Question about Kodak EasyShare C743 Digital Camera
How to replace battery door cover
I have the new battery door but can't figure out how to replace it. I have removed several screws, but don't want to pull it apart. Any help would be appreciated
    Problem Solver:
  • 4 Answers
To replace the battery door you will need to disassemble the camera. remove the six screws (#0 phillips) on the sides and the bottom, two per side. make sure the batteries are removed and the door is open, whats left of it anyway. slip the front of the camera off, you might need a small flat screw driver to help separate the halves. with the front off remove the screw just above the view finder and the one by the battery compartment in the corner. now pry the back off, start with the side by the lens. the usb jack will not let you slip the back straight off so you will have to pry the lens side down a bit and then push it toward usb jack. with the back off you can remove the remains of the broken door by sliding the pin toward the negative symbol on the camera, watch for the spring. reassemble in the reverse order. when putting the back on slip the usb jack into its hole and make sure that it is not pushing against the inside of the case.
Posted on May 23, 2009
I have a Kenmore microwave, model 721.62649200. The Handle to the door just broke off. I can find places online to buy a new handle, but I can't for the life of me figure out how to take the door...
I have a similar unit and I removed the outside of the door by loosening two flat head screws on the narrow where the handle is located. There are several screws yet holding the outside plastic housing too. Once these are removed the plastic door will come off. Then the handle will be accessible.
The same issue started with my oven too and I replaced the original handle with larger screws and using a high quality plastic glue.
This held for a while. The plastic door cover seemed to have changed dimensions during its life and warped. I ordered a new door and it lasted a short while. I then asked for a new door under warranty.
Bottom line they wouldn't sent a new cover but they returned my money. Apparently the doors all had crappy plastic issues. Currently we are using the microwave with out the door front. It still works like new after 10 years though.
Nov 12, 2012 | Kenmore 62622 Microwave Oven
Driver side mirror replacement
Instructions1.
    • 1
Remove thedoor panel. Refer to your Honda Accord repair manual for theinstructions in removing the door panel. Unhook the rods and connectors on theinside of the door panel and set it on the floor.
    • 2
Remove thefilm covering the access to the side mirror. It's difficult to avoid damaging thefilm while removing it so you will need to purchase a new piece of filmcovering when you buy a new side view mirror.
    • 3
Reachthrough the service hole into the mirror housing with a screwdriver. Loosen thescrew that holds the mirror. Twist the screw out with your hand.
    • 4
Reacharound the door and support the mirror with your other hand. Continue to twistthe screw out, then catch the mirror as it drops out when you remove the screwcompletely. Put the screw in a safe place so you don't lose it.
    • 5
Installthe new side view mirror by positioning it where the old mirror was. Insert thescrew you took out in Step 4 and twist it in with your hand. Insert ascrewdriver into the service hole to tighten the screw.
    • 6
Replacethe film covering that was damaged when you took out the old mirror. Push itinto place in the indentation on the door.
    • 7
Sit in thecar seat and adjust the mirror so you can use it properly.
Jul 06, 2012 | 2005 Honda Accord
Replace front speakers
You would have to open the door panel to replace front speakers. Look for any screws around the door handle. look at the whole door panel for any screws so that you may remove the panel in order to reach the speakers. once the panel is free from any visible screws, use a door panel remover ($5-10) and use it to pry off the panel, use it around the door panel push-in connectors, and don't use extreme force, may break connectors. once the connectors around the whole panel are removed. make sure your window is down before the whole procedure. then pick up the panel from the bottom (push up), then the panel should be off the door, if you want to change the speakers, you don't need to take any of the wiring to the window/door lock. simply remove the cover if any over the stock speakers, usually some screws. once the cover/screws are off. the speaker should come off. You will see two wires off the speakers (the red(positive) the black(negative)), once the stock speaker is removed, simply attatch the new speaker to the wires. make sure the negative and positive from the car DO NOT TOUCH, you WILL short circuit and blow a fuse, maybe worse, and it's not worth the time fixing. hope this helps, good luck.
Jun 12, 2011 | 2004 Volkswagen Beetle
Need to know how to change batteries, I have ten properties with schlage keyless enties
It depends a bit on the lock and how it was installed.
For the Home locks with a panel on the interior of the door, remove two screws and take off the inside cover. These screws can be at the top and bottom or through the plate of the interior door handle. Then remove the 9V battery and install a new one. Put the cover back on and replace the handle, if needed, and the screws. (Do not use a cordless screwdiver - you could overtighten and strip the threads.)
Other installations have the battery inside the panel with the keypad on the exterior of the door. To access the battery compartment, you need to remove the interior door handle or lock. Then pull the keypad section out of the door. The 9V battery will be behind a coverplate on the back of the unit. This cover needs to be pivoted downwards to open the compartment.
