Question about Hoover V1 SteamVac SpinScrub Vacuum
Will not start again.
When I plugged it in it started then turned off - now it will not start again. I check the Outlet and that was fine, I even tried a different outlet. When it went out I wiggled the cord thinking it was loose - it sparked but did not start up.
    Problem Solver:
  • 9 Answers
Possible bad plug or outlet - but 1st remove/replace tanks and try again at a different outlet. For some reason all Hoovers models have some sort of "shut off" if you hit a wall edge too hard or when you turn you make the machine off balance. The r& r of tanks always works for me when I get an unexpected shut off. Also - it will make that noise you hear when the tanks are full first - then shut off even though they are no where near full.....
Posted on Apr 26, 2009
    President:
  • 1,673 Answers
If the cord sparked, then it is bad and needs replaement. If it sparked at the plug end, then replace the plug.
Posted on Mar 02, 2008
Lately as I'm vacuuming, my vacuum will turn off. I can start it again, and it will shut off again. It seems like a power issue. Happens different places in the home, so it is not the outlet.
Some vacs shut off when the dirt bag is full Check your brush area and see if there is dirt or bits of string like things wrapped around the brush or the brush ends. This will cause the machine to shut down as well if there is pressure holding the brushes. Will it run if you wiggle the plug if so you could have a bad plug as well.
Jul 07, 2015 | Kenmore Vacuums
My Bosch vacuum won't start
Check the easy things first. Check your circuit breakers. Will a lamp or another appliance work when plugged into the same outlet? If it is plugged in and you wiggle the cord near the plug and near the vacuum will the motor try to run? This would indicate a faulty plug or cord. If the switch, plug or cord is bad, then you need an appliance repairman. Anything else is highly unusual and would probably require a new vacuum. Best of luck.
Sep 22, 2014 | Bosch BSG71310UC Bagged Canister Vacuum
Why rainbow vac wont turn on
There are numerous reasons. If there was no smoke or burning smell, first try a different outlet. Then you can try wiggling the cord and check cord for damage, if you can get it to start and it turns off again cord is loose or damaged. Try the switch, sometimes switch wears out, if it is not making a click sound or is very loose it may be the switch. The most common reason for an E series to not start after working just fine is a broken actuator on the water basin or missing from the bottom of the vacuum. There is a raised part on the water basin that depresses a little black plastic actuator on the bottom of the vacuum. This is a safety switch to make sure the water basin is there so the vacuum will turn on. You can try pressing in on that and trying to start your vacuum, if it starts you will need to check and see if the part is broken off of your basin or if the little black actuator is missing. You can see pictures here.
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
May 10, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Lights on front of unit stopped working and a little while later the whole unit stopped working while in the middle of vacuuming
Take it to a qualified repair facility. Even as there isnt to much to a vacum let the tech check it out. Could be a faulty switch or controls. I dont think its a serviceable by homeowner problem.
Dec 20, 2013 | Kenmore Vacuums
The Vaccum is not turning on when i plug the hose into the wall. The hoover system will turn on when i turn the switch on at the base and wont go off till i turn the switch off. But it will not come on...
you can test this out by taking a small metal spoon and with the bottom side of the spoon insert it into the vac outlet on the wall. you want to touch the two metal pins inside the vac outlet to test if the unit is the problem or the hose is the problem.
If the unit starts, the hose should have a 3 year warranty on it. I recommend you have your nearest beam dealer check it out.
If the unit does not start, it has a 7 or 10 year warranty, the circuitry should be replaced. Again have your nearest beam dealer check it out.
good luck
Nov 06, 2010 | Beam Industries Vacuums
Not turning on. Was running fine, but turned off to empty cannister and will not start again.
You have either tripped a breaker at the breaker panel, or you have a short in the vacuum somewhere. Try plugging it in a different outlet in a separate room.
Good Luck!
Jim
Oct 07, 2010 | Hoover Vacuums
Wind tunnel hepa filter it stopped during my vacumning. It was plugged so I cleaned the plug but it won't start again. the outlet has power??
let the handle all the way down look down at the vacuum head you should see a reset button reset it and see if it won't turn on then hope this helps
Jun 30, 2010 | Hoover U6630-900 WindTunnel Bagless...
After I run my vacuum for a couple of minutes it shuts off. If I unplug the vacuum and plug it into a different outlet most of the time it will start working again.
I would say check inside the plug and make sure the connections are tight. If the vacume runs fine on the other socket outlet then it will bw a faulty socket which cuts your hoover out. Can buy a new socket frount from diy stores for about 2-3 pounds. If the hoover also cuts out on the other sochet it will be a temperature cut out device on your hoover. If this is the case empty the bag and give it a good clean and get rid of any accumalation of dust/dirt
Jun 24, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Hoover V1 SteamVac SpinScrub Vacuum Logo
335 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
