Question about Maytag Admiral Top-Freezer Refrigerator
Freezer portion doesn't freeze.
I have an Admiral Refrigreator/Freezer (top) model HMG 19145. The refrigerator works fine, however, the freezer has quit (doesn't freeze food). I assume that if the frig still works, it must be related to the freezer componet (temp selector ?) Is it fixable or will it be less expenseivve to replace the appliance?
  • 572 Answers
Check settings. if good check if compresor is running. a relay on compresor could fail
Posted on Feb 10, 2010
SOURCE:
My admiral model hmg-64184 is leaking water from the bottom of freezer
It sounds like you have a broken place in the door gasket that is allowing warm air to enter the freezer.
May 29, 2015 | Admiral 26 cu. ft. Side-By-Side...
Admiral- Model HMG 19153 Freezer is cold, but doesn't freeze What's the problem?
Is it set at max? Try switching to fast freeze. it bypasses the thermostat and may help find if it is faulty
Mar 27, 2012 | Refrigerators
Admiral / HMG 23173 / 10690324HQ. Motor running. Freezer cooling but not freezing. Refrigerator cool - not cold. Not sure age of refrigerator. Internet says 1964 or 1988 - so probably 88 since house...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 06, 2011 | Admiral Refrigerators
My Admiral freezer is cold but not freezing. The fridge seems fine but food in the freezer is thawing.
See if the coil is clean, if not, vacuum and brush the coil clean.
That should make diagnosis much easier.
Jan 09, 2011 | Maytag Admiral Top-Freezer Refrigerator
Admiral ATF1910DRW refrigerator. The refrigerator
hi there,
there seems to be a technical error. call your repairman to have him take a look at the inside wiring before your food gets spoiled even more.
Jun 11, 2010 | Refrigerators
Feezer seems like it defrosts too long and ice cubes become wet, ice cream gets very soft, then they refreeze fine. thermometer shows 25 degrees above zero when it is happening. ADMIRAL MODEL HMG 19145, 15...
well its gone wrong now? 25 degrees "above zero?" wow,,, thats cooking!!!! lets be honest,, its 15 years old? its about time you invested in a new freezer you have had your moneys worth out of this one,, and it will cost you more than its worth to fix it up, it realy is time you treeted yourself,, get a new one!
Nov 17, 2009 | Refrigerators
Admiral refrigeration not freezing not cooling
This could be a defrost problem or fan not working all time when compressor is working. What is your model number so I can see what components your model has and then solve your refrigerator problem. Need you to answer so we can get you running, Sea Breeze
Oct 23, 2009 | Maytag Admiral Top-Freezer Refrigerator
Ice/Water dispenser not working correctly
hi,,
it is a thermostat problem,,because of it heating is not done properly ..u should replace or fix it,,it is not a big amount....
thank u,,,
Jul 01, 2009 | Admiral 26 cu. ft. Side-By-Side...
Maytag Admiral Top-Freezer Refrigerator Logo
339 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
