Question about Kenmore 22422 Top Load Washer
Won't spin my kenmore model 110-44722401, apt. size washer will not spin. All other cycles work fine. Went through testing and all OK til it is time to drain and spin. Pressure switch? It is brand new, never used, but has been sitting for a while. SSmith
  • 770 Answers
Check your lid switch ...on the lid you see a little plunger this should go into a slot areound the rim of the washer and close a switch. you can try a small screwdriver to press it in while in the spin cycle..see if it works then if not the sw will have to be replaced as this needs to be closed (lid) before the unit will pump out and spin
Posted on Feb 23, 2008
Kenmore Top load washer - Model 23922200 Can anyone help me figure out what’s wrong with this washer? It runs all the cycles fine, seems to agitate ok, but when it gets to the spin cycle it won’t spin,...
if you have to push the cloth basket get it to spin then your basket drive is wrong out it need replacing , which you have remove basket an drop the tranmission to washer you can google it by put in your model number an you will see a video on how to do it are just try find you a good uased wasder.
May 20, 2018 | Kenmore Washing Machines
Kenmore Washer 70 series Model #110.22722100 won't spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped.
Feb 25, 2013 | Washing Machines
Kenmore He3 sometimes sound like a jackhammer in spin cycle
Have you tried less items? It could be the load is not balanced. Try placing items around the tub evenly. This unit is about 12 yrs old so it could be a bearing.
May 03, 2017 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Noisy when in spin cycle
This could be the drum baring and probably will need professional engineer to do it.
Jun 01, 2017 | Kenmore 24032\24036 Top Load Washer
I have a kenmore front load washer model 41744052500 the other day i did a load of wash and when i went to the drain cycle it worked fine but whenit went to spin it went right a couple of times then left...
tub was out of balance remove some of the heavier clothing and re spin! and in the future donlt try to run so much through it that are heavier items when they are wet
Jan 12, 2010 | Kenmore Energy Star 44092 Front Load...
The tub on my kenmore model no.44052401 front loader won't turn
Always remember Electricity is dangerous and should be treated with respect.
Please pick a topic of your  problem by clicking ...hope you find this helpful :-)
  1. Automatic dispenser information
  2. How a washer works, good to read this first: Click here
  3. Has Kenmore or Whirlpool ever had a off-balance switch.....
  4. Help for storing an appliance
  5. How does the agitator come off my washer ??
  6. How to prevent socks from getting into your pump
  7. Inglis, Whirlpool and Kenmore belt washers - common problems Like timers, pumping problems, leaking, spinning, agitating and spinning/agitating at the same time.
  8. Inglis, Whirlpool & Kenmore belt drive washers How to take washer apart and how the washer works.
  9. Inglis, Whirlpool & Kenmore style washers which style do I have ?
  10. Inglis, Whirlpool & Kenmore - how to replace the belt
  11. Inglis, Whirlpool & Kenmore - how to tighten the belt
  12. Inglis, Whirlpool and Kenmore - how to replace a pump
  13. Inglis, Whirlpool and Kenmore - how to replace or check the wig/wag solenoid assembly from American appliance
  14. Inglis, Whirlpool & Kenmore - How to remove inner basket
  15. Inglis, Whirlpool, Kenmore belt drive washer - parts breakdowns
  16. Inglis portable washer belt change help From our friend Lee )
  17. Important disclaimer
  18. Missing cycles or timer stalls in middle of cycle
  19. My clothes have a whiting on them that looks like lint.
  20. My washer has a funky odor
  21. Slow water fills
  22. Washer Basics: Filling with water problems
  23. Washer belts: If your belt on any washer looks like this, replace the belt(s).
  24. Washer sample wiring diagrams
  25. Whirlpool newer style apt size newer washer
May 06, 2009 | Kenmore Washing Machines
Kenmore Automatic washer -110.24862300
sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
Sep 02, 2007 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
192 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
