Question about Dell Dimension 3100 PC Desktop
Imstalling internal card reader
I want to know how to install an internal card reader because my motherboard doesn't have a slot for it.
    President:
  • 2,351 Answers
Hi jmarie, If you have the standared Dimension 3100 it did not come with a floppy drive. If so you can buy a Sabrent Internal 64-in-1 Multi Flash Media Card Reader - USB 2.0, Black, 3.5", Self Powered, SDHC Support, Vista ready reader that fits in your emty floppy drive. http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1871218&CatId=962
Your dell does not have a free 5-pin male USB connector on the motherboard. So you'll also need a Sabrent SBT-FWPH USB 2.0/Firewire 1394 8 Ports PCI Card Internal Combo Hub.
Included, Free Standard Shipping. Here: http://www.meritline.com/3-port-firewire-5-port-usb-2-0-combo-pci-card.html
The card reader will plug into the internal USB 2.0 Sabrent. You will gain four USB plugs & two 1394 plugs. Once you see the pictures you will understand. Bottom line everything will be inside the PC.
Or you can use the external as computafixa suggested for half the cost. Click the link to see:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3603298&body=MAIN#detailspecs
It's up too you jmarie!
Posted on Feb 23, 2008
    Sergeant:
    Champion:
  • 317 Answers
Well, installing an internal card reader without a spot on the motherboard, is a little hard to do. I would suggest buying an external card reader. They are a little cheaper, and a lot easier to setup and use, since they just connect to a USB port which all computers have.
3.0 doesn't work
motherboard has to have usb 3 too
Apr 13, 2014 | Rosewill RDCR-11004 5.25" Internal Card...
I have a PNY usb 2.0 combo. The usb ports work fine and read external drives etc. The SD readers quit working. The SD cards read fine on the internal mounted reader. My PC recognizes the drives, and t
I bought a deer cam (trail camera) at Walmart and a PNY card with PNY Multi-Slot USB & Flash Card Reader P-UBSDRDR21K-RF. I can't make them all work for me. PNY card reader has no instructions on the package neither on their website and their support is a joke. When I plug in this multi-slot card reader into my PC (I tried two different PCs) something isn't right. I get no results, just empty folders. The card is new and has data on it. Both products come from PNY, both were purchased at Walmart and both are going back to Walmart for a full refund and I will never buy a PNY product ever again.
Feb 14, 2013 | PNY Memory Card Reader and USB Hub Combo
Is there and sd card slot anywhere????
I believe SD card readers plug into the usb, the sd card then plugs into the reader to read.
A permanent sd card slot can be installed in the small floppy disc tray and plugged into the mobo.
But the sd usb option is bone cheap.
http://www.interweb.in/pc-news/15420-sd-card-reader.html
http://www.thinktechno.com/2008/02/28/62-in-1-usb-internal-multi-card-reader/
May 15, 2011 | Computers & Internet
I would like to install a internal card reader with a usb port.
Those wires go into an internal USB extension connector - which your motherboard doesn't have. Get a PCI USB card and connect them to it - this way you will also get USB2.
Mar 10, 2010 | Chaintech CT-6OJV2 Motherboard
Card reader on MSI A6000 doesn't reconize card
Try different cards in the slot, if none of the cards are being recognized then go into the device manager and make sure the card slot drivers are intstalled, if you see something that says pci base device then that means the drivers are not installed.
In that case you need to install the drivers for it. If after you install the drivers the slot still doesn't work then that means the slot is bad and since its built onto the motherboard the motherboard needs to be replaced.
Dec 17, 2009 | ASUS Computers & Internet
My SD card reader on my Sony Vaio will not read the card...it seems to know its in the slot, but won't read any data and says 'insert the SD card' if I go to computer and try to read it. Any thoughts?
Take a can of air and blow some into the slot to make sure dust or dirt isn't getting the way of that reader trying to read the sd cards.
If you still get the same message try another SD card in that reader or try to see if another computer will read your SD card, if another computer will read the SD card and the slot still won't recognize the sd cards properly, then you know at that point the reader is bad. If the reader is bad, thats integrated into the motherboard so the motherboard would need to be replaced.
Nov 30, 2009 | Acer Aspire 5610-4648 Notebook
Install internal mini-pci wireless card,dell inspiron 5100 laptop
open bottom of laptop where ram and cpu is located usully in middle 2/3 screws there should be a slot arouns an inch long on board that this slots into however does your laptop have the wireless cables that run from motherboard to hinges that hold screen in place usually black1 and grey 1 which are main and aux grey is usually main
Oct 02, 2009 | Dell Inspiron 5100 Notebook
Trying too install 4in1 card reader
If its an internal card reader, you should install it in the PCI slot. If it's an external card reader you should plug the card reader into the USB port. I need to know the brand and model of the reader so that I can give you more precise instructions.
Sai.
Mar 01, 2009 | IBM Computers & Internet
Addinga card reader to an ASUS M2V m/board
Install a PCI usb card to give you the USB connectors.
Feb 16, 2009 | ASUS M2V Motherboard
Multi card reader fault after re-boot?
I have a akasa internal 3.5 card reader, 4 slots and a usb port, no fans. Installed ok and worked one time then dissappeared in my computer and device manager.
Looking at the plug it had a wire in where a dummy connector on the motherboard connects. Took the cover off the card reader and looked at the other end and on that connectot no wire. Reversed the lead and all up and running. No Quality assurance any more!
Oct 11, 2008 | Computers & Internet
Dell Dimension 3100 PC Desktop Logo
381 people viewed this question
Alun Cox
