Question about Mitsubishi WS-55907 55" Rear Projection Television
HDTV comes up green
I just purchased HDTV services through direct TV, when the installer plugged the HD cables into the 1080i DTV section in the back of the TV the screen comes up mostly Green, I can see Blue and Red but everything else comes in some shade of Green. it workes fine when plugged into the 480i or 480p section but not for the HDTV.
  • yourmomtakes
    yourmomtakes Jun 28, 2012
    I have this same problem, i HAVE MADE SURE i set it to YPbPr, but it seems to change itself back EVERY time.
    Sergeant:
    Champion:
  • 301 Answers
There is a setting in the menu under setup i believe it is called "LABEL VIDEO INPUTS". check you owners manual. you need to make sure that the DTV input is set to YPbPr NOT RGB.
Posted on Mar 29, 2008
Mitsubishi WS-A65 1080 HD Series Won't Switch from 480i to 1080i
Its main digital board has to be replaced. It is a skilled work. If you wish to get more details about this work, check the site linked below and pull up older posts there.
Apr 22, 2013 | Televison & Video
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
I have a 2002 Mitsubishi Medallion TV. The only input for HD is DTV (no DVI or HDMI inputs). Is there a converter box from HDMI to DTV that will allow for 1080i resolution?
From looking at the back panel of the TV, the DTV input can be configured as a component video. The M-Link/DVI-HD port is also a DVI with HDCP port and maximum signal handled is 1080i. The M-Link should work with an HDMI to DVI cable or adapter. For this to work, the source must not be a computer or another device using the default computer video output (computers give RGB output). The DTV port would need an HDMI to Component video converter. See this page for some examples: http://www.hdtvsupply.com/hdtocoad.html . The first one in the list (for Netflix and Boxee among others) will give 1080i out if the source is set correctly.
Most DVI-HDMI cables are single link. I've seen some examples where DVI-I (single link) and DVI-D (dual link) cables are not interchangeable. If you have video problems, check your cable. An HDMI to DVI adapters will let you run an HDMI cable up to the TV and then converter at the TV as a separate connection.
I hope this helps.
Nov 17, 2010 | Mitsubishi WS-65613 65" Rear Projection...
57H83 57 in. Rear Projection HDTV Television: I have a Toshiba 57H83 and recently purchased the ...
I would suggest to leave your directtv hd/dvr box connected the way It is.
The HD Colorstream 1input on your TV should work just fine.
This TV does not have an HDMI input but you can buy an adapter and connect to DVI/HDCP IN and that might be able to get 1080i video resolution on your TV.
Jun 30, 2017 | Toshiba 57H83 57" Rear Projection HDTV
TV Picture is green
is your RGB cables are the same output from your tv...are you connecting from where dvd cable box sattelite box, if you are connecting from a box exs output of cable box is what colour are you using? for your your output to your tv and what input are you using of your tv set.[input 1is it video input 1,] or comp? let me know...
Jan 10, 2009 | Televison & Video
HD tv with the mitsu
Well if your refering to the right tv (check your model number) then this tv only supports 480i, 480p and 1080i. Ive never seen anywhere that it supports 720i.
The component wires should include three lines for each corresponding color, red green and blue, and finally white and red for left and right audio. I think that is what your refering to.
If everything is right, it should work, the fact your seeing green could be a number of issues... maybe its a direct tv box issue?
Apr 03, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Need a "Mitsubishi HD-1080 HDTV Receiver" to convert my TV to HD
You con't need to buy anything other than a HD satellite or cable box. A television can either handle HD or not.  The high definition sets are monitors that are capable of handing an input of up to 1080i.
Quick and dirty. Look in the back for blue, green, red cable input sockets. There should be matching cable outs. from your cable or satellite box. get a set of  component video cables, plug them in. Determine the audio type, where RCA jacks, Toslink fiberoptic or a component cable sock. In the latter you use a cable much like a yellow video. You can get away with using a yellow video cable if need be. Now, below more specifics if needed.
