Question about Sony SDM N50R 15" LCD Monitor
MITONE MP3 player software files are formatted
I have a MITONE multi user MP3 player, one of the my family member software files are formatted, please tell me next solution for install the software??
MP3 player software files are formatted problem
SOURCE: omg format
dont know nothing on that
Posted on Apr 03, 2007
SOURCE: my mp3 player could not play some songs
download mp3 software from sony website ,, n then u r able to play mp3 songsn can put mp3 files direct to mp3 without convertning them ,, but in this sony sony u have to conert songs into AC3 b4 u put them into ur mp3 ,,so I suggest u to download this program
Posted on Aug 02, 2007
SOURCE: Format error in mp3 player
You posted an iPod question in the PSP section. I recommend posting your question in the iPod section of the site.
Also, please re-word your question to be more clear. It's hard to understand what your exact problem is from the description.
Posted on Dec 19, 2007
SOURCE: needs software installation
i bought a new mp3 player,don't need the hassle with sony
Posted on Oct 10, 2008
SOURCE: Snoy NW-E105
I had the same problem and struggled with it for some time. I forgot the format feature on the device itself and kept formatting from my pc. This won't work.
The solution:
1. Unhook your device from the pc by pulling out the USB cable.
2. Click the "Menu" button 1 time (found on the back of your NW-E105 player).
- This will show "Display"
3. Click the " |<< " button 3 times (the button to rewind track).
- This will show "Format"
4. Click the Play/Stop button 1 time.
- This will show "Format: N"
5. Click the " |<< " button again 1 time.
- This will show "Format: Y>
6. Click the Play/Stop button 1 time (wait for "really?" prompt), click it again.
Now your device is formatted and will play the files you add to it.
Posted on Oct 22, 2008
I have mitone mp4 player (MITMP26) 4 GB . I have a problem. USB device don't see my computer. Windows 7 64 bit. Please help me.
Hi, player not recognized by the computer
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see Sansa player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the Sansa player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mitone mp4 player Connect and mitone mp4 player Express which only use MTP mode. MTP mode is the recommended and default method for mitone mp4 player Players when used with Windows OS.
The mitone mp4 player player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
SOLUTION 3 - Connect using MSC mode
Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC.
If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the mitone mp4 player firmware
NOTE: mitone mp4 player Express and mitone mp4 player Connect do not have MSC mode. For mitone mp4 player Connect you can try reinstalling the firmware using the Connect Recovery Mode.
Additional troubleshooting notes:
If you have replaced the mitone mp4 player Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting.
- Try connecting on another computer.
- Try using a different USB cable
- Try connecting to the back USB ports which may supply better power.
- If only MTP mode is not working, try reinstalling Windows Media Player
For Windows XP try also download and install the MTP Porting Kit.
Hope that helped And please don't forget to rate me..
Have a nice day....
Feb 19, 2011 | Audio Players & Recorders
I clicked right on the mouse and formatted the i pod suffle 2 GB .since then it is not working.what should i do?
lets say you at least copied the software from the ipod...(well if you did not... you wiped it clean by formatting).. okay do you have a friend, family member or next door neighbor that has the same Ipod (that you can copy the software only)...
how to copy software
1 connect ipod to pc... Itunes will load up (x it out, close it)
2 go to my computer see the device click on it... copy the software and hidden also (you will not see any media files)
3 paste all the software to temp file on the pc
4 disconnect the borrowed IPOD, and connect your IPOD
5 copy all software from temp file and paste to IPOD
6 disconnect, close out my computer, plug back in, give it a 1 or 2 mins (if Itunes do not open, then open manually and see the new ipod)
please note you must have the latest Itunes version
Dec 12, 2010 | Apple Audio Players & Recorders
I have mitone mitmp25 mp4 player When i connect it to pc, it shows 3 folders sls.dir playlist & mic.dir Where ould i copy mp4 files in thesefolders? I tried copying in every folder but the player...
Mitone MITMP25 plays only videos in MTV format, so you should use the software included to convert all videos into MTV format before you can play those. See page 21 in user manual :-)
Jul 02, 2009 | Yifang Digital Easy Mp3 EM01 MP3 Player
I format my mp3 player
if you formatted your mp3 (you deleted not only the musical files, but the software to run your mp3)...if by any chance this is true and a friend / family member of yours have the same exact mp3 player. you can ask can you copy their software............this what you do, take their mp3 plug it up to your pc (copy only the software check for hidden files also)...disconnect the mp3 and give them back their mp3 (we dont need it anymore)...plug your mp3 to your pc and copy all the software data from pc, you just copied ....on to the mp3...and put your music back (put all M. Jax (R.I.P.)) ...........if this is helpful feel free to rate
Jun 14, 2009 | Philips SA2310 GoGear Mp3 Player
Lost factory settings - sample pictures, videos and music
You have a disk which came with the MP3 Player.
the disk contains the relevant software.
the device uses windows media player 11
You can follow this link to download a compatibility program for windows vista.
also any drivers necessary to reinstall the software.
Click Here for Software
If you find this post useful please leave a rating. Thanks
Mar 02, 2009 | Sony Walkman NWZ-B105F MP3 Player
Mitone MP4 Player 4GB MITMP22 - software disck empty
MITONE MITMP22 4GB MEDIA PLAYER PLAYS RMVB FILES
TO CONVERT TO RMVB FILE USE WIN AVI (AVI TO RMVB)
ONCE YOU HAVE THE WIN AVI PROGRAMME THEN YOU WILL NEED THIS EXTENSION FILE (HelixSDK0715 win avi rm extention file) AND CHOOSE THE SIZE OF FILE TO SUIT YOUR SELF IN ADVANCED ONCE YOU HAVE SELECTED RM
Feb 16, 2009 | Kenwood KDC-MP4028 CD Player
Downloading and playing files
Here is the link to the Mitone company.http://www.szimp3.com
Dr. Fawaz
gm@tekvalorg
Sep 29, 2008 | Philips SA3115/02 1 GB Flash audio video...
MP3
I bought a MITONE FLASH MP4 DIGITAL PLAYER. I am downloading files from internet sites in mp3 format but am not managing to listen to them on my Mitone though it seems to be playing them. maybe i dont know how to use it yet. any suggestions please?
Jul 29, 2008 | Sony Write-Once Recordable, 30 spindle...
Need firmware for MiTone MITMP20
If a player like this
http://www.szimp3.com/product_show.asp?BigClassName=MP4&SmallClassName=MP2610  ,
there are several clones of the Chinese goods. Firmware on the Russian here (English supports)
http://ftp.roverbook.com/RoverMedia/Aria_Q7
there two different versions of firmware for the assembly player (one can work with bugs)
Methodology firmware:
1. Disable USB cable, turn off player.
2. Holding down "M" connect the USB cable.
3. The menu select 3 - y para (other then USB disk), clicking the right analog stick.
4. The system will appear logical disk 2. First at 16 mb, second - remaining FLASH memory.
5. Copy invested in this archive 5 files on 16 - MB removable disk (all except reame.txt).
6. Turn off the player through the safe extraction devices.
Jan 22, 2008 | Apple iPod shuffle MP3 Player
If a player like this http://www.szimp3.com/product_show.asp?BigClassName=MP4&SmallClassName=MP2610 , there are several clones of the Chinese goods. Firmware on the Russian here (English supports) http://ftp.roverbook.com/RoverMedia/Aria_Q7  there two different versions of firmware for the assembly player (one can work with bugs)
Jan 08, 2008 | Yifang Digital Easy Mp3 EM02 MP3 Player
Sony SDM N50R 15" LCD Monitor Logo
43 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
