Question about Ovens
Hotpoint EG54P ignition sparking by itself
Our hotpoint EG54P has a gas hob with electric double oven. It has just started sparking the hob by itself every 10-20 seconds unless you turn the power off to the whole oven.
  • LG37 Feb 24, 2008
    I did that- gave everything a good clean and it does seem to have stopped. Will keep you posted if it starts again. Thanks.
  • Gary Davd
    Gary Davd May 11, 2010
    pull off the knob and see if it stops.Let me know
  • 770 Answers
The reason it stopped was you need to push down to activate the switch and turn on the sparking be careful about getting water down in the unit ..Glad to Fix Ya plz rate my answer
Posted on Feb 24, 2008
Can you diagnose the fault & advise me how to fix my hotpoint electric cooker please?
This video shows how to test and replace the faulty heater element on the fan oven on a Hotpoint double oven.
Sep 26, 2015 | Hotpoint Ovens
Gas hob Luce(hotpoint) gas on glass 5ring burners keeps going out on low flame when pull pan drawer beneath out
Same problem with my hob. I adjusted the small jets to their lowest setting in order to be able to simmer -impossible on the bigger jets. The problem is the vents underneath the hob. These can't be closed off so the problem appears to be in the design. The solution I have to use while I save up to by a decent German model is to open and close the cupboard doors underneath the hob very, very slowly.
Nov 19, 2013 | Ovens
Hob on my hotpoint oven trips my RCD
It is either a faulty ring, or the regulator that controls it is faulty.
You really need a meter to test the ring with to be certain which part is faulty.
Hope this helps.
Feb 21, 2010 | Ovens
Hotpoint uy46 style line stainless steel, 2 year old, main oven fan takes 20 to 25 mins to start then runs too slow and some times stops, but the heat element is glowing red and very hot
The symptoms you describe are an indication that the fan motor is in imminent danger of breaking down altogether.
You need to replace it as soon as possibe, otherwise you will end up with the element burning itself out, thus doubling the cost of repair.
Please rate my solution.
Thankyou.
Jan 26, 2010 | Hotpoint UY46 Style Line Stainless Steel...
Ignition switch on a gas hob/electric oven not sparking
Some have a AAA battery under the button - replace this, others use mains to create the spark, ensure you have the ignition wired up
Jun 01, 2009 | Ovens
HOTPOINT DOUBLE OVEN mODEL uy46 BOTTOM OVEN NOT WORKING CANNOT CL
While it is flashing auto ,you will not get the oven to heat up.
You must press the timer buttons in the correcf sequence to cancel auto.Refer to user hand book.
If you suceed with this, and the oven still does not get hot, then the element has probably failed.
Nov 23, 2008 | Hotpoint UY46 Style Line Stainless Steel...
Hotpoint dy230gx
it is normal for the grill electrode to spark as well when lighting main oven - i assume you don't mean that the grill lights - just sparks
Jun 29, 2008 | Hotpoint SY21 Style Line Gas Single Oven
Oven won't ignite
In many cases, even if the igniter is glowing, the 'hot' resistance may not be low enough to turn on the gas valve. The igniter has probably gone bad. ($50.00 to $90.00 for igniter)
Jun 09, 2008 | Hotpoint Ovens
Hotpoint Double Oven ceramic hob
suspect more than one problem. half grill not working may be due to half the element gone open circuit. the other problems could be due to an installation fault. many ovens have links in the connection box which have to be tightened down. this is often overlooked. look at the connection box or terminal strip to check. there is often a diagram of hoiw it should be done adjacent.
Jun 02, 2007 | Hotpoint UY46 Style Line Stainless Steel...
Ovens Logo
268 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
