Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Panasonic PT 50LC14 problem
When you push the power button the power button light goes green for just a couple of seconds and then starts flashing yellow ( in a sequence of two flashes). And thats all it does. What does the flashing code mean? I've already put in a new lamp in hopes that would fix the problem.
  • no help Mar 02, 2008
    Mine flashes green and then goes back to red and the fan continues to run but no picture. I have also changed the bulb. I was told that I need a power supply. I can't locate one.
  • Anonymous May 12, 2008
    The power supply for the lamp is called the "ballast". Most likely, this is what needs to be replaced. Cost $425-450 including labor.
You have to close the lamp door. It has a switch in it much like a clothes dryer door in that when it is open it wont operate.
Posted on Jun 29, 2009
Where can I get the cheapest price for the lamp and ballast for Panasonic
PT50LC14?
AnyOne please
Posted on Nov 16, 2008
How do I change lamp T Y L A 1000
Posted on Dec 11, 2008
The manual has all indicators laid out.. two orange flashes means the lamp cover is unsecure, 1 flash means the cooling fan is not working
Posted on May 02, 2008
I also get the same yellow flashing light in sets of two after replacing the bulb. No lights, no picture, nothing. What the heck....
Posted on Mar 06, 2008
No help, did you ever get your issue fixed. mine just started doing that last night. Flash green then jumps back to red and fans continues to run.
Posted on Mar 16, 2008
3 Suggested Answers
SOURCE: Panasonic pt-50lc14 lamp needs replaced.
You will find this very easy. Take the front panel off. It just pops off. Two screws..one on the out side door and one inside the door. You can do it from there. Oh yea put the back of the Tv back together....lmao.
Posted on Jun 02, 2009
johnnydiode
  • 647 Answers
SOURCE: Lamp reset on a panasonic model pt-50lc14-k
This works for mos Panasonics
Turn on Power
Pres and hold the "vol-" button on the front of unit and the "split" key on the remote together for over 5sec.
Screen should say " Lamp time was reset to 0"
Posted on Nov 12, 2009
When i push the power button on my nikon coolpix L5 the lens comes out and the screen flashes on then off
sounds like grit in the lens mechanism..... but is it worth enough to get it serviced?
Apr 17, 2014 | Nikon COOLPIX L5 Digital Camera
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
My panasonic pt-50lc14 turns off the power light flashes red and temperature light flashes.
Examine the lamp first and be aware the model 50lc13 and 50lc14 which are almost identical had all sorts of problems----the lc13 was part of a massive recall/exchange that cost Panasonic tens of millions of dollars.
could be lamp or even the ballast which was the real issue involved in the recall.
Aug 27, 2012 | Panasonic PT-50LC14 50" Rear Projection...
Green light is blinking --says clean when you push
Hello & Welcome to FixYa
Flashing green light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jun 10, 2011 | Kenmore 16764 Dishwasher
After pressing the on button it turns green for 5 seconds then it flashes yellow/orange for a second then it flashes red.
Yellow Light of DeathThe "Yellow Light of Death" or YLOD is the common phrase people use to describe the following sequence when they try to turn on their PS3:
  • Press Power Button
  • Red Light Flashes Three Times
  • Yellow Light Flashes
  • Green Light Flashes
  • Beeps Three Times
  • Red Light Flashes
The sequence above may vary a bit but you do see the flashing yellow light (sometimes shows up as orange) that normally you would not see when operating your PS3. The YLOD is a general hardware fault that can mean a lot of things. However, one of the problems is cracked solder that leads the PS3 to think one of its internal chips is not connected or is broken somehow. Cracked solder can happen when the chips get too hot (RSX most likely) and leads the motherboard to start bending, which may crack the solder. Changing the power supply (lower the average wattage going to the chips to lower the heat) and better thermal compound (heat dissipates faster to the heatsink) may prevent this error from occurring. However, if your PS3 has already had the YLOD, then you can reflow your motherboard every few months to keep it working (but it is not a permanent fix as the YLOD usually comes back).
Oct 09, 2010 | Sony Playstation 3 (PS3) Console
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
1,741 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
