Question about Canon imageCLASS MF5770 All-In-One Laser Printer
MF5770 is not showing an error message, but isn't printing.
I've checked the network settings, and printer settings, and can't seem to find anything wrong. No error message is showing up on the printer, but the printer icon on the task bar disappers and the queue clears within seconds of trying to print. When I check the printer, the file is there, but it doesn't print. The copier and fax machine also seem to be nonfunctional, but when trying to copy, nothing goes to the copy jobs. I've also tried power cycling and rebooting all the computers on the network, with no success.
Thanks in advance to anyone who can help me out.
  • ngwds Apr 30, 2008
    I have had the same problem....I have cleaned the metal connectors and unplugged the copier also.....Can Someone Shed some light on the problem so we can get past this problem?
    I will never buy another Canon.
    Habit-Forming:
  • 131 Answers
Paste the address below in your browser window.You should find some helpful information there.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=124&modelid=11147#SupportDetailAct
Posted on Jul 16, 2008
How do i fix the error message set pcu correctly on my ricoh aficio sp c811dn
Turn the machine off. Open the access door and remove the cyan photoconductor unit. Check the contact pins are straight and undamaged. Gently reinsert the unit. Turn the power back on. If the machine still does not recognise the pcu is inserted it is probably damaged and needs replacing. How many copies/prints has your machine done?
Nov 05, 2015 | Ricoh Aficio SP C811DN Laser Printer
Epson scanner cannot communicate
My solution was that Epson Scan was set to connect via network instead of local. (All was working fine, then it quit-something changed this setting) Try this, go to start, choose all programs, choose Epson folder, choose Epson Scan, choose Epson Scan Setting. In the pop up box set the connection to local or network, whichever is appropriate. Close the window and open photoshop and all works fine. It could be that your problem is the opposite of mine- I try switching this to the other setting even if the change is wrong, then switch it back to see if that works too.
Good Luck.
Jan 05, 2013 | Epson WorkForce WF-7520 Wide Format...
Rpc server is unavailable when installing printer
According to the error message, I assume that the spooler service cannot find out the printer on the network.
You may set the startup type of Printer Spooler service to Manual or Delayed Start for a test.
You could go to Customer support- just dial +1(800)243-0051 Toll Free.
Apr 27, 2017 | Office Equipment & Supplies
Hello: I removed all installed printers from the uninstall list in control panel the other evening. Then I deleted two icons from the devices and printers window but they sometimes reappear. This time, I...
Hi Edward
The automatic reappear printer problem its come when you are connect to two and three computer in same network, when the network on the automatic search the printer in network if you install that printer in any other PC so automatic the printer is add in your printer list.
For installing the printer not nee to delete the all printer, put the installation CD in Rom and click the setup.exe
Cheer
Jul 11, 2011 | Xerox Phaser 6180N Laser Printer
I was able to scan to my computer four pictures without any problems. When I tried the fifth, I get a "scan request failed" repeatedly. Nothing changed between the computer and the printer. ...
What is the status of the WiFi light on your printer? Try to check if your printer is still connected to your wireless network by printing the wireless network settings. How to Print the Network Settings Page on the X3500 and X4500 Series Inkjets; a Brief Explanation of its Values. Check the SSID and the IP address of the printer and see if it's the same as your network.
You can also try to relaunch the Lexmark Wireless Setup utility to connect to the printer again.
May 28, 2011 | Lexmark X4530 InkJet Printer
Printer Offline Message
If your system is showing Printer Offline message, then you need to check the status of the printer in control panel. If it is offline then you need to set it online. The following steps will help:-
1) Click start -> Control Panel -> Hardware and Sound -> Select Printer.
2) If the printer is online it shows "Ready". and if the printer is offline, then it shows "offline".
3) Set the printer online if it is showing offline.
4) Now right click the printer and select "Use Printer Online".
5) The display should change to ready.
Note:- If still you are facing the issues, then update the printer driver or you can also take assistance from any tech support provider such as AskPCExperts. To know more you can also visit: http://www.askpcexperts.com.
Jan 07, 2010 | Epson Aculaser C1100 Printer
I am running Vista Home 32 bit and have a Lexmark X4850. It will not communicate with the printer from either wireless or USB. I got it to print a test page from both, but that was one time after a...
Have you talked with Lexmark Technical Support? I suspect you may have to escalate this beyond level one. Vista on Mac is likely to have issues that differ from other Vista environments.
Sep 24, 2009 | Lexmark Wireless X4850 All-In-One Inkjet...
Destination.msi issue (O/S = Vista SP1)
reinstall your printer software again
I would also check your add remove programs see if anything like that shows and if so uninstall
also go to start programs startup if it shows in startup delete it
restart your system and then let me know if you still get the message on startup
I'll assi8st you further
Jan 19, 2009 | HP Hewlett Packard Pavilion a6130n PC...
Canon imageCLASS MF5770 All-In-One Laser Printer Logo
145 people viewed this question
old marine
old marine
