posted by a2dvoices on Feb 23, 2008
My son's Casio G-Shock 2688 Wave Ceptor watch is 2 months old. This morning the watch display went completely blank. He says he has seen this before, but hitting the light button normally corrected the situation. The only part of the display that seems to be working is the BATTERY ring (and it looks full).
Any ideas?
Thanks!
Comment by a2dvoices, posted on Feb 23, 2008
After shaking the watch very hard, the watch powered on. The display buttons are not working correctly, but the unit now shows "charging". Suspect that the unit just needs to charge for a while.
1 Other User Has The Same Problem
Comment by velvl, posted on Mar 08, 2008
how do I change the battery on the casio 2688. Is it something that I have to take to the dealer?
willdi
Solution #1
posted on Apr 13, 2008
On the solar charge watches, they use a chargeable Lithium battery. It is NOT an off the shelf regular battery! It is best to send the watch to the factory service rep in your area for a battery change.
In many of these models the battery is using solder contacts to the circuit board. The person changing the battery will require the original spec battery, and be equiped to do surface type soldering.
When working on this watch, the factory service will change the seals and do a pressure water resistance test. The regular corner watch service store is not equiped to do this type of testing.
Normaly, the battery in solar watches should last more than 5 years. Some are going past 10 years!
Jerry G.
Jerry G.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Casio Wave Ceptor WV57HA-1AV Wrist
Email this problem
Email this problem
Can you Help with these Watches problems?
Casio Wave Ceptor WV57HA-1AV Wrist Watch
setting the time on my new...
Hello, i recieved the casio... Answer This...
Cant get Casio 4303 to enter...
I have a casio 4303 (all... Answer This...
instructions for casio wave...
i need instructions for setting... Answer This...
Casio Wave Ceptor #3054
I cannot get RC timekeeping to... Answer This...
Can't receive atomic signal
I have a Casio Waveceptor,... Answer This...
Repair Service
Find Watch Repairman Near You:
