Question about Samsung SF-330 Plain Paper Inkjet Fax
Samsung sf 330
When i copy a vertical black line appears on the copied document.
how can i get rid of it?
  • 168 Answers
If you open up the feeder door (Where your originals feed into) you will see a slit of glass going from side to side by the feed rollers. (you might need a flashlight to see it better)
On the slit glass there is probably some white out or something on the glass. All you have to do is clean the glass and this should take care of your problem.
To help you zero in on where the marks might be located, make a copy of a white piece of paper through the fax machine.
And then line up the copy that comes out with your black marks to the feeder.
This should get you in the general location.
If you have any other questions, feel free to post another question.
If I have helped you, please post a feedback and a rating.
Have a good day.
Good luck.
Mac
Posted on Feb 24, 2008
    Champion:
  • Samsung Expert
  • 214 Answers
Go in your setup under maintinace do shading test. should work then
Posted on Oct 04, 2011
How do I fix this
Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans
support.hp.com/us-en/document/c02881567
Figure : Sample output with vertical colored bands or lines ... Remove any paper from the automatic document feeder (ADF) tray. ... To protect the scanner, do not spray the glass cleaner directly on the glass. .... determine if your printer is still under warranty, and then Contact HP Support to schedule a repair or replacement.
How to get rid of lines on a copied page - YouTube
? 2:10
https://www.youtube.com/watch?v=xTJpCg5sHl0
Feb 17, 2010 - Uploaded by Wayne Springer
When you make copies on your copy machine, does it ever leave a black vertical line ... QLS ' How to Eliminate Vertical Linesfrom Scans, Copies & Faxes ... Part 2- Fix or repair color laser printer with fading, light print, or lines ...
Dec 29, 2015 | Office Equipment & Supplies
How do I get rid of the black vertical lines for the Kyocera FS1128mp?
make a copy from the document feeder and see if the lines are there. then copy from the platen glass and see if the lines are there. then print to it and see if the lines are there. if the lines ONLY occur when feeding through the document feeder then check the slit glass VERY carefully for debris like gel pen ink and whiteout or other stuff. even one little speck on the thin slitglass will appear as a line on a copy through the adf. if it happens on ALL tests. then it could be a scored drum, bad dv unit, secondary transfer, or fuser.
Sep 30, 2014 | Kyocera Ecosys Fs-1128mfp 30ppm All-in-one...
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
I recently installed a new laser cartridge. Shortly after, when copying a document, two black vertical lines began appearing on the copy. What is the fix for this? The black lines do not appear when...
Clean the scanner glass. When I had that problem, I set a copy with lines on it in the scanner feed to see where the problem was, and when I lightly ran my finger on the glass over where the lines were, I could feel two small bumps. I just scraped them off with my fingernail, but here is the HP solution for cleaning your scanner glass:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=378048&prodTypeId=18972&prodSeriesId=378048&objectID=c00062196
Aug 24, 2010 | HP LaserJet 3015 All-In-One Printer
Vertical black line in scan document not in copies through document feeder
Lift the lid and to the left of the main glass is a smaller glass; that is what scans during the feeding process. Make sure that it is completely clean; even a speck of dust can cause a line to appear. I took a lens wipe and cleaned mine and my line was gone.
Jun 01, 2009 | Brother MFC-7820N All-In-One Laser Printer
Black line while scanning and copying
Open up the document feeder and clean the scanner glass
Jan 25, 2009 | Brother Multi-Function Center MFC-240C...
Black vertical lines issues on Samsung multifunction fax SF
Black lines are usually a sign that you have toner on the laser slip glass which is usually situated above the drum unit, its just a little bit of glass if u give this a wipe and get toner on ur finger or rag then thats probably what wrong. If you don't I would look at your drum unit as it might not be cleaning correctly, which would mean getting a new one.
Hope you find this info helpful. Cheers
Dec 13, 2008 | Samsung SF-830 Plain Paper Laser Fax
Full page vertical line appears on copy fed pages.
Open up the document feeder. You will probably find wite-out on the scanner glass.
Dec 12, 2008 | HP Officejet 5510 All-In-One Thermal...
Samsung SF 330
Un plug the power crd fo 10 seconds
Oct 20, 2008 | Samsung SF-330 Plain Paper Inkjet Fax
Samung Sf-330 fax.
probably you did not fix properly the ink cartridge.check the cartridge for proper seating.
Jun 02, 2008 | Samsung SF-330 Plain Paper Inkjet Fax
Samsung SF-330 Plain Paper Inkjet Fax Logo
142 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
