Question about ASUS My Cinema-P7131 (90C1VFV00UAYZ)
The TV picture is flashing
I have recently installed an ASUS P7131. Installation was clean and downloaded the latest drivers. The program found the cable channels (PAL) but the TV broadcast is flashing on the screen. When I capture the captured mpeg2 files play correctly (i.e. without flashing). I suspect some display problems.
This is further corroborated by the Dscale program that gives normal, non-flashing TV reception. FM radio works OK.
Computer:
Gigabyte GA-945GM-S2/Intel PD925 3GHz Dual Core/2 Gb memory
The problem seems to be due to Cyberlink PowerDirector. Most people suggests to remove it from the computer and use other capture programs. This, of course, does not explain the stuttering display of the TV channels on a Plug-and-Play LCD monitor.
Posted on Feb 25, 2008
Latest asus motherboard drivers to play angry birds
Hello, you can download the vga driver here:
http://support.asus.com/download.aspx?SLanguage=en&p=1&m=P4VP-MX&hashedid=h2IybiXlhuhUUW38
Select vga and click on global for downloading the driver.
You have to unzip the file before installation.
You maybe need to install these to programs also:
http://www.java.com/en/download/index.jsp
http://get.adobe.com/flashplayer/
Oct 11, 2011 | ASUS P4VP-MX Motherboard
My Cinema-P7131 is not responding. I have win xp sp3.
Your P7131 may not be responding because it is not enabled. To check if is recognized and enabled check in "Device Manager" by doing the follwing. Click on "start", lower left of your screen. Find "control panel" and click on that to open. In your list, or icons, find "Device Manager". Right click on that and open, click on "continue". Ciick on box with + next to "idisplay adaptors". You will see a drop down and, should see Asus or tv tuner. Right click on that and you will see in the box, "enable" or "disable".if you see enable, click on that and you know your tv tuner is recognized and enabled.
If you need drivers you can get them here;
http://support.asus.com/download/Download.aspx?SLanguage=en-us
1 Select product-click on arrow at right of window, scroll to "multimedia" and click on to select.
2 Select series- click on arrow at right, scroll to "TV TUNER" and click on to select.
3 Select models-click on arrow at right, scroll to "My cinema 7131" and click on to select.
Click search. A window will pop up "enter your o/s". Click on the arrow on right and select Win XP or Win XP 64 bit, depeneding on what you have, and click search. This will bring up your download. Usually the top most driver is the most current. Click on your download and run.
You will notice there are three choices under select models. If P7131 is your complete model # then you have the right download.
Mar 23, 2011 | ASUS My Cinema-P7131 (MY CINEMA-P7131/MCE)...
Download free Drivers for ASUS P7131 TVFM for Windows 7
~To download the manufacturers and therefore correct drivers or specific software;
Always get your drivers from the manufacturer of your Laptop, Notebook or Desktop.
If you were to log on to the manufacturer's web site, usually one is able to download if available, by model number, All available Driver downloads as required.
If the driver is not available, perhaps your manufacturer does not support the OS you are installing.
This is the best way of ensuring up to date drivers for your system and they are free of charge!
There are no XP drivers to be found with Microsoft as XP is no longer supported.
Some manufacturers may have a limited number of Drivers still listed.
I hope this helps.
Feb 16, 2011 | Televison & Video
Install the card but to install the driver leaves a message saying the driver is not supported I have windows vista sp1
Go to the main website of your product, you have asus, i have 4650 his HD radeon went to main amd site and got all drivers up to date. but you could try the amd site for yours too.
Feb 15, 2011 | ASUS My Cinema-P7131 (90C1VFV00UAYZ)
I reinstalled Windows xp and then ran the Asus sis 661fx serious cd for hardware configuration which all went well but ever since I've been getting a bubble note that a pci simple communications controller...
You can go at Asus support Website to get the latest drivers what you wish to need. You need get the bubble note because hardware driver is not installed properly. I recommended you to go at: http://support.asus.com/download/download.aspx?SLanguage=en-us . Search your asus model and simply download the latest driver. This will fix your issue. Hope it help for you.
Jun 19, 2010 | Computers & Internet
M2N-SLI with Raid and Vista
Hi Eric,
You need 2 hard drives to create a RAID! (Read this).
http://en.wikipedia.org/wiki/Redundant_array_of_independent_disks
Download from Asus the latest RAID driver software for Vista.
M2N-E SLI motheboard.
http://support.asus.com/download/download.aspx?modelname=M2N-E%20SLI&SLanguage=en-us
Hope you find this helpful Eric!
List any troubles or questions....
Mike
Jul 19, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Asus
Download ASUS Update V7.06.02 Install Program for XP before trying to flash your bios.
Download here.
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=A8N-SLI%20Deluxe&type=map&mapindex=1
Jan 05, 2008 | ASUS A8N32-SLI Deluxe Motherboard
Tuning via media center
Just to verify, you're saying it picks up some channels but not all, correct?
Aug 31, 2006 | ASUS My Cinema-P7131 (90C1VFV00UAYZ)
ASUS My Cinema-P7131 (90C1VFV00UAYZ) Logo
370 people viewed this question
Top ASUS Televison & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Michael Galve
Michael Galve
David Payne
David Payne
Are you an ASUS Televison and Video Expert? Answer questions, earn points and help others
