Question about Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius drive belt wont go on
Plz help cant get drive belt on
  • 10 Answers
Hook the belt around the motor spindle first then get the belt as far round the pully as you can once at that stage hold the belt firmly as you can on the pully and turn the pully round making sure that the belt does not slip off keep turning the puully round till the belt is fully on once on spin the drum around by hand to make sure that it is on the pully square with motor spindle. job done. if this helped please leave feed back.
Posted on Feb 24, 2008
Had the same problem and used three tywraps to hold the belt to the drum pulley after fitting it first to the motor spindle,turned the drum slowly and the belt put itself on to the pulley no problem cut off the tywraps problem solved wouldn't have been able to do it without the tywraps. Thanks.
Posted on Dec 22, 2009
The belt is very tight to fit and instead of trying to hold the belt on the top pully by hand, put a cable tie on to hold the belt in position.This i have been informed of by a washing machine fitter who took half hour to fit one
Posted on Oct 18, 2008
Thanks Guys. really helped fixing my wd240 belt. However, the belt kept sliding and rubbing through the plastic casing of the drum. casing already grooved and i am concerned I may have to replace the belt pretty soon. Any idea what the problem is please. (Could it be the bearing?)
Posted on Oct 09, 2012
Hotpoint aquarius ctd00 tumble dryer...everything working but drum wont turn
it looks like you need to put the belt back on which is inside the machine. to do this open the lid with screws on back take lid off then you should see the belt inside the machine and where is was before on the drum of the machine. slip it back on and put lid back on and it should start turning again. hope this helps.
Sep 20, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint drive belt
un plug appliance, remove lid and back plate, place belt on motor and carefully on drum pully, turn pully to pull belt onto its, its quite tight to do but is possible, watch out for trapping your fingers.
Apr 07, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius tumble dryer, drum not going round but still
If you can hear the motor going, then the belt probably needs replacing, if no motor action, then prob is more serious.
Please rate my solution.
Thanks.
Jul 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Fitting a new drive belt to a hotpoint aquarius
Remove lower rear panel, tilt washer forward, getting someone to help, and fit belt round motor pulley, then fit belt round drum pulley, slowly turning the drum pulley round as you feed the belt on, it is very tight, and you might think the belt is to small, but this is normal, as the belt stretches, just persist, but be careful you do not trap your fingers. Good luck.
TRhanks.
May 10, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Drive belt came off Hotpoint Aquarius WT540
At each side of the lid there is a small plastic cover. Remove these then take out the screws. Lift the lid at the front and push it back then lift off.
Thankyou for using Fixya.
Jan 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Need to replace drive belt on hotpoint wf430 but to tight to get
Put it on the motor spindle first then feed it onto pulley. It is tricky with such limited access.
Hope this helps &thanks for using Fixya.
Jan 22, 2009 | Hotpoint Aquarius WF000 Front Load Washer
The belt in my washing machine just broke
Try this number; 0818 313413
This is Hotpont service in Dublin.
Plz rate my soution.
Thanks.
Jan 14, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Door wont open on my hotpoint aquarius washer/dryer
Turn the dryer dial to off, making sure you can hear it click off, wait 1 min, and then try door. If it will still not open then you may have faulty door lock, or a prob with the door handle.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius wma30 drum wont turn
If it has filled with water, and no lights flashing, and then no motor action I would check the brushes in the motor for wear.
Remove rear panel , remove belt, undo 2 screws securing motor,
and lever motor back, disconnect motor plug, noting which way it goes in, and check brushes for wear
Plz rate my solutioin.
Thanks.
Dec 28, 2008 | Hotpoint WMA30 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
987 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
