?
Feb 17, 2008 | Edirol UA-4FX External Sound System
"Unable to locate" 002 Rack Unit - sometimes!
Please help this guy and me too. I had the same problem. I emailed digidesign but cant get a good answer. I hpe this shit is not broken. I just bought it 2 years ago.
Sep 10, 2006 | Digi 002 Rack FireWire-based Pro Tools LE...
Digi 002 Rack FireWire-based Pro Tools LE External Sound System Logo
1,239 people viewed this question
Top Digi Computers & Internet Experts
Alun Cox
Don Hart
Chris Larocque
Are you a Digi Computer and Internet Expert? Answer questions, earn points and help others
