Question about Kenwood KDC-519 CD Player
Kenwood KDC-519 Faceplate Problem
None of the lights on the faceplate work or light up ...all the functions work properly. I can listen to the radio and CDs, even the faceplate flips over when keyed off.
I seen the post where another individual was having the same problem, and it was suggested to replace the ribbon cable. However, I noticed the other day when I was changing a CD, that when you press the button and the faceplate rotates down in order to insert a CD, all the lights on the face work like they are supposed to, but once you insert a CD and faceplate closes again, all the lights go out on the face.
I've tried pressing the reset button, but the only thing that done was cause me to lose all my settings (bass, treble, radio presets, etc.), and without any lighting on the faceplate, I can't see how to reset any of the settings.
Would this also be a ribbon cable problem, and if so, why will the lights work fine when the faceplate is open, but when closed there's no lights?
Is something shorting out or something?
Any help would be most appreciated!
Thanks!!
  • Blakrayn Feb 26, 2008
    After reading over several other posts from individuals that are not only having a similar problem occuring once, but twice; I've decided to purchase a new and entirely different headunit ...one without a flip-over faceplate that is.
    Thanks for the advice!
It is a ribbon problem its not really worth fixing unless u love the radio it cost about 50 bucks to fix
Posted on Apr 24, 2008
  • 43 Answers
Detach the faceplate and look at the electrical contacts on the back of it for damage/dirt - you can spray it with electrical contact cleaner. Do the same to the contacts on the head unit - it sounds to me like one or more of them are a bit loose or otherwise not working properly.
Posted on Feb 24, 2008
Need to get the security code for Kenwood KDC-608OR
ok I just found this info online and they say it came from the service manual for that stereo so I hope it helps:
You will need a Kenwood RC-410 remote control. This remote works on KDC-519, KDC-X859, KDC-319, KDC-4019, KDC-MP919, KDC-X759, KDC-419, KDC-X459, KDC-MPV619, KDC-MPV7019, KDC-2022, KDC-2022V, KRC-435, KRC-535 and KDC-X959
To reset the code do the following:
1) Turn on the car.
2) The faceplate rotates out and the CODE - - - - prompt appears.
3) Press >>' and Auto keys simultaneously on the faceplate and hold for 4 seconds. (If the faceplate rotates back into the console push on the upper left top edge of the faceplate and it will flip back around. Press the Eject button and then try it again.)
4) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>' key on the faceplate.
5) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>' key on the faceplate.
6) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>' key on the faceplate.
7) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>' key on the faceplate.
8) The radio goes into All Off mode and you are set! Hit the SRC button on the faceplate to select CD, Radio, etc.
Above information source = http://techbybucky.blogspot.com/2008/01/how-to-reset-security-code-on-kenwood.html
Jun 19, 2011 | Kenwood Car Audio & Video
Nothing works plese help !!!!
try the menu button , holding the fm/am button basically it is waiting for you to hit the security code correctly
Apr 10, 2009 | Kenwood KDC-519 CD Player
Kenwood KDC-MPV 7019 code
Kenwood Code reset for KDC-MPV7019: (remote required)
1) Turn on the car.
3) Press >>| and Auto keys simultaneously on the faceplate and hold for 4 seconds. (If the faceplate rotates back into the console push on the upper left top edge of the faceplate and it will flip back around. Press the Eject button and then try it again.)
4) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>| key on the faceplate.
5) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>| key on the faceplate.
6) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>| key on the faceplate.
7) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>| key on the faceplate.
MANUAL for the same radio
Jan 15, 2009 | Kenwood KDC-MPV7019 CD Player
Need to reset the code for a kenwood kdc-mpv7019
If You Have The Remote Here Is Your Solution.
1) Turn on the car.
Thank You For Using Fixya.com Please Don't Forget To Rate My Answer
Jan 08, 2009 | Kenwood KDC-MPV7019 CD Player
No power to Kenwood KDC-4019 faceplate
It sounds like the stereo does not have the "ACC" voltage. It could have blown a fuse. The "ACC" voltage goes to the red wire on the harness and you get that voltage turned on only when the ignition is turned on in the car.
The symptom of the disc ejecting and nothing else works is an indication that only the constant voltage for the yellow wire is connected. Check the voltage on the red wire with the car turned on, if you have that 12 volts at the red wire, then you need the radio serviced.
It is not very likely that the faceplate has gone bad. Just because the radio will not turn on is not an indication that the faceplate is bad. It could be a voltage regulator in the radio or a circuit trace is blown, or almost anything else. There are many reasons that the radio would have the problems you describe and it can only be found out for certain by troubleshooting the radio on a test bench with the proper tools. If you have a multimeter and a power supply I can guide you thru troubleshooting the radio and even email you the service manual in PDF format if you would like to take a crack at it yourself.
Let me know how you want to proceed.
Dave
Oct 25, 2008 | Kenwood KDC-4019 CD Player
Kenwood KDC-MP2035 security code
yo tengo un reproductor kenwood kdc-mp2035cr pero este no me reproduce nada solo me sale un mensaje que dice protect y no me deja hacer nada ni colocarle nada por el auxiliar
Jun 05, 2008 | Kenwood KDC-MP2035 CD Player
Kenwood excelon kdc-x815 display screen no power
recently bought a kenwood kdc-815 car radio from a swamp met. bought it with no security code need security code
Apr 08, 2008 | Kenwood KDC -X815
No response from the KDC-519
I once had the same problem and took it in to have it looked at! The guy simply pushed in the small black button to the left of the ATT button and it reset!
Hope that helps!
Sep 04, 2007 | Kenwood KDC-519 CD Player
Kenwood kdc-322 faceplate problem?
I found my Kenwood KDC322 faceplate doing the same thing(cutting out) I cleaned the contact points on this 'ribbon' behind the faceplate by rubbing the discoloration off with a pencil eraser. The lights have not cut out again.
Apr 04, 2007 | Kenwood KDC-322 CD Player
Dead Kenwood KDC-128 CD Player Is there a "reset"
KENWOOD MADE TWO DIFFERENT EDITION FOR THIS AND SOME OTHER MODELS. YOUR WILL NEED TO CHECK THE SERIAL NUMBER AND YOU CAN CHECK WITH PACPARTS AT pacparts.com THEY WILL GET THE RIGHT ONE FOR YOU
Dec 13, 2006 | Kenwood KDC-128 CD Player
Kenwood KDC-519 CD Player Logo
512 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
