Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens
Canon 300d autofocus problem
Im having a bit of problem with my camera its a canon 300d. When i use Autofocus it will focus on anything pointing the camera upwards but not on the same level or down below. Any help appreciated.
Sound like the secondary autofocus mirror may be loose, gently move the main mirror up after removing the lens to have a look. If this is the case the camera needs to be repaired
Posted on Apr 05, 2008
  • 42 Answers
Have you choose a correct "Focusing Point" by pressing the right outmost button on the rear of the body, just above the CF card compartment door?
Posted on Mar 07, 2008
Autofocus problem on canon 135mm f2
If it focuses OK on manual focus and won't focus on auto focus the problem may be down to a broken ribbon cable in the lens.
May 06, 2017 | Canon EF 135mm f/2.0L USM Telephoto Lens...
My canon eos 300d will not lock onto autofocus, no matter which lens I use. Consequently, cannot take fotos using "A/F". (Works ok on Manual Focus) Help!
Clean the contacts on the camera body (and the lens, too) where they meet with a cotton swab lightly dampened with rubbing alcohol.
Oct 12, 2011 | Canon Digital Rebel / EOS-300D Digital...
In my Canon 4ood Even after i pressed halfway and the autofocus point has blinked to indicate focusing is done but focusing is not happening and the shutter won't fire.With manual focus i'm able to take...
If it is a dark scene and the camera cannot detected edges well the autofocus will either move around a lot or simply will not focus and thus wont expose. You will just have to manually focus or use the flash
Mar 01, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
Will a quantaray 28-105 1:3.8-5.4 Zoom lens Autofocus from a 35mm rebel ti fit on Canon EOS Digital Rebel 6.3 MP 300D?
The 35mm Rebel Ti and the Rebel 300D use the same lens mounting protocol. All Canon cameras designated 'EOS' use the autofocus EF lenses. If your Quantaray lens worked on the Rebel Ti, it will fit and should work on the Rebel 300D.
Mar 19, 2009 | Canon Digital Rebel / EOS-300D Body only...
Autofocus on my Canon 28-135mm f/3.5-5.6 EF IS fails
Hello. First, check the contacts on the lens mount--you're looking for bent pins, oxidized(odd-colored) metal, damaged contact points, etc. The camera must communicate reliably with the internal circuitry of the lens unit. If there is any dirt, moisture, intermittent contact going on, the sensitive focusing electronics will be effectively blinded. If all is fine with the contacts, then the problem lies with the circuits in the lens that provide critical focusing data to the camera. Movement of certain parts causes electrical changes to occur at a calibrated rate--if the camera loses connection, it can't tell if the lens is actually adjusting. You'll have to send the lens in for repair--http://www.usa.canon.com/consumer/controller?act=SupportIndexAct. This address should get you started.--Hope I helped!---Rick
Mar 19, 2009 | Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
Canon Rebel Xti Wont autofocus
I dropped my camera and thought the autofocus broke. It turn out that it swithed from autofocus to manual focus. There's a switch on the lens. Check if that's your problem too.
Sep 25, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon 400d constant backfocus
Backfocus problems will be magnified when using wide aperture lens with shallow depth of field, nice lens btw. Camera's adjustments for manual and autofocus are inside mirror cage behind mirror, and you dont want to risk getting dust on sensor or damaging sensor. Qualified camera repair shop or sending to canon for adjustment would be my suggestion.
Feb 27, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Autofocus jumps around and often will not settle on the correct setting
what i do is usually put it onto manual focus then back to auto focus, what it may be is that you are using the wrong lens for your subject :/
Feb 27, 2008 | Canon Rebel XT / EOS 350D Digital Camera
My Canon digital rebel will not autofocus correctly. My camera has 7 points autofocus, but it will only autofocus on the far right point. All other points are not used. I have had the camera for 14 months...
I had this problem awhile ago - you must have accidently adjusted the focal area - it is sooooo easy to do without realising it. Here is what I was told:
Most likely, you have changed the AF point, which only takes effect in the creative modes (Manual, Av, Tv, P, etc)
There should be a button on your camera that has a grid like pattern above it, like
or so. press that, look through the viewfinder, and move the shutter or rear wheel, you should see the different AF points like up in red, and as you turn different ones will light up, and eventually all of them. also, you can look on the screen on top (or back, if its a rebel) and it will show you which ones are selected while in that mode, instead of looking through the viewfinder.
Nov 07, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens Logo
933 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
