Error Code Pitney Bowes C230 shows blinking alternating codes of "E6" and "01" All doors are closed and no jams are present?
  • Chip Rawlinson Feb 27, 2008
    It flashed a "U4" error code one time, then went back to "e6" and "01" alternating blinking.
  • 168 Answers
I think that is a Duplex error message. The duplex unit is not getting the correct power.
One thing you can try, is to slide the (ADU) duplex unit out and don't push it all the way in. Leave it out about an inch. Then turn the machine on and off. If the machine starts to warm up, but tells you to slide the duplex unit in, then you isolated the problem. Let me know if this works, and we can go from there.
Good luck.
Mac =)
Please always remember to post a feedback and a rating if I have helped you in anyway.
Posted on Feb 24, 2008
  • Mac Gyver Feb 28, 2008
    Well, we are narrowing it down. U4 is a Sorter Error or Open Code. The U4 should only show up if the sorter is not pushed up against the sorter.
    The E6-01 is still the duplex unit error code.
    If you slide the Duplex unit out when the machine is OFF and leave it out about an 1", and then Power the machine ON, do you get a U5 Error code? A U5 error code means the Duplex draw is out. IF you wait about 3 minutes and let the machine warm up first. (You will hear the machine running and then it will stop.) Then after the machine stops, slide the Duplex draw back in. If you get the E6-01 at that point we know there is something wrong with the duplex unit.
    Let me know what happens and we can go from there.
    It still could be something simple.
    Good luck.
    Mac =)
Error C-0500 on a DL46 Copier. How to reset and what is this code for
Fuser unit malfunction code.Verify the continuity the heater lamp,thermistor and thermofuse.Clean it.For reset open the front door and close or press the service reset switch.
Nov 10, 2009 | Pitney Bowes Office Equipment & Supplies
C180 says E2 and printer tray light blinks
E2 means paper miss feed press resum button the go to print
Oct 30, 2009 | Pitney Bowes C180 Copier
Pitney bowse every time show this messages
We need your model number.
Also check your toner cartridge carefully. A toner that is not fully locked in can cause this error.
Oct 30, 2009 | Pitney Bowes Office Equipment & Supplies
Pitney bowes fax machine model 1630 has 76 error code, what does it mean
The heater lamp in the fuser is broken. Call 1 800 243 5556 for service.
Oct 19, 2009 | Pitney Bowes Office Equipment & Supplies
Pitney bowes model c400 copier error 0070??
Sincerely,I don`t know this model,but the error codes is similary to the Agfa,Minolta,Konica copiers.This code is the toner agitator motor malfunction code.The developer station is blocated under minimal level of toner ratio.In this case forced toner supply.Opem amd close the front door to reset.
Aug 19, 2009 | Pitney Bowes Office Equipment & Supplies
Pitney Bowes Model 9016 Error code E3 01
E3-01 is the toner bottle rotation. for some reason it is not rotating. Take out the toner bottle and be sure it is in coreectly, that the labels are not loose and preventing it from turning.
Jan 19, 2009 | Pitney Bowes C180 Copier
FAULT CODE P0500
Fuser error code. unbend a paper clip and push in hole on right side of control panel. watch the control panel on the left side about 2/3 up a dot will appear. when it shows up, press 3. press trouble reset. Touch exit.
turn machine on and off. If it comes back up, reset again. 3rd time it needs a new fusing unit. Call 18002435556 for service.
Jan 05, 2009 | Pitney Bowes C180 Copier
Pitney Bowes Copier - C180 - Error E3
Sorry it took so long. Your copier probably is similar to a Toshiba E series. The error code is paper jammed in the bypass section.
Use this link as a lookup to the error codes
Use 4501 under Toshiba to find the error codes.
Aug 26, 2008 | Pitney Bowes C180 Copier
Pitney Bowes C180
There should be another set of flashing number after the E7.
There should be another 2 digit code.
This will help determine where the problem is located.
The E7 error code is a problem with either your automatic Doc Feeder or the the sorter if there is one installed.
If there is a sorter/collater, then also let me know if it has a stapling unit installed or not.
Jan 24, 2008 | Office Equipment & Supplies
137 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
