Question about Mitsubishi VS-50605 50" Rear Projection Television
DEAD TV TV is either dead with power surge at plug in or power led lights and goes out. TV makes click noise like it is powering up but does not. When I can read an error code it reads a 12 code which is no error. Where is the ground point when checking IC951. I'm a little rusty. It has been at least 20 years since the last time I repaired a TV. Any detailed help you could give would be great. THANKS REDCAT55
  • Mitsubishi Master
  • 8,617 Answers
Look for 2 resistors off of pin 2 of IC951 R955 & 956 they are hooked in parralell and the tail end of those resistors are grounded.
Posted on Feb 23, 2008
How to reset tv
hi Tracie,
is the set making a clicking noise?
is the power light flashing on the front?
or no power light at all just dead?
if the set is just dead, just put your ear to the back vents can you hear like a very faint screaming noise and can you smell and burning in the vent?
if so it just could be capacitors on the power board.
if its clicking the that will need a service kit on the power supply board.
if the power led is flashing then you will need to count how many flashers from start to finish when you first turn set on.
hope this helps.
Panasonic TH 42PX75 80 TH C42hD18 Dead TV Repair Fix TXN P1XGTUS HNTUS... Panasonic TV Won Turn On Learn How to Replace Your Power Supply FIX Panasonic Viera 42 inch Plasma SU BOARD TH 42PX75U Diagnosis Repair...
Jun 20, 2014 | Panasonic "Viera Tc P65 Gt30 65"" Class 3...
Spot of bad weather here, just had a power surge in the house and now our tv (sharp lc-42SB48UT) won't power on. There is no blue or red light on the front and changing outlets/surge protectors doesn't...
90% to 95% ur tv have a dead power supply board only.5% ur tv could have both dead boards the tv power supply board and the main tv Tuner signal board too.The tv power supply board.That the board,where the power a/c cord plug into it.The tv main Tuner signal board,that the board where all the exstented devices and the tv incomming broadcasting signal cable wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement first.The tv problems should be fixed.If not than the main tv Tuner signal board is dead too.Must be replaced also.
Apr 24, 2011 | Sharp LC42SB48UT 42 in. LCD TV
My philips ambilight wont switch on i can hear clicking noise and red standby light keeps flashing any ideas
U have tools like a soldering iron,desoldering pump or roll of desoldering braids,a roll of solders and understanding basic electronic also can do basic soldering?This problems,most of the times are causes by those dying soon to be dead components call capacitors on the power supply board.Yes,take ur tv aparts,the power supply board,that the board,where the power a/c cord plug into it.Check the power supply board for those dying soon to be dead capacitors parts,it alway bulges up on it tops or puffing up on it tops.Replaced these dying soon to be dead capacitors parts,will solved ur tv noises clickings,power LED light indicator will stop flashing.Tv will power up normal again an work.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 20, 2010 | Philips 32PFL7332D 32 in. LCD HDTV
HAD A POWER SURGE NOW MY TV WONT POWER ON
The tv power LED light now totally dead or power LED light indication flases?The tv power supply board is dead.That the board,where the power a/c cord plug into it.Tries website like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 11, 2010 | Sceptre X23BV-Naga 23 in. LCD TV
We can't turn on the TV. We[ve tried the remote & manual controls & have unplugged it & plugged it back in using both the surge protector and wall outlets to no avail... Any suggestions?
The power LED indication light flashes or totally dead?The power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacemrnt.
Oct 17, 2010 | Olevia LT42HVi 42 in. LCD Television
Whenever i plug the unit in i hear a clicking sound from the back of the television it is for about 3 seconds and it usually takes 2-5 seconds before it starts the noise. The power light only comes on for...
Ur tv turn on now,hear alot of clicking?The tv LED light "lamp" on front panel flashes or light up?The tv projection lamp is dead.The Ballast board dead too,if hear alot of clicking?The ballast board help to ignite the projection lamp.
Jul 16, 2010 | JVC AV-56P575 56" Rear Projection...
I possibly had a surge on my Element FLX-3711B Tv. It was also connected to a sony surround sound station. The sont was off for a while but reset it self after awhile and now works fine. My TV has not...
Tv now have LED indication power light on the screen panel blinking light or totally dead,no light at all?The power supply board,that the board where the power a/c cord plug into it.That the power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jul 16, 2010 | Element Electronics FLX3711B 37 in. LCD TV
TV won't turn on, red light flashes on TV and hear a clicking sound in back of unit is it worth fixing?
Yes,the LED power lite on the front panel stable?Yes,mean the DM power supply board is good.LED power like blinking,mean the DM power supply board is dead.DM power supply is good,still making that clicking sound,when turn on.Mean ur Blast board is dead,that the board that help to light up the projection lamp.
Jun 24, 2010 | Hitachi 43UWX10B 43" Rear Projection...
No power on TV - JVC LT-47X788 47 in. HDTV LCD
Power supply board is dead.U have a LED light indicator on LCD panel flashing?The tv is completely dead,no LED light at all?Tries Website like Shopjimmy.com.Ebay.com to buy a refurbish power supply for the replacement.
May 07, 2010 | JVC LT-47X788 47 in. LCD HDTV
My tv made a popping noise and then shut off wont
Power Supply Board is dead.Replaced the power supply board will solved this problems.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 19, 2010 | Televison & Video
Mitsubishi VS-50605 50" Rear Projection Television Logo
49 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
