Question about Alpine CDA-9815 CD Player
Wire house speakers
I want to connect 6x 8ohm 100watt speakers to my large screen tv.
How do I connect them?
  • 640 Answers
Two ways--first you can open up the unit and use the exsisting wires from the tvs internal speakers or goto radio shack and ask them for a audio jack splitter,you would than connect the wires from the speaker to the splitter then plug the jack into the audio input on the back of the tv.If your thinking youll get more sound from these speakers by doing this it wont work unless you have a surrond sound system.Only an amplifier can boost the output.
Posted on Feb 23, 2008
I have a laptop with sound and I connect a large screen to it, but the large screen does not have speakers.
Get a set of remote usb speakers. Is it a large monitor or large screen tv? If it is a tv it will have speakers. They will work if you have an HDMI CONNECTION on your laptop.
Sep 19, 2017 | Apple Computers & Internet
I have a fender frontman 65r with a 8ohm speaker can i add another 8ohm speaker to this
http://cie-wc.edu/Series_Parallel_9_14.pdf
Not recommended.
you could add 3 more 8 ohm speakers in series / parallel wiring and keep an 8 ohm load to the amp, or
2x 4 ohm speakers in series, or
2x 16 ohm speakers in parallel
Jan 11, 2014 | Fender Frontman 65R 65W 1x12 Guitar Combo...
4ohm speaker connected a normal 8ohm crossover is
This is a wrong conection.For 8ohm crossover conect two speakers in serie and one in parallel to one of a previos.Check resistans by multimeter
Dec 02, 2009 | Parts Express 80 Hz LOW PASS 4 OHM...
How do you wire up a dual voice coil lanzar 15 for 4 ohm?
Hello dexterchapma,
The only way to wire a single 4ohm DVC sub to present a 4ohm load is to just connect one voice coil. If you wire the coils in parallel, you get a 2ohm load. If you wire them in series, you get an 8ohm load. But it will work great with just one voice coil. Or if you really want to use both voice coils, and your amp isn't stable at 2ohms, wire the voice coils in series and present an 8ohm load to the amp. It'll work fine, it just won't deliver quite as much power.
Hope this helps.
Jun 27, 2009 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
Cd vs. microphone
A few possibilites.
1. Even though you have some kind of peak limiting on your mics, the signal might still be peaking somewhere along the audio path and causing distortion. Gain controls might be set too high somewhere along the way.
2. The amp you are using might simply be driving too much power for the speakers to handle.
3. A faulty connection, connector, wire or input could cause distortion of something like distortion which is of course would be more apparent at higher volumes.
4. Equipment placement could be picking up sounds or interference from other sources.
5. If you are able to discern level peaks but they are occasional and not flat out, then a compressor placed in the mic signal path could certainly help - otherwise see # 1 above.
Best of luck in solving this.
Cheers.
bd.
Oct 25, 2008 | Audio Players & Recorders
Wish to use extension speakers with Bush IDLCD32TV22HD
You will need to get into menu and enable the external speakers. Some older TV may have a switch at the back to turn the external speakers ON.
Feb 25, 2008 | Televison & Video
AVR 110 Harmon Kaedon
Looking in the manual (link below) I see that this receiver uses 8ohm speakers, check that your speakers are 8 ohms or more. I think that connecting 2 sets of speakers to the same output is the problem as when you connect speakers in parallel (i.e. just twisting both pairs of wires together) you effectively half the impedance. So if 2 sets of speakers of 8ohms are connected this way the result will be 4ohms which is too low and will cause the unit to go into standby. Try removing the additional front speakers & see if the fault persists. If it does then it is likely a fault in the wiring. http://www.harmankardon.com/product_support/support_detail.aspx?Region=USA&Country=US&Language=ENG&cat=&prod=AVR%20110&sjump=om&#active
Jul 28, 2007 | Harman Kardon AVR 110 Receiver
Cabling car speakers as home speakers (is it really that stupid?)
If you wire the speakers as a pair in parallel; (For two 4ohms car speakers) 1/R=1/4 + 1/4 1/R=2/4=1/2 R=2 ohms (the resistance value you'll get) (don't even think of trying it!) in serial; R=4+4 R=8 ohms (this mostly fits to home amplifiers, however, they provide 6ohms as well) I recommend that you use reasonable 8ohms speakers for the home theater amplifier you have. Despite the fact that the impedance value fits to 8ohms when you wire two car speakers as a pair in serial, this type of connection will tire your amp as well as the capacitors of the car speakers. Furthermore, you can get unwanted peak sounds from car speakers.
Apr 26, 2007 | Pioneer SHF21LR Speaker
Alpine CDA-9815 CD Player Logo
48 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
