Question about Cobra 25 LTD 40-Channels Base CB Radio
Radio issues i have a galexy 99v and when i put it in my truck it only keys 4 watts. when i put it in my house it keys 8 swings 15. i took it to a cb shop and had it tuned. i was told that it was doing 30+ watts. i have ppl telling me that radio will not do any more then 8 watts but i have seen diffferent on a meter Can any one help me plzzz?????
Your getting different readings because the S.W.R is not the same in the car as to the house. If you placed a 50 ohm dumb load on ANT outlet the readings will be similar.
Posted on Jul 06, 2008
  • 3 Answers
Unless your using a Bird Wattmeter with proper frequency plugs your not seeing a true reading of power output. The radio manufacture presets the power output to a max. of 5 watts.
Posted on Feb 23, 2008
Had my 99v peaked & tuned swing kit recevies real good want talk very far has static when transmitting already changed mic
Have it bench tested on the bench with a dummy load as any decent shop can tell if outgoing power and modulation have a issue.
Aug 28, 2012 | Galaxy Radios DX-99V 40-Channels Base CB...
My 99 dose not rech out very far i need to tune it up how do you pick and tune it do you have a diagram to show how to tune it
Take off the cover, and hook it back up to antenna, and power, set it on AM mode, mike gain at minimum, RF power to HI, connect watt-meter to ant. out-put, adjust VR13, key the mike adjust it for 8-10 watts, do not go any higher than that because you will damage the transistors...Then replace cover and enjoy....hope this helps.....
May 20, 2010 | Galaxy Radios DX-99V 40-Channels Base CB...
I have a cobra 200 gtl dx and some one make modification on it to get more power and more modulation but i see in my books the modification to raise up on the board in front of my cb tell me to raise up...
you do not do it by resistance. To turn up the radio it is a variable resistor. What you do is connect a watt meter that can read PEAK or PEP watts AND AVERAGE or dead key watts.
First you check it on avg watts. Hook the radio up in line with the watt meter and set it on avg watts. key the radio. Stock is 4 watts. A lot of times when you peak a radio, you lower the dead key.(thats keying with no audio.) This allows you to get more modulation wattage, or swing wattage. If that has been done it will probably do 2 or 3 watts. If it has had the AM power raised in it, it could be more, this is no good. You want your dead key a bit lower.
Now check it on peak. Flip the meter to peak and make an AHHHHHHHHHHHHHHH noise into the radio. It should swing to anywhere between 15 and 20 watts.
You adjust the AMC while giving it audio and watching the meter on peak to adjust the modulation. 4 watts is legal modulation.
Feb 07, 2010 | Cobra 200 GTL DX 4-Channels Base CB Radio
I have a 77 that has got hardly any swing anymore.it keys 3-4 watts and won't swing past about 8 watts.i used to get 25 watts plus swing out of it. i have replaced the finals and it did not help.any ideas?
Is this just on the AM side or also on SSB?
If you type in 77HML or Galaxy 77HML in your Search Block,you should have a listing for cbtricks.com. and it should say Manual.This will give you Schematics,Transistor Voltages,Parts Placement and Specifications anything you would need is on this page.There are 3 Transistors on the Back Right Corner of the Radio looking at the part side,TR-49 is a predriver for TR-50 and TR-51,which are your AM Modulation Transistors.Hope this helps you out.
Jan 24, 2010 | Galaxy Radios DX 77HML Base CB Radio
I have a Galaxy dx 88 hl that don't swing
You will need a good technician. I know of a few but I do not like you to spend money again and again. Email me at...... poikaa@yahoo.com
Sep 14, 2009 | Galaxy Radios DX- 88HL Base CB Radio
Tunring up a cobra 150 gtl/dx
Um... What?? This is hooked to a switch? CB radio by FCC regulations is only supposed to have a max of 4 watts total output. If you can flip it to 7 watts dead key, you are doing really good. It won't do much more then that. It sounds like its set up to run on a linear amplifier, which cannot have more then 3 watts dead key transmitting into it.
Dead key, and modulation are different. You may have a meter that only reads dead key, and won't see the modulation. This radio is probably swinging close to 15-20 watts. you need a meter that can read PEP, Peak envelope power. Cheap meters only read AVG, or average power, witch will only show your dead key.
7 watts dead key is really good for that radio.especially since stock only has 4 watts. you cannot get any higher then that without changing finals.
at 3 watt dead key, or 7 watt dead key, your modulation wattage is still swinging much higher.
Also, you will get more swing with a lower dead key any way, which is better if you want it to be loud.
Leave it alone. its probably set just right.
May 12, 2009 | Cobra 150 GTL DX Base CB Radio
Low output power
On the meter you are using, does it mesure Average power or peak envelope power?
This is very important to know when you are measuring.
AVG measures basically your dead key. It usually will very little if at all.
PEP measures your peak output, or swing. Modulation.
So even if you have a radio that has been peaked, on a meter that reads AVG, it will still read around 3 to 4 watts. And, if it has a swing kit in it, it will read even less. A swing kit lowers the dead key it increase modulation. Higher PEP.
For example. I peaked my cobra 29 and it does some where around 22 -25 watts PEP. I have variable power in it as well, but usually run the dead key at 2 watts because I have a linear. The Radio alone, when mesureing on PEP with key up at 2 watts, and then when you talk, swings to about 22 -25 watts.
If I flip the meter to AVG, it stays at 2 watts even with talking.
If you have one of those cheap pyramid meters, etc, they usually only read AVG.
Get a meter from radioshack. They have a fairly decent radio for the money. It reads both PEP and AVG and has SWR as well.
If the radio has been peaked and it has a swing mod, it will most likely be swinging to some where in the 20 watt range.
On a side note. According to FCC regulations, a CB radio is only allowed to transmit with 4 watts of final power. Most times the manufacturer will have it a hair under so that they are leagal.
Basically it is illegal to use a CB that puts out more then 4 Watts.
But its a free for all these days. There is no more funding to the FCC for monitoring CB radio, so they do not want anything to do with it. As long as you don't over do it, have over 50000 watts and terrorize a small community with RF, you can do what you want.
Now a days most cb radio's bought have already been peaked if you got it from a cb shop, or off a website that does it.
Apr 21, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
148gtl, Taiwan when you modulate the meter swings backwards
In the back is where power mods have been added...It sounds like a swing kit 1/2 watt deadkey to 25 watts which is a powerful modulation exceeding 100%. Its a 220uf capacitor in place of a jumper J1 or J(x) J something in some radios. if you replace the jumper and remove the capacitor 220uf or 470uf one.(near finals it will return to around 4 watt dead key) The result of 4 watts is modulation is flat;where if you adjust it to 2 1/4 watt to say 20 watts it will be very loud and modulation is at 100%.
Dec 07, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 25 LTD 40-Channels Base CB Radio Logo
41 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
