Question about Fuji FinePix A330 Digital Camera
Usb not recognizing camera
My computer wont recognize the camera thru the usb hub
    Sniper:
  • 67 Answers
You have to install drivers on your computer before it will recognize it.
go to
http://www.fujifilmusa.com/JSP/fuji/epartners/
ServiceSupportProduct.jsp?prodcat=710738
and install the usb drivers for your operating system ie windows xp
Your computer will recognize it after that whenever you plug it in:)
Posted on Feb 23, 2008
Printer not being recognized by computer
Sir/Madam
1. Is the printer turned on?
Make sure the printer is turned on.
Make sure the power cord is securely plugged into the electrical outlet.
Test the power by plugging in the power cord of another electrical appliance to an electrical outlet and turn it on. If the power to the other electrical appliance comes on, the printer may be considered to be faulty.
If this product is recognized:
Close this page to return to the installation window.
If this product is not recognized:
Proceed to the next step.
2. Are your computer and the printer correctly connected?
Make sure the USB cable is securely connected to the printer and to your computer and check that the USB cable is not damaged nor badly crimped.
The printer will not be recognized during the driver installation if connected to a printer switch or the printer buffer. If this is the case, try to directly connect the printer to your computer using the USB cable.
If you are connecting the printer to your computer via a USB hub, connect the printer to the first-tier hub from your computer. If the printer driver is still not recognized on your computer, try to directly connect the printer to your computer without the USB hub.
If you are connecting the printer to your computer via a USB hub, make sure the USB hub device is recognized by your computer.
3. Does your computer provide USB or IEEE 1394 support?
If Still Your Problem Is not solved Then Click On Below URL
http://files.support.epson.com/htmldocs/r1800_/r1800_rf/dset_1.htm
Or
Still You have problem Then please Follow Us On HP Printer Support
Jan 08, 2014 | HP P4515n LaserJet Printer
When i plug Numark DJ/iO Sound Card in pop up message says "USB Device Not Recognized - One of the USB devices attached to this computer has malfunctioned, and Windows does not recognize it. For...
there are drivers needed for this item you may need to download them also re install your usb drivers an attach to a different usb port not thru a hub.
Mar 15, 2011 | Numark DJ/iO Sound Card
My computer won't recognize the external thru my usb hub
Hi friend, As you have mentioned that the hard drive is not getting detected through the USB hub, I would like you to please check that if any other flash drive is working from that hub or try to connect the USB hard drive to other USB ports on the hub
Dec 07, 2010 | Hitachi Computers & Internet
Computer not recognizing MyBook when plugged in
Have a look at this article on external hard disk troubleshooting. Could be that you need to delete the USB root hub devices in the Device Manager to force Windows to recognize the device.
Jun 24, 2010 | Western Digital 320GB MyBook External USB...
USB device not recognized
SOLUTIONS:
  1. Unplug the USB device. It is possible that the connection is not secure and has become loose. This is one of the most common reasons for an error in detecting a USB device.
  2. Use the Device Manager to scan for new and recently installed hardware. From the start menu, select the 'Run' option. In the pop up box, type in Devmgmt.msc and then click 'Ok'. From the 'Action' Mmnu, click 'scan for hardware changes'. This will make Windows recognize any new devices that are installed. Now, close all device managers and control panels. Now see if your computer will read the USB device.
If the above two doesnt work, then try the following,
Disable power management of the USB hub. To disable the power management,
1.Click Start, and then click Run
2.Type devmgmt.msc in the Open box, and then click OK.
3.Expand the Universal Serial Bus controllers' node, and then follow these steps for each USB Root Hub that is listed:
4.Right-click the USB Root Hub and then click Properties.
5. Click the Power Management tab.
6. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
PS: If you perform the following procedure on a laptop computer, you may reduce the battery life.
Jun 03, 2009 | Samsung CLP-315W Laser Color Printer
How to save videos from sony handycam to my home pc
you need to put the camera into playback mode
then go into the menu and go to the setup menu
Then USB streaming and turn it on
That should enable the computer to recognize the camera
May 29, 2009 | Sony Handycam DCR-TRV140 Digital Camcorder
I want to connect a cctv camera to psp
yes indeed. you need simply a usb to mini usb hub cable ( about 15 bucks) and hook it in, go to usb mode on the psp it will have a few options. naturally th epsp wont recognize the system immediatelt, so give it time and all will be solved. if this doesn't work, then i recommend changing psp settings on your computer to allow the psp tpo recognize it immediately.
Apr 19, 2009 | Sony PlayStation Portable (PSP) Console
USB DEvice not recognized
I had a problem like this -- tried plugging the camera in to the rear USB slots not the front ones and it worked fine.
I think that it doesn't like going via a USB hub, but wants a direct connection. All of the USB ports on my computer are connected direct to the motherboard (i.e. none are on PCI cards or anything), but looking at the hardware info for the computer, it looks like the motherboard has a few "direct" USB connections, and then an on-board hub which the front ports connect to. If your computers are the same, that would explain things. I'd suggest trying each USB port one at a time (turn the camera off before plugging in, and back on when in) and see if one of them works. Wouldn't hurt to power the camera from the mains at the time too.
Jan 01, 2009 | Video Cameras
Windows XP doesn't recognize my new Canon SD1100 camera even after loading software as instructed.
It is very simple you guys! I had the same problem with my Windows XP SP3 and SOLVE IT EASY!
1. Unplug all your USB devices. If you have hubs, unplug only the devices attached to the hub, not the hub from the computer.
2. Open the registry and delete the following 6 branches.
H_L_M\System\ControlSet001\Enum\USB
H_L_M\System\ControlSet001\Enum\USBPRINT
H_L_M\System\ControlSet001\Enum\USBSTOR
H_L_M\System\ControlSet002\Enum\USB
H_L_M\System\ControlSet002\Enum\USBPRINT
H_L_M\System\ControlSet002\Enum\USBSTOR
3. Restart your computer and attach one by one your USB devices. If you have hubs, first let the OS to recognize your hubs, then attach the USB devices.
Your Digital Camera should be recognized immediately by the system. If you don't have your Digital Camera software installed you can use Windows Scanner and Camera Wizard to upload your photos.
Cheers from Guvidu Romania
Apr 09, 2008 | Canon Cameras
Camera No Longer Being Recognized
Does it connect to the PC via a USB cable? Then try connecting to a different USB port or if you have try a new USB cable. I had the same problem with my IXUS 400 and changing to a new USB port, directly to the PC - not a USB hub, it worked. However now I have several issues with my camera - no sound or image on the LCD screen, but I think these are unrelated.
Jan 27, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
Fuji FinePix A330 Digital Camera Logo
1,453 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
