Question about Philips 27MT3305 27" TV
Vertical section problem? Part of screen is blank
My magnavox tv screen has lost the picture about 3 inches from the top, its just black space now, with about a half inch of upside-down picture, then the rest of the picture itself. I'm learning that I need a capacitor changed, but how do I identify the correct one? I have the TV open and am looking at the control board/circuit board, and there are several capacitors there to choose from.
Anybody have any advice?
    Problem Solver:
  • 8 Answers
As far as i know, you have a problem with the vertical driver or output
try to replace first the vertical driver its a silicon type transistor, i recommend because its the cheapest, for you to know which ic is it, locate the ic with 7 pins then look for the series no of the part. the next in series silicon type transistor is the vertical driver, if no changes you have to replace the 7 pin ic, which is the vertical output
Posted on Apr 07, 2009
  • 20 Answers
Replace cap. 2465, cap. 2561, cap. 2460, and d6460
Posted on Jan 07, 2009
Firstly, you do look & feel for any swollen or burst capacitors. if they all look good, get a multimeter & set it to the correct measurement & measure the capacitor. The capacitor's rating wud be on it.
Posted on Apr 08, 2010
Try replacing the 10 uf 160V cap and d6460 zener
Posted on Aug 15, 2008
At the top of the tv screen about three inches wide there is a black line that covers the picture at the top of the screen
I, thats a vertical circuit problem with some capacitore ,they are leak or dry
and at the same time you replace the vertical ic and verify for bad soldering
in the vertical circuit.
hope the will help you
regrads Alan
Jan 26, 2011 | Philips Magnavox 20MT4405 20" TV
Screen went to a 4 inch pic in the center of screen, then total black. All other functions work, just no pic
if the picture shrink into the center of the screen about 4inch then goes blank. you do have problem with your vertical drive IC, it's either loose contact with the board or the vertical IC already malfunction.
Jan 14, 2009 | Philips Magnavox 27MS343S 27" TV
Folddover at top of picture about an inch from top
Replace cap. 2465 and cap. 2561. That should take care of it unless the vertical transistors are bad or there are other bad caps.
Oct 27, 2008 | Philips Magnavox 27MS343S 27" TV
I have found an fix for this a capacitor 2494 needs to replaced.
Aug 21, 2008 | Philips 27MT3305 27" TV
3 inch blank space at top and bottom of 50 inch projection hitachi ultra vision
Good Day, richardyoung;
Lack of vertical reflection? Does this happen on all channels? Can you change channels and the picture size changes? Are you receiving a HD signal? Have you tried changing the format?
I hate to ask you all these questions but I need to understand your concern completely. If you answered some of questions above yes / no; your TV might be okay. But try them.
Good Luck, big IRISH.
Jul 29, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Wide black area top of the screen.
More than likely it's not the crt. If the picture has "foldover" at the top of where the picture is currently, then more than likely there are bad caps. in the vertical scan circuit. If not, the vertical sizing probably just needs to be adjusted. You will have to get in to the service menu to do that.
May 26, 2008 | Philips Magnavox 27MT5405 TV
27 in Magnavox Smart TV
problem in vertical circuit 100uf 35 volt cap also could have poor solder connections on vertical ic
May 02, 2008 | Philips Magnavox 20MS233S 20" TV
Picture size is shrinking within screen
hi there, you have vertical section prob., repalce imeditely the electrolytic capacitor at the vertical section. do some test and check up. ty
Feb 18, 2008 | Philips 27MT3305 27" TV
Vertical size
your problem in vertical outout section only. check feed back line. most probably electrolytic capacitor failure.
Sep 27, 2007 | Samsung TXE2546 25" TV
Philips 27MT3305 27" TV Logo
789 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
