Question about Compaq Evo D510 Minitower (Open Box) (OB4700432011) PC Desktop
Monitor resolution re-set with a Samsung MW225 and Windows Vista
The video resolution on my Samsung MW225 Monitor is reset to lowest resolution sporadically after restart or user account changes. Anybody any idea how to fix this? PC runs Windows Vista Home Edition. Thanks!
  • 2 more comments
  • Marcel Nussbaum Feb 24, 2008
    Thanks kykeaton. I checked the registry. Unfortunately, there's no such entry. ( /NV does not exist).
  • Marcel Nussbaum Feb 25, 2008
    Hm...I am attaching the monitor to a HP Pavillon Slimline...
    Device Manager says that I am using an ATI Radeon HD 2400.
    I assume the graphics card is on-chip.
    Thanks again
  • Marcel Nussbaum Feb 26, 2008
    Again, thanks for trying, but turning off TMM had no effect. Monitor resolution still changes back to lowest at each startup / wakeup / user profile change. Might have to fall back to the Bill visit :-).
  • Anonymous Mar 23, 2008
    hi..i just restarted my pc today"windows vista"..and then changes the screen resolution but cant see anything its all dark and the message i get is this reoluation out of rage..is there any chance to change back to normal.?
  • 35 Answers
Yes if your comfortable with editing your registry.
remove the following: (backup your registry first)
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\nv\Device0]
"DefaultSettings.XResolution"=-
"DefaultSettings.YResolution"=-
"DefaultSettings.BitsPerPel"=-
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\nv\Device1]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\nv\Device2]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\nv\Device3]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Services\nv\Device0]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Services\nv\Device1]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Services\nv\Device2]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Services\nv\Device3]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0000\Settings]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\nv\Device0]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\nv\Device1]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\nv\Device2]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\nv\Device3]
Posted on Feb 23, 2008
  • Kenneth  Keaton
    Kenneth Keaton Feb 24, 2008
    Ok so you don't have an Nvidia graphics card then,.. was worth a shot for it to be an identical issue. I can still help though
    just let me know what kind of Video card you have or Video chipset if its integrated
  • Kenneth  Keaton
    Kenneth Keaton Feb 25, 2008
    I dug this up and it, let's see if it helps. :
    Vista has a module called Transient Multimon Manager.
    Seems this module has been causing this EXACT issue with other people, so since my fix didn't help,
    let us hope this one does. Hang in there, we WILL figure something out if I have to call Bill Gates and send him to your house! :-P
    Follow directions to DISABLE TMM and let me know your result. http://www.vistax64.com/tutorials/115320...
My NEC MultiSync LCD 1765 monitor boots up to the lowest resolution available. When I attempt to correct the resolution through the Display Options in my Control Panel Settings, I set it at the highest...
Try connecting the NEC to a different computer, to see if it correctly accepts 1280-by-1024.
If so, then there's nothing wrong with the monitor, and the fault lies with either the video-adapter in your computer, or something messed-up with your installed copy of Windows.
Try replacing the video-adapter.
Dec 29, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
Samsung 920WM monitor - Color problems, "blotches"
The 920WM has a recommended resolution of 1440x900. If your display properties are set to a higher or lower resolution, there will be ugly effects on videos, photos and fine text.
If you're running WindowsXP, minimize your apps and web browser so you can see the background.
Right-click on the background and select "Properties" to bring up the display properties dialog.
In that dialog, select the "Settings" tab to see the display resolution.
Set that to 1440x900 if it's not already, then hit "OK"
If videos are still blotchy, then check the video playback software to make sure it's not setting it's own resolution.
If that helps, please be sure to hit the "thumbs-up" button for me.
If not, use "add comment" to fill in some more details (XP or Vista? What's the video playback software called? How are you viewing pictures?) and I'll do my best to help!
Jan 05, 2010 | Samsung SyncMaster 920WM LCD Monitor
Resolution resets after reboot
The RAM module/s may be faulty or needs reseating because the video card grabs some of the system RAM. If you got two RAM modules then swap them around in the DIMM slots.
Try deleting/disable the video driver or change it to standard VGA.
If you can uninstall the video driver then OK.
Reboot the laptop and reinstall the video driver and it usually requires a reboot for the driver to take effect.
Also try connecting an external monitor to the laptop's external video port, power up the monitor first then the laptop. The video should automatically divert to the external monitor. Then try and change the screen resolution. If this doesn't work then there is a possibility the Video card might be faulty.
As a last resort reinstall Windows it may fix your problem.
I've run out of further ideas, good luck.
Apr 12, 2009 | Dell Latitude D620 Notebook
When I boot into Windows Vista Premium nothing on screen
In Safe Mode, your monitor will not be listed as it is using a generic device driver for basic display. Go into your video settings and reset it to the lowest resolution available. Reboot the computer into Vista again and your display should be working. If you check Device Manager now, you should see your monitor listed. If it isn't, you will need to load the Vista drivers for it. You can then modify your display settings to suit your preferences.
