HI there try these hope its helpful.
1. Restart the PC and repeastedly hit F8 until you have a menu in front of you.
2. You will find few option there. Just select these mention option " Last know good Configuration ...." use by your up/down arrow on your keyboard.
3. Press enter there.
4. your will see the system asking you for which OS you want to use. If you have only one OS then just press ENTER there or select the OS and Enter.
After these if you face the same problem then format the OS & install it again.Thanks & waiting for your feedback.
0x00000024: NTFS_FILE_SYSTEM
A problem occurred within NTFS.SYS, the driver file that allows the
system to read and write to NTFS file system drives. There may be a
physical problem with the disk, or an Interrupt Request Packet (IRP) may
be corrupted. Other common causes include heavy hard drive
fragmentation, heavy file I/O, problems with some types of
drive-mirroring software, or some antivirus software. I recommend attaching the hard drive to a different computer as a secondary drive (so it does not need to boot from the faulty file system) and run ChkDsk or ScanDisk here. If you can, you should back up all user data file, if any, still readable from the drive. If you do not own an XP CD, borrow one from a friend, they do not have any physical copy protection. The key code for installation should be on a sticker on the computer or on a separate cardboard provided by the computer supplier. If there was no such key provided, your copy of Windows may be an illegal copy - contact Microsoft with a proof of purchase and they'll help you out.
