Question about Canon EF 24-70mm f/2.8L USM Lens
Hard to extend zoom
My lens does not extend easily from 24-70mm without me exerting a great deal of strength. Any way it could be jammed? Any solution to loosening it up?
Thanks,
Biggsman
  • Biggsman Feb 23, 2008
    My bad! It's a Canon L series 24-70 lens (excellent lens apart from this problem- -superb images) and I use this on a Canon 5D and Canon Xti
    Sergeant:
  • 324 Answers
Hate to say it, but unless you have a bunch of experience with lens assemblies, your best bet would be to take it to a camera or photography shop to have them look at it. You need the right sized spanners and such for disassembly. There are also a number of considerations to be taken into account when reassembling them. They shouldn't charge for looking at it and can give you an idea as to what it would cost to have them fix it. From what you've told us, it sounds like it's gummed up and may just need to be cleaned.
Ron-
Posted on Feb 23, 2008
  • 4,889 Answers
Can you let me know the camera model?
  • eagle338
    eagle338 Feb 23, 2008
    Ok. . Can you hear loud noise from the zoom motor even while zooming it slowly or its normal? One more thing you would want to know is that An unusual aspect of the 24-70mm f/2.8L (and 28-70mm f/2.8L) is that its barrel extends as it zooms toward its shortest focal length. This can increase the zoom time a little bit further.If you still think it has not acted like this before, then this is a problem with the zooming mechanism.Since the lens has got dust protection cover its an internal problem with the zooming mechanism itself. I can give you instructions for taking it apart and fixing it but its risky. I storngly advice to get it replaced for a new piece if its under warranty.
    PS: If you still want instructions about trying to fix it yourself i will give them to you.
    Regards,
    Eagle 338.
Sony video camera hdr-cx110 ... blinking error code E:61:00:00 auto focus doesn't work... I can see inside the lens and see movement when I use the zoom in and out ...
Hi Hedonismious,
If the camera is under warranty the best option would be to get it repaired for free via the service center.
Either they will repair it or replace it.
From the error code , it seems to be the zoom lens malfunctioning which you cannot repair by yourself and the error in itself means that you need to get in touch with the service center.
It's a chip level fault or a firmware fault which SONY authorized center can deal with.
What you need to do , i contact the service center and just inform them about the error code that you are receiving , and they will come to know as to what is the problem and direct you to appropriate department and method to get this problem resolved
I would also like to caution you , that you should not attempt anything on your own in this situation because it may result in further damage to your camcorder.
Hope this helps ...:) Let me know in case you have any queries.
Sep 08, 2011 | Sony HDRCX110 Camcorder
I have a new Echo CS-400. It starts easily, and appears to run aat full power, however, It is very hard to cut logs. I have to exert a great deal of force to saw through a six inch log. The chain is new...
Are you certain you have the chain on the right direction? Sounds like you may have it on backwards. A new chain should cut easily almost without effort unless it has come in contact with stones or metal or something equally hard. Hope this helps
May 03, 2011 | Echo CS400 18" Chain Saw
Nikon 55-200 is locked on 55 and won't extend to zoom. Worked the last time I used it, and was on the camera when it stopped.Nikon 55-200 is locked on 55 and won't extend to zoom. Worked the last time I...
Assuming that you've already tried a good firm hand on the zoom ring then all you can realistically try is to give the lens a few good firm slaps onto a desk to try and free up whatever has gone wrong. Brute force usually sorts them out, but it is "kill or cure". This lens lacks a macro mode, so this is not the usual simple case of adjusting a lens control and then slapping your forehead with embarrassment...
The lens is otherwise uneconomic to repair as it's one of the cheaply built kit lenses and so you can easily obtain another for less than the cost of repairs.
Jan 26, 2010 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G ED...
Lens cover jammed open.
No send it back they are the only people that will deal
More over - the likely cost will be very near the cost of a new high spec camera.
Jul 21, 2008 | Fuji MX-1700 Zoom Digital Camera
ERROR REMOVE CAP LENS
I had the same problem with mine after I dropped my camera when it was opening up after turning on. It feel directly on the lens and ever sense has told be to remove the lens cap.
I’ve disassembled the camera and discovered that the zoom motor drive assembly has a small set of plastic gears inside that are quite fragile and like mine are easily broken. You’ll find the zoom motor after taking the back assembly of the camera off. It’s located on the bottom left side of the lens assembly if you're looking at the camera as if you were taking a shot.
Here’s the part no. from the Panasonic support web site.....
L6DAAAHB0001
ZOOM MOTOR
46.07
May 28, 2008 | Panasonic Lumix DMC-FZ8 Digital Camera
Zoom error
worked on allot of fuji's. first detease, a gear is slipping in the lens retract assembly due to a crack or wear or jam
2nd guest .. zoom errors means its really stuck tight
the gears can be ordered and replaced and one more possibility is that the motor that drives the gear is bad
Also if dropped or zoom lens jammed hard... lens assembly needs total realignment or replacing..
May 23, 2008 | Fuji FinePix F460 Digital Camera
Lens jammed
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 04, 2007 | Canon PowerShot A520 Digital Camera
A500 Zoom Error
Your lens assembly has become jammed due to impact or contamination. You can try GENTLY manipulating the extended lens using slight side to side pressure and twisting motions back and forth. Sometimes this will free a component which has jammed out of alignment. Be VERY careful you can easily damage the lens further if you do not use extreme caution. If this method is going to work it will take minimal force to free the components. If this does not work you will need to find a service center to take the camera apart and re-set the internal components in the proper alignment. David Millier Advance Camera Repair
Feb 24, 2007 | Fuji FinePix A500 Digital Camera
Canon EF 24-70mm f/2.8L USM Lens Logo
146 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