The Schlage commercial offline locks (no computer monitoring) use AA alkaline batteries (4 or 8) in a block. The eight battery version has 4 batteries on each side of the block. These are all on the inside of the door. Remove one screw to get the cover off. Then remove two screws to get the battery holder off (this keeps the batteries from coming loose in the block). Replace all of the batteries and resecure both the battery holder and the cover panel.
For the consumer Schlage Locks manuals, see http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx . For information on the Schlage commercial locks. see http://commercial.schlage.com/electronicsecurity.asp . The manuals are available in the Technical Library for each lock type.
I hope this helps.
Nov 20, 2010 | Schlage Locks & Locksmithing
How i can mount a new battery cover on Olympus SP-560 UZ
i just purchased a new cover for $33 from uscamera. part#omp vg4293. You will need a jewlers philips screw driver. Make sure you lay out screws where they came out. They're different. Looking at the bottom,Remove 1 screw under battery door. Two screws on bottom my mount. Open little door on left for mem card and remove 2 screws. Open little door on right side where cable goes, remove 2 screws. Then gently on end wher door goes, pull back cover back just enough to remove old door and reinstall new door. Press back together and install screws.
Jun 18, 2010 | Olympus SP-560 UZ Digital Camera
How do I remove the CD/DVD hardware drive from Aspire 5520 laptop ..i want to replace it with a new one...where do i start first?
It will slide out once you unscrew one set screw. Flip over the Laptop and you will see several small screws. Gauge which one by figuring about 5.5 inches long from the edge of the front of the CD Rom and normally it is the middle or off just one inch either way.
If you try several screws it wont disrupt anything... just put them back of course.
Press firm while unscrewing...don't chance stripping and have the right size screw driver :)
Jan 24, 2010 | Acer Aspire 5520-5156 Laptop
Remove/replacing side view mirror on a jeep grand cherokee
    Remove the Old Mirror
  1. Step 1 Disconnect the negative battery cable before you take off the grand Cherokee front door trim panel. Remove all screws and clips.
  2. Step 2 Detachthe window trim cover screw, and control lever screw beforedisconnecting the entire mirror trim cover. Remove the rubber coverinside the mirror cover, and disconnect the electrical wire.
  3. Step 3 Remove three nuts from the power mirror using a Torx® star-shaped screwdriver.
  4. Step 4 Pull out the outside rear view mirror. Guide the power wire through the hole in the door.
  5. Install the New Mirror
  6. Step 1 Replace the old mirror. Put the new power mirror in place. Push the new wiring through the hole in the door.
  7. Step 2 Install and tighten the three retaining screws you took off when removing the old mirror.
  8. Step 3 Connect the power mirror wiring to the connection located on the door panel. Replace the rubber cover and interior mirror cover.
  9. Step 4 Put the front door trim panel back in place by securing all clips and tightening all screws.
  10. Step 5 Connect the Subaru Outback's battery cable to restore the power.
i will recommend i site where you will get all the information you need to remove and replace your side mirror
http://www.wjjeeps.com/mirrors.htm
Sep 10, 2009 | 2004 Jeep Grand Cherokee
Battery Door
remove two small phillips head screws next to battery compartment,,this will allow you to raise the camera case enough to insert the tabs from the new battery door cover,replace the screws,,,i just replaced mine not to difficult
Jul 15, 2008 | Kodak EasyShare CX4200 Digital Camera
How to replace battery door?
I just replaced my battery door. You have to take every screw out of the camera. I used a philips eye glass screw driver. Then, pull the front and back covers apart carefully, its only plastic. There is a pin that holds the door to the rear cover. If you push the battery door button back and fourth the pin will start to show out the side of the camera. I pulled it out once it showed with small pair of needle nose pliers. Just reverse the procedure to install the new door.
Dec 12, 2006 | Canon PowerShot A20 Digital Camera
Replacement Battery Cover Assembly
If you're handy, you can replace it in about 3 minutes. Don't attempt it unless you're willing to risk tearing a thin flexible circuit under the rear cover. Looking at the camera from the rear, remove the screws on the right hand side ( 2 ? ) then the screws across the bottom - open the card door, remove the card, and wedge a knife blade between the front and rear cover halves - the card door will be loose with an attached spring coming free. No need to remove the rear housing completely, just enough to expose the tracks for the battery cover hinge. Remove the old door, noting the position of the opening spring at the hinge, by angling one hinge out first. Insert the new battery cover and the card door in reverse order.
Dec 05, 2006 | Kodak EasyShare CX7430 Digital Camera
Kodak EasyShare C743 Digital Camera Logo
117 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
