I have solution for re-entering Serial Number on HP M2727nf back unto Formatter when you replace it my e-mail is [email protected]
Install the printer on one computer and connect it via USB .
Save the PJL file to the root directory i.e. in C drive
Now go to Printer and Faxes Folder and right click the LJ XXXX( your printer model) printer icon and Share this printer , Give the share name E.G. give the share name " Given by My Computer "
Then Right Click on the "My Computer" icon and go into the properties and click on "Computer Name " tab . Note down the computer name E.G the computer name is "Your Computer Name "
Now click on "RUN" type cmd
Then type cd\ and press enter .
Type dir look in c: file named SerialNumber.pjl
Then type copy give a Space
Then type /b Give a space
Type file name SerialNumber.pjl on this window
Give a space and then type \\
And then type the computer name
Then type the \
Then type the printer share name
Then hit enter.
Now you will see on your printers LED display printing document this is the file being
printed unto your new Formatter.
Press cancel document and print printers Configuration page you should now see your
restored Serial Number on the Config Page.....
****Note*** If you are going to be changing different Serial Numbers of different Printers
you will need to enter your Serial Program file and EDIT it in C: prompt and change Serial Number
and re-save file with new Serial Number*********
Please tell me how to save the pjl file(where i found it).
I create this file and everything is OK .Thanks.
How do i create the pjl file (is there any special column width o comma separated)
is this pjl file formated by columns comma separated or something?
