Philips DTR220/05 digital freeview reciever not recieving anymore
Hey guys. for some reason, over night, this box has stopped recieving our previous full channel list and now only lets us watch bbc 1 and 2...nothing more! out of 72 previous channels.
restored back to factory settings, searched for software updates and still nothing.
its simply happened over night!
i know the information maybe a bit vague but thats all i can give at this time :(
Mike
  • Spl1nt3r Feb 24, 2008
    i ran the first time instilation again, twice and had the same effect. (only found 6 channels, and 2 radio)
    i took out the signal amp from the aerial and splugged it directly into box, same reception. Plugged aerial into back of tv, crap picture but reception.
    so, this leave me wondering as weather it is something to do with a service issue.
    on the otehr hand, my housemate downstairs using a different freeview box, is having no problems apart from a few signal losses during viewing.
  • 476 Answers
If the box is still receiving some channels, then the box is probably not at fault.
If you have done the full "First time Installation" rather than search for new channels, then eithe the aerial, connection or signal is likely to be to blame.
There have been several changes with the Freeview service over the last few months, and there will be more in the run up to analogue switch off.
In some cases, channels have moved, and in other cases the service has been switched off for a short period, low power etc.
Check the aerial on a standard analogue signal, if the quality is poor, then this rules out the box.
Posted on Feb 23, 2008
  • David Simpson Feb 24, 2008
    If the reception is the same without the signal amp, then its possibly the amp at fault.
    Try your box on your housemates aerial point & TV.
    The Philips DTR210 & 220 both have a more sensitive tuner than older models, and so, should give best possible reception.
HAVE PHILIPS FLAT TV 42" WITH BUILT IN FREEVIEW
Try this web site http://www.support.philips.com/support/html/index_us_en.html
Sep 26, 2011 | Philips 42PFL7332D 42 in. Flat Panel LCD...
Does this TV have built in Freeview ?
Yes,all tvs that are a LCD or a Plama tvs that are a flat screen tvs picture panels can recieving Free over the AIR DTV broadcasting incomming tv channels.Buy and used a Digital design tv Atena for a long and strong recieving incomming tv free signal DTV channels.
Aug 15, 2011 | Philips 26PF8946 26 in. HD-Ready LCD...
The Box Super, Digital Reciever
try this it worked for me north west. 00-OB-F2-52-4E-1B-86-90 GOOD LUCK
Feb 19, 2009 | StarTech.com StarView SV211K 2-port KVM...
Recieving no digital channels in my LCD TV
hi there alot of the updates for the system should automaticly download via ariel to the tv to keep you up to date some times if the strenght of the signal isnt srong enough then you might not get the update they send out , one thing i have found is that if you use an ariel booster then this makes the signal stronger this helps particularly if you have more than one tv set up with the same ariel, you could try unpluging all ariels to other tvs making sure the ariel lead you are using has no conections in it as this also gives you loss of signal if there are multiple conections in the lead runing from the ariel to your tv set hope this helps some
Cheers ;)
Feb 05, 2009 | Toshiba Regza 42C3030DB 42 in. LCD TV
Connect philips dvdr80 to intigrated freeview tv
Solved the problem by connecting the freeview box back into the dvd recorder. Apparently because the dvdr was made before tvs with integrated freeview, it can only recieve decoded signals from a freeview box, ie analog
Jan 16, 2009 | Philips DVDR80 DVD Recorder
Cannot find freeview/digital on our new TV
You can only get the freeview / digital channels through cable by subscribing to a package which includes them. They will then supply the necessary decoder to get the channels. Otherwise you will need a digital aerial and a freeview box if you tv is not dtv ready.
Jan 03, 2009 | Televison & Video
How can I get Freeview Channels?
I have a Bush 6690D and I can confirm that it does have a built-in digital decoder for terrestrial signals (Freeview).
Have you checked whether ***********'s TV is set to digital mode ? The "Mode" button on the remote cycles between analog, digital and AV inputs.
Oct 23, 2008 | Bush DVD2038 DVD Player
I HAVE A HDD&DVD PLAYER RECORDER WITH DIGITAL FREEVIEW IT,S DVDR5520H.I IT DOSE NOT DOWNDOAD THE PROGAMMES PLUS GUIDE. CANYOU HEHP
in setup for guide plus U must enter the time and date along with UR correct post code and select freeview as UR input then the correct input route of UR freeview box ie EXT2 then proceed as instructed. also you must select program number 102 on you freeview stations for the eye to send signal to UR box .the eye for the guide plus must be placed directly in front of the freeview box by it`s remote control reciever.
Oct 08, 2008 | Televison & Video
Can,t record from digital channels
You’re dvd/vcr only has analogue tuner so the only way to record is by using the Phillips tv but as said tv will need to be switched on.you would need a sky or cable box or a free view box separate to the tv to record with tv off.the vcr will recieve only on the av channel av1 when connected to tv.a sky box or cable can be connected to av2 on sharp using a second scart lead and box
Feb 05, 2018 | Sharp Televison & Video
Can't tune stations from freeview box to DVDR3380/5
You can only record freeview channels through your box.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
If you are doing timer recordings, you will also need to leave the freeview box on the channel you wish to record, or set the freeview box timer.
Dec 15, 2007 | Philips DVDR3380/05 DVD Recorder
Televison & Video Logo
587 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