No, you don't want to by the add-on from Mitsubishi.  I am assuming you have a 16-9 wide format box
If you have a squarish box, i.e. 4:3 ratio. forget it. I don't know if any wree made for HD, but unlikely.  If you'd given me the model number could be a little more definitive. If you have a manual, it will tell you whether you can go HDTV.
Take a look in the rear of the set and look at  the connection holes. You should have at least one set of inputs, marked in some way with the Red, Green and Blue just on the inside of the cable hole. Those are tomponent cables pops that allow you to do high definition television. These cables are video only.; Sound is a second separate question.
There are usually some other assorted things back there, including off air tele.and maybe another kind of connecter.. Some of these might be useful if you have games etc. that attach directly to the set. In any event, those component cables say that you can  do HDTV. (NB:
The Direct TV  HD box should have component cable outputs. You can do this directly from the DiTV box to the set. You would also need a separate Audio Cable(s). Your set should have either a toslink fiberoptic hookup and/or a component audio cable. There's no inherent advantage between those two. If you have an old video cable (yellow) than you can substitute that.
You should now have HDTV and high quality sound through the set. You will probably have to set up the inputs and other stuff with the.remote. It's pretty logical. If you have used input x for bringing in the video, just match it up.and your on your way.
If you are going to confuse things by trying to connect another piece of gear, e.g. dvd box, you would go to inputs two. If you have the second set of component input, then hook an HD player to it. In this setup, you adjust the sound on the set according to how it works. I assume the DTV audiio can be controlled directly just as a cable box.  -- Here's what's going on. For several years Mitsubishi built higher end televisions without tuners or slots for cable (or satellite). But they were HD capable (as I said, not all). At the time, there was no HD that mattered and not even much of a standard for it. Some wanted 729p, others wanted 1080i The advantage for 720p over 1080i was supposedly the improved movement capture. 720p isn't dead, but it's not a problem.
You will need to set the menu on the television (using the remote) so that it says 1080i. It does not do 1080p, the newer high standard. It only has two other settings of consequence, 480i and 480p. Put it on 1080i and leave it alone. The 480i and the 480P will be on auto pilot if you have an older DVD players. If there is a high definition signal at fewer than 1080, it will be upconverted to 1080i..
The set will handle any signal you send it like that. You probably have an HDMI  out from your dtv or cable box. The set does not have HDMI (unless on a later model). The DTV box should have both of them. That's a simpler wiring setup that allows 1080P. On the offchance you have a box HDMI only, you'll need a converter cable.
The setup gets a little more  complicated if you're using a receiver as a switcher, i.e. all inputs go there with only one output to the set. when ou do that you're in an area outside this question.
  is this all there is to it. But It goes only slightly more difficult if you're hooking up the   .
You don't need the box for the television set.
Feb 17, 2008 | Mitsubishi WS-65809 65" Rear Projection...
How do i get my tv at 1080i
First of all your system, tv, must be able to perform your request, Secondly, your service must be able to provide the 1080i or 1080p, not all service's provide the service with the equipment they provided you (your box). Check with your provider.
Nov 17, 2007 | Mitsubishi WS-55311 55" Rear Projection...
HDTV Cable box conflict
This set does not support 480I in the DTV mode, only 480P and 1080I is supported. Try setting the analog setting in the cable box to 480p and that should take care of watching the set in DTV. Most cable boxes have a setting for format changes in the customer menu, depending on the type of box. If you are able to change the format, then the other inputs will not work since they need a 480I signal, as well as VCRs. Another setup could be to use the S-Video cable or Video input jacks to get a better picture in 480I instead of using the cable input. However, when changing from HD to Analog, you will have to change to the correct input on the set as well. Hope this helps.
Dec 24, 2006 | Samsung HCJ655W TV
Open Questions:
Mitsubishi WS-55907 55" Rear Projection Television Logo
83 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
