Question about Samsung TXN3271HF 32" TV
Not Available Flashing
When I turn on my TV, the CH light turn on and Not Available flashes in red in the middle of the screen. It does this off and on all the time. If I tap the CH button on the TV repeatedly it will go out and the Not Available will stop flashing, but when I change channels, it starts up again. Also, the remote will not turn on and off the TV any more.
  • samsung725 Jul 12, 2008
    Same issue.
  • Anonymous Feb 04, 2009
    I have a Samsung lnt4661f with the same problem -- "not available" repeatedly shows up, regardless of the input (e.g., cable box, blu-ray, rabbit ears). Wondering if it's a closed captioning or SAP issue...
My Samsung TXN3271HF had the same issue where the poorly-designed Soft-Touch channel button begin to register phantom touches (leading to the "Not Available" message flashing on the screen).
The fix is simple: remove the plastic strip containing the Soft-Touch buttons and when replacing the strip, leave some room between the buttons and the TV's circuit board (you will see the circuit board once you remove the plastic strip).
Hope this helps.
Posted on Aug 20, 2008
JVC TV has flashing red light in front. TV won't turn on when red light starts flashing. After unplugging tv for a while, TV sometimes turns on but screen is shaking violently. Any flashing lights...
sometimes a leaky filter capacitor in the power supply primary section could caused this problem,or a loose solder connection in the power supply section
Jul 18, 2011 | JVC AV-32230 32" TV
TV will not turn on. There are two lights in front at the bottom of the screen - One is the power light, one is the OPC light. When the power cord is plugged in, both lights flash twice, then the OPC light...
Sounds like your screen is broken or has been impacted. Force the television on by doing this: Unplug it and on the side of the television where the panel buttons are hold down the ch- and vol+ buttons. Then plug in the television while still holding them down. The television should come on and you see the cracks. Unfortunately it can't be repaired.
If it isn't ch- and vol + then try ch + and vol -.
Feb 05, 2011 | Sharp LC46SB54U 46 in. LCD TV
The fan dont turn on when i turn on the tv and the red light is flashing
Red light flashing on tv indicates that tv got some problem and shifted to protection mode to avoid further damage.
If Lamp light is flashing on tv then check lamp that would be dead or broke, replace lamp to solve tv problem.
If standby red light is flashing on tv then let me know how many times it is flashing after 3 seconds long pause to provide you helpful info.
Thanks.
Jan 22, 2011 | Sony KDF-E55A20 55 in. LCD Television
My 37" LG LCD TV will not turn on and it has a flashing red light on the front at the bottom. I cannot get onto LG's website and there is nothing in the manual that addresses this problem. Any...
Two possibilities: the better one is that some joker put the set in demo mode (which includes a flashing power light), then turned on the Key Lock feature and turned off the set.
To check for this (quoted from page 118 of the manual):
Oct 24, 2010 | LG 37LG30 37 in. LCD HDTV
I try to turn it on but it just blinks on stand by
Probable Lamp. If lamp hasn't bown the red Lamp Lite won't flash but other lamp issues cause stby timer light to continue flashing. If stby red lite is flashing, count the no. of times flashing - could open thermal fuse (6X flashing)
Nov 27, 2009 | Sony KDF-E42A10 42 in. LCD Television
LCD SCREEN WILL NOT TURN ON RED LIGHT FLASHING
what bank in p.a. can i open a checking account thats wont hold it against me if i owe another bank money?
Oct 04, 2009 | LG Televison & Video
I have a Sony KP-53HS10 TV. The screen just died. There is a red light in the front that flashes, any idea on what to do? Thanks!!
this happened to us about 3 months ago. We were in the middle of a movie and the screen went black, red light flashing. we went online and the lamp bulb is blown. you can order a new on online, cheaper than Sony will charge you.
Apr 04, 2009 | Sony KP-53HS10 TV
Flashing Red Light....
The flashing "boat" in the middle of the viewfinder just means the button battery is dead. Camera will still work. It's the little pull-out light grey plastic thing that's next to the heel of your right hand when you're using the camera normally. You need a CR2025 cell.
Jan 27, 2009 | Canon XL1S Mini DV Digital Camcorder
Red toner light flashing
Dear sir; CH appears on the window means somewhere the door didn't close, when you close all door the red light will be disappear. try it out and let me know if you need more help, good luck, DON'T FORGET GIVE ME A RATING, THANK YOU , HAVE A HAPPY HOLIDAY !!!
Dec 22, 2008 | Sharp AR-M205 Copier
Sony FD Trinitron WEGA KV-36XBR800 36" TV
I get a black screen after power on...then a bright white light in the middle of the screen.Then the red light flashing and turns it self off.
Oct 27, 2007 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Samsung TXN3271HF 32" TV Logo
127 people viewed this question
Henry  Thomas
Henry Thomas
