Question about Samsung Digimax S730 Digital Camera
Card Locked no matter what memory card you put in the camera it says memory card locked
  • Chris Herring Mar 05, 2008
    Customer at circuit city has same problem. I am a tech here and we tried 2 diff 1gb cards and they both came up with card locked. the 64mb card that came with it works fine but none others will. WHY!!!!!!!
  • brinablossom Mar 17, 2008
    The camera says crad locked when I atempt to take a pic with the memory card inserted. When I remove the memory card the camera works just fine
  • 3 Answers
I had this problem too. I took out the SD card (which was unlocked), locked it, then unlocked it again. Then I put it back in the camera and it recognised it as unlocked.
Posted on Mar 23, 2008
    New Friend:
  • 136 Answers
You have to use the origanal samsung chip try samsung.com
Posted on Mar 17, 2008
2 Suggested Answers
SOURCE: Card Locked ! Error
Remove SD card, then whilst card is removed, delete all pictures that may still be stored in cameras 'internal' memory (usually just a few) then replace SD card. Should be unlocked now?.
Posted on Dec 03, 2008
"memory full" but SD cards are empty
Not sure if it will be this, but has the SD card got locked by accident? There is a little sliding button on the side of the card, which can be locked to protect the content. My camera shows the card as full if I accidentally lock the card. You can just slide it back again to unlock it. I never noticed the button was there until I accidentally knocked it while loading the card in and out of my PC to transfer the photos.
Dec 04, 2012 | Fuji FinePix S1000FD Digital Camera
My camera seems to be locked on the internal memory no matter how many blank sd cards i put in it keeps saying memory full
You need to get rid of the pics on the internal memory. With no card in the camera, go into the menu and find "format". Follow the on-screen instructions to erase the internal memory. After that, your card should work properly.
Nov 07, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
I keep getting "card locked!"
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Troubleshooting steps for this problem are listed here.
Aug 24, 2011 | Canon PowerShot SD960 IS Digital Camera
No matter what card we put in the camera, it always read locked and will not take pictures. please help!!
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Aug 16, 2011 | Canon PowerShot A650 IS Digital Camera
My SDHC card is locked. When I put the memory card
The problem solved by using the proper SDHC card reader. It is working fine in the camera now.
Dec 29, 2009 | Cameras
"Card Locked"
Hi!
There's a small switch on the memory card reader inside the camera which detects that the card is locked. Most likely this switch is broken. You can try to point it with needle or something but I'm afraid you will have to give it away for a repair to a local repair shop or Canon service center.
Tom
Sep 23, 2009 | Canon PowerShot A590 IS Digital Camera
It says memory card locked when it's not..
try moving the small sliding switch on the card to the "unlock" position. That usually solves the "card locked" problem.
Apr 02, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Memory card locked
I had the same problem - just put the lock button of the card to the lock position and than again to the unlock position
Jul 06, 2008 | Canon PowerShot A450 Digital Camera
Memory card
If the card is locked, you could the steps below:
- Turn off camera
- Remove memory card
- Take a look on the switch of the memory card itself
* If it's at the TOP = card is UNLOCKED
* If it's at the BOTTOM = card is LOCKED
- So, you just have to make sure that the switch is at the top
for the memory card to be UNLOCKED
After doing that, you just have to put back the memory card to your camera and turn on the camera. Try to check if this works.
Jan 01, 2008 | Samsung Digimax S630 Digital Camera
Samsung Digimax S730 Digital Camera Logo
176 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
