Question about Frigidaire 24 in. GLD2150RCC Built-in Dishwasher
Abnormal noise and vibration
Hello, experts. My Frigidaire GLD2150RCC has after three year's service developed an unusual noise and vibration. It seems to be occurring when the washer is pumping out to drain. It does this upon first start up and then in later cycles when it is pumping.
It creates a deep vibration that rattles the cabinets. It seems to be laboring hard, like pump cavitation. There is no air gap installed. I am guessing that the drain hose is partially blocked or perhaps the pump is simply worn.
The washer otherwise washes normally and effectively.
  • mordo Feb 24, 2008
    Thanks, willymik, I'll investigate.
    If I end up deciding it's a blockage, where do you suggest I look first? Easiest route seems to be at the hose to trap connection, yes?
To follow up on this problem, I successfully solved the problem.
I disassembled the drain pump and found a piece of a toothpick in amongst the impeller vanes. I don't know if was actually preventing the impeller from turning or if it simply was interfering with the impeller but after removing it, the washer is back to normal operating condition.
Posted on Mar 18, 2008
  • 105 Answers
Pump is viabrating against body remove frond base and separate metals or slip a bit of foam between
should fix problem
oterwise there may be obstuction in drain pump
Posted on Feb 24, 2008
  • william mikkelson Feb 25, 2008
    you need to remove the dishwasher from kitchen cabinet then remove panels to access drain pump take off pump at dishwasher and check in there
    there maybe some string or tyes tangled around impellor blades
I put a new timing belt on my chev 2.3 now when i turn it over buy hand i have a cicking noise
The timing chain tensioner timing chain tensioner and guides are prone to wear and may develop an abnormal noise, requiring replacement. if worn this will cause a clicking noise.Engines Affected: 2.2L 4 Cylinder, 2.3L 4 Cylinder, model years affected, 1990 to 1995. and 2005.
Jun 19, 2014 | 1995 Pontiac Grand Am
Frigidaire refrigerator makes chugging sound
Hi - Generally speaking, it is normal for Frigidaire refrigerators to making a vibrating, snapping, dripping noises however not a chugging noise. From what you have described it sounds like it could POSSIBLY be the drain sucking in air or it could be refrigeration through the evaporator. A constant noise could indicate a serious problem with one or more components. This is a repair that should be left to a refrigerator service expert.
Oct 16, 2012 | Refrigerators
Fridge making loud vibrating sound .
Uggh that has been one of the hardest things to diagnose in my 30 year appliance tech career,
the only way you can determine what is vibrating it touch everywhere and the noise will disapper when you grab right place since the sound is suddendly being dampened by your hand
i wish you good luck
Gene
Jul 28, 2011 | Frigidaire Refrigerators
Why does my self cleaning gas water heater make clicking noises?
zdriscoll-
All tank water heaters make some amount noise, clicking and "snapping" sounds, particularly after much of the hot water in tank has been used (like after a long shower) and has been replaced by cold water that is being heated vigorously.
If the noises are accompanied by poor or erratic performance, or obviously if something malfunctions, you may require the services of a repair connection.
Hope this helps.
Regards,
DIYpro
May 03, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Our frigidaire 10 year old front-load washer is vibrating way too much. it knocks on fast spin. is something broke?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 12, 2011 | Frigidaire Washing Machines
Why is my dishwasher making a buzzing noise? It is almost 2 years old and is a GE brand we got from Sears. It is still cleaning and filling and emptying properly, but the buzzing noise is driving me...
Sounds like a noisy circulation pump motor. As an Engineer, I would treat any abnormal noise seriously; the motor may require examination and possibly a new start capacitor fitting? or it may be loose or have a problem with its impeller, etc. Or it could possibly be a relay for the heating element is noisy. Either way, abnormal noises are unusual, and dishwashers need to be 100% reliable as they are often used unattended or overnight and any problem might indicate a possible fire risk. Sorry to be so heavy - is the machine subject to any guarantees or extended insurance etc? Some have 5 year guarantees. Whatever, I would call an engineer out to have it checked over.
Feb 02, 2018 | Jenn-Air JDB6510 Built-in Dishwasher
I have a Lexmark C510 which display a 910 service engine motor. Can you tell me what motor this is?
910—Developer motor service check
Step Questions / actions Yes No
1 Are there any unusual
noises heard around
developer motor or
developer drive assembly
before error posts?
Replace toner
cartridge
Does problem go away? Problem solved.
If not Replace
developer motor
and/or developer
drive assembly.
Partnr developer motor:
56P1627
Partnr Drive assy: 56P1628
Jul 15, 2009 | Lexmark C510 Laser Printer
Frigidaire FRS26R4A Vibrating Noise
Finally called a service technician. He said the compressor was bad and needs replacing. Fortunately, I'm in the 2nd - 5th year of my limited warranty so parts and labor are covered. He also said that the FRS26R4A is "junk" and it helps to support his family.
Jan 09, 2009 | Frigidaire FRS26R4A Side by Side...
Kenmore 4.6-cu/ft refrigerator makes unusual vibrational noise
probably is the compressor become noisy but it doesn't mean that it will fail
Oct 08, 2008 | Refrigerators
Mine is a FDB635RFS4 model - issue is loud screeching noise
i recently had the same problem of a loud screeching noise. my unit was installed new in 1999 and has worked well up to this point.
when i disassembled the tub water filter i found the filter was heavily clogged (it is supposed to be self cleaning), and i also found glass shards from a broken wine glass. i further disassembled the plastic housing under the filter ( held in place by three torx drive screws ) which covers the pump impeller and holds the lower spray arm. while i did not find any blockage in the pump area, and no abnormal sound when i turned the impeller by hand, i did find that one of the pump impeller vanes has a small chip which probably makes the impeller unbalanced resulting in more than normal vibration. i cleaned the water filter and reassembled the parts and the original screeching noise is now gone.
Sep 03, 2008 | Frigidaire 24 in. FDB635RF Built-in...
Frigidaire 24 in. GLD2150RCC Built-in Dishwasher Logo
235 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
