Question about Durabrand DWT1905 TV
Durabrand 27" TV
I have a 27" Durabrand TV. Its only 15mos old and the picture started fading from bright to dark and from normal color to red. Does this mean the TV is fixing to go out?
  • Anonymous Feb 29, 2008
    my television does not show dark it is black and the adjustment is on bright as can go and still is dark like the picture tube is going out
    Problem Solver:
  • 12 Answers
The problem, lies on the flyback ,, on the flyback there two adjustment, the screen and focus that was writtten , adjust only the screen slowly untill screen of your tv back to normal.....fading because over saturation of voltage, adjust the screen trimmer counterclocwise....
Posted on Mar 02, 2008
Still, bright images on my PS3 change the color of my TV in areas
hi verifies if you are connecting good the video cable i mean the red, the yellow, and the white, if this dont serve you, is because your tv is to old.
Sep 19, 2009 | RCA TruFlat 27F520T 27" TV
Picture has a red "haze"
the color in my tv is a little faded when theres dark scenes on cant really see picture. Red and Blue really fade into picture
Feb 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
JVC AV27430 picture seems to have lost the red color
Hi, good day.
Pls check for loose contacts along the crt circuit and likewise, the possibility of a defective crt socket
mycho
Feb 15, 2009 | JVC AV-27430 27" TV
Rca truflat 27"
You can take off the back of the tv. Look for the red wire at the top of the tube. Follow it down to the part that it goes into. On that part (transformer) there are 2 controlls. The one marked SCREEN, is the one you can turn up and watch the screen at the same time. If the tv shuts off, put that control back to the original position. If it brings up the brightness, then it is fixed. If not, take to a repair shop.
Jun 13, 2008 | RCA TruFlat 27F520T 27" TV
Dvd connection
from the DVD to VCR (use the AV sockets) then from VCR to TV (use the antenna cable)
Jan 27, 2008 | RCA DRC247N DVD Player
Durabrand TV picture died. 2 yrs old
hats the shelf life on that tv
Jan 21, 2008 | Durabrand DWT1905 TV
Brightness of picture
If you feel good about opening your set then you can try this: Look for the flyback (high voltage) transformer, with the thick red wire which goes to the top of the picture tube. There are 2 controls on the flyback transformer, focus (top) and screen (bottom)Turn the brightness and contrast all the way down and then increase the screen control until you see retrace lines, and then back it down until those lines just vanish. Return the brightness and contrast to normal and adjust the focus control, if necessary, for a nice sharp picture. Let me know if that brings your brightness back.
Aug 21, 2007 | JVC AV-27D104 27" TV
JVC 27" AV27F803 Brightness fades to dark intermittently
I likely you have a loose conection in the crt board at the neck of the picture tube or a loose conection close to the high voltage transformer,I would suggest to tap the main board as well as the crt board with a wooden or rubber handle(not metal),be attentive were you tap to see if the set reacts ,if the set reacts you will need to resolder those places ,be carefull working on a set that is on while you do it,this should give some idea what the problem could be in case you want to call someone to help you with the repair.Let Us know if you need more information.
Nov 06, 2006 | JVC AV-27F803 27" TV
Brightness and volume
The dark picture is a bad capacitor for the screen or drive voltage for the picture tube driver transistors. The other problem of streaking is one of the same. Thats the indication that a capacitors defective . It could in a rare cas ebe a defective or gassy crt as well but 99% of the time when a crt is said to be gassy its nothing more then poor drive to the crt. Good luck
Jun 13, 2006 | Mitsubishi CS-40507 40" TV
Durabrand DWT1905 TV Logo
178 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