Mar 28, 2009 | ViewSonic VX2035WM LCD Monitor
NO DISPLAY :(
the resolution setting may have been in inadvertently change to one that your monitor does not support you mentioned that you have another monitor that does work with your computer what i would do is to set the video resolution to the lowest possible setting and the turn off the computer and connect the questionable monitor to your computer and reboot if it does come up then you will be able to make changes and find an appropriate resolution for your monitor
Dec 27, 2008 | Samsung SyncMaster 710N 17 in. Flat Panel...
My HP monitor (f50) has malfunctioned
Try these 2 steps if they don't work get back to me :)
Step 1. Connect the video cable and turn on the computer. What happens?
  • If the monitor screen remains blank (no startup screens or onscreen display messages), the monitor must be connected to another computer using a different cable to determine if the monitor is bad. Skip to the Step to connect the monitor to another computer.
  • If the monitor is capable of displaying boot screens but is unable to display Windows, use the following steps to set the computer to a compatible resolution:
    NOTE: Find the native display resolution for your monitor in the User Manual or in the product specifications for the monitor model. If you are unable to find the native display resolution for your monitor model, temporarily use 1024x768 for troubleshooting purposes.
    1. Turn on the computer and press the F8 key repeatedly when the first startup screen appears.
    2. If you are using Windows Vista, select Enable low resolution video (640 x 480) , press Enter , and wait until Windows opens. To set display settings that match the monitor, use the steps in the HP support document, Changing Display Settings, Background Image, and Screen Saver in Windows Vista . If you are using Windows XP, select Enable VGA Mode , press Enter , and wait until Windows opens. Continue using these steps to set display resolution. If you are using Windows 98 or ME, select Safe Mode and perform the following steps to enter into a standard VGA mode:
      1. Once Windows opens to the desktop in Safe Mode, click Start , and Run .
      2. In the Open field type msconfig and press Enter . The MS Configuration Utility window appears.
      3. Click the Advanced button, and select VGA 640 x 480 x 16 if it is available.
      4. Click OK and restart the computer.
      5. After Windows opens, click Start , and then click Run .
      6. In the Open field type msconfig and press Enter .
      7. Click the Advanced button, and remove the checkmark next to VGA 640 x 480 x 16 .
      8. Click OK . Do NOT restart the computer.
    3. After Windows opens, right-click on an open area of the desktop and select Properties (Windows XP, 98/Me) or Personalize (Windows Vista).
    4. In Windows Vista, Scroll down and click Display Properties . In Windows XP, 98, or Me, click the Settings tab.
    5. In Windows Vista, select the native display resolution size using the Resolution slider. Set Colors to Highest (32 bit) . In Windows XP, select the native display resolution size using the Screen resolution slider. Set Color Quality to Highest (32 bit) . In Windows 98 or Me, select the native display resolution size using the Screen Area slider. Set Colors to True Color .
    6. Click Apply after you have made your adjustment. The screen should blank out temporarily and come back.
    7. If you are satisfied with the new display settings, click Yes on the Monitor Settings windows. If you are not satisfied or if the screen just goes black, wait: Windows sets the screen back to the way it was before. Try another setting until you find a display configuration that is compatible with the monitor and meets your needs.
      NOTE: If the native resolution is not available, download and install updated video driver software for your computer. Updating the video driver software can add more resolutions (graphics modes).
    8. Restart the computer. The monitor should now display a full screen image in high quality. You are done.
Step 2: Connect to another monitor
Using a different cable, connect the monitor to another computer that has video. Turn on the monitor and the newly connected computer. What happens?
  • If the monitor works, the video hardware on the original computer is likely to be the source of the problems. You can try connecting the original computer to another monitor that works to update its video drivers.
  • If the monitor remains blank, repair or replace the monitor.
Dec 27, 2008 | HP Pavilion F50 17" Flat Panel LCD Monitor
Samsung Monitor resolution reset to 800x600
i think you have problem with your graphics card. restart your computer and then before starting to windows press F8 to set your settings to safe mood, after booting up to windows restart the system again.if the problem persist reinstall the software drive of your graphics card if you have it.
Mar 10, 2008 | Computers & Internet
My monitor is stuck in the lowest resolution
Distorted video after increasing the resolution in Windows. The resolution has been set higher than what is supported by the monitor, ... we recommend 640 x 480 with 256 colors or the lowest available setting.
Computer always boots into Windows safe mode. When booting into safe mode, the lowest settings are used, including your video card. This means that the resolution is 640x480, 16 colors when in safe mode.
Drivers & Downloads for your Dell Monitor Drivers & Downloads for your Dell Monitor ... Drivers & Downloads for your Dell Monitor
These's site click on them and follow instructions, Good Luck....Please dont for get to Vote.Thank you.
Dec 15, 2007 | Dell E173FPb 17" TFT LCD Monitor
Compaq Evo D510 Minitower (Open Box) (OB4700432011) PC Desktop Logo
1,022 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
