Question about Kenmore 23313 Whispertone Bagged Canister Vacuum
No suction I just replaced the bag, and normally after this I have a lot of suction. Now that I have changed the bag I have less suction that I had before. Not even enough to picj up dog hair. I snaked he hose and checked all of the connections. It seems to have an air leak but no amount of tape will fix this. I cleaned the filer as well with warm water and dried it and re installed but still absolutely no suction. I am ready to throw it out! Any suggestions would be appreciated
  • marrarry Aug 21, 2008
    My Kenmore whispertone won't **** at all. The motor appears to be running but the suction is completely gone. I have changed the bag, ensured there is no leak in the system, checked the hose and the exhaust, cleaned all the filters I can reach without a screwdriver. It is a 9 year old vacuum but it cost a pretty penny and I am reluctant to throw it out. I don't want to spend a whole lot fixing it
1, Does the blower (discharge) side blow bunches of air??
Yes: Something is clogged from the bag to the hose end. Try blowing out the hose from the discharge side.
Or: The bag is not properly seated. Make sure that the plastic piece is properly inserted into the bag, and properly aligned and locked in place with the suction intake.
No: Something is wrong in the motor/fan assembly.
2: The hose has a plastic cover on the end farthest from the unit. Make sure that this cover is closed. If it is open, your suction will go way down.
Posted on Feb 24, 2008
My machine has poor suction
When was last time you changed filter or bag or whatever as YOU did not mention make model or anything else that would let one help you
Jan 02, 2017 | Vacuums
Why does my Electrolux epic 6000 sr shut off with suction?
If this Epic 6000 is shutting off when you either just turn it on or while vacuuming with it...it\'s one of several things...1. Change the bag if you\'ve been picking up a lot of "fine" dust such as drywall dust or carpet freshener powder. That\'s ******* them. 2. Being the machine is over 22 yrs. old, the suction control valve inside either needs to be replaced or just cleaned well. This is the usual cause of the vac shutting off especially if you\'ve tried the dial in several different settings. Hope that helps!
May 20, 2014 | Electrolux UltraLux 2000 Bagged Canister...
Can anyone help with an older Euro Pro EP055, It has very little suction.
Cleaning filters on a bagless vacuum helps but filters should be replaced frequently, as often as every 3 to 6 months on some vacuums. Foam filters aren't as critical to replace because the pores are very large (which also means they don't filter out the small particles) so they don't clog as easily but paper filters have much tighter pores which become clogged and restrict the airflow. Cleaning paper style filters with water which can pack the fine dust into the pores clogging the airflow even more.
I recommend replacing filters st least onceor twice per year and cleaning them after each use for best performance and longer vacuum life. Blowing the dust out with an air compressor is my preferred method.
Changing filters frequently on a bagged vacuum isn't as critical because the bag collects most of the fine dust, dirt and gunk. The surface area of a bag is much greater than that of a filter so a bag is less likely to get clogged than a filter. Most homeowners change the bag once per month which keeps the air flowing smoothly.
Sep 30, 2017 | Euro-Pro EP055 Bagged Canister Vacuum
My Kirby Ultimate G does not have enough suction to pick up pet hair. Is there anyway this can be corrected? I felt under the vacuum when it was running, the roller is running, but I felt very little...
An Ultimate G has lots of suction. If you turn on your vacuum and the bag immediately inflates - that is how you can tell if your Kirby is moving air (suction). There is a more modern brush that came out with the Ultimate G Diamond and the Sentria that has stiffer bristles that dig up pet hair better.
Another way to test the suction is to spread some baking soda onto a hard floor and vacuum it up - you can see how much suction your Ultimate G has, or take off the vacuum head and put on a hose and test the suction at the end of the tube.
Ways to increase your Ultimate G cleaning efficiency. Take off the vacuum head and remove the brush roller. Attach your hose attachment and **** vacuum out the head. Put on a new belt, and remove any hair and or string or threads that may be wrapped around the brush roller. Put the roller back on and on the ends of your roller you will see that the ends spin and have numbers on them. If your vacuum brushroll is original - you could have your bristles rather worn and so you can align the #3 on BOTH sides of the brushroller. This would be a good time to consider upgrading to the Sentria Brush.
Remove the bag, and replace with the CLOTH Kirby bag. It has the best filtration and it has the best airflow (which increases what you are referring to as suction). If you want to go the cheap route - at least get the paper Micron Magic with HEPA filtration (but it has slightly less air flow)
Remove the side mini emptor from the vacuum and check to see if there is anything clogged up on either the vacuum or the mini-emptor.
If your engine is running and inflating the bag and you replace the belt, the brush roller and to the cloth dust bag - your vacuum should pretty much run like a brand new Sentria Vacuum. Your vacuum system is outstanding, but may benefit from a little TLC if you have been neglecting it.
Mar 19, 2010 | Kirby Ultimate G Bagged Upright Vacuum
My hoover has no suction at the nozzle, though it has strong suction at the hose. This problem started after I replaced the vacuum bag for the first time.
there is a blockage behind the roller brush remove the roller plate and the roller and check the inlet hose for a blockage also remove the bag and chek the inlet to the bag for some type of obstruction. Don the Vacuum Doctor Alb, N.M.
Nov 01, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Decreased suction
you might have a clog, to try and unclog the lines, you need to unplug the unit, and remove the bag compartment. Then take a shop vac using the hose attachment hold it into the attachment door where there is low suction and try to draw the clog out the way it went in.
May 09, 2009 | Broan-NuTone CV353 Central Vacuum
Kenmore 23313 Whispertone Bagged Canister Vacuum Logo
214 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
