Question about Electronics - Others
Verbatim Memory Stick
My Verbatim Memory stick has somehow lost its log-in area - when I check on Windows Explorer on the drive, the log-in area, where I used to have to put a password, has disappeared.
  • nickyb79 Oct 28, 2008
    My Verbatim Memory stick has somehow lost its log-in area too - when I try the log-in area, where I used to have to enter a password, it has disappeared. How do i access my passworded area now? I split my stick's memory to 500mb each and now i only have 500mb remaining with no way into my privacy space. Can anyone help? Pleeease!
5 Suggested Answers
  • 94 Answers
SOURCE: memory stick
hi
u do not require driver for new generation memory stick, unless ur os is 98/95
Posted on Jun 12, 2008
  • 11 Answers
SOURCE: Can't view the files on my memory stick
you must have copied them wrong or they were a format that your computer doesnt even recognise.Format the memory stick (delete everything) the try again. make sure you format it not just delete the files on there
Posted on Mar 26, 2009
laikexpert
  • 281 Answers
SOURCE: I have an 8gb maxell usb memory stick which asks
1.
Update Your Windows Operating System.
2.
Check your computer.
with antivirus and antispyware program.
3.
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
3.a) Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
3.b) Format memory stick
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Posted on Feb 06, 2010
SOURCE: why computer won't read Sony 8gb memory stick produo?
when i plug my camera into my computer it normally pops up imput pictures but its not doing that with my 8 GB memory stick and idk why! and its making me mad
Posted on Jul 03, 2010
Hi i cannot access my verbatim flash stick. It asks me to format the flash stick but i try to it fails to format can you give me some idea as to fixing this problem pls
I hope your Jump Drive did not get formatted - because all your files would be lost.
You could try this:
Go to "My Computer" and right click on the drive letter for the Verbatim Jump Drive.
Select "Properties"
Click on the "tools" tab and select "check now".
This will check your Jump Drive for problems.
Feb 09, 2011 | Verbatim CORPORATION 94933 USB 2.1GB...
How do I safely turn off my Verbatim hardrive when I shutdown my laptop that it is attached to.
In the notification area you will see an icon with the Safely Remove hardware label - click on it; a small window will appear listing the devices connected to the USB ports (your stick included) . Click on the entry corresponding to the stick, wait a few moment to be unloaded from the Windows and take it out. Now you can shutdown safely.
Feb 06, 2011 | Verbatim VER95327 USB Hard Drive
I cant format or put data on my Verbatim Memory stick disk is write protected, and it appears the following pop-up screen Verbatim Memory stick disk is write protected so please provide me with...
Some Verbatims have a write protection switch on its side - make sure it's not activated. Then open the properties of the stick in My Computer. If in there the stick isn't set as read only then it has died - there's nothing more you can do to save it. Junk it and get a new one.
Sep 06, 2010 | Verbatim CORPORATION 94933 USB 2.1GB...
Saving Music to Memory Sticks
Memory sticks, memory cards and even USB thumb drives all get attached by Windows as a drive. Pull up Windows Explorer (file manager on Mac). Navigate to My Computer level. THis will show all drives attached including hard drives, connected USB drives and connected memory sticks/cards. You may not be sure which is which unless the drive was labeled with the cards branding. One way to determine is go to lower right task area and click on the 'safely remove hardware' icon (green arrow). Select safely remove hardware from pop-up menu. Check the box for Display device component. This should populate the window above with the actual names of the devices along with the assigned drive letter. Now that you know which one, open Windows Explorer, navigate to My Computer level and the select the drive letter. You can drag and drop files to and from this window to take files on and off the memory card/stick/USB drive. You can also right click on the drive letter and choose properties to see how much room you have on the card.
Oct 11, 2009 | Electronics - Others
Verbatim 8G USB memory storage stick not working
There could errors in the drive. You should either run a scandisk on it or format it altogether. Either should get it back up and running is it is a genuine device.
1. To check for errors/scandisk right click on the icon of the memory stick, select properties. Under the properties menu look for Error-checking and select check now. The check disk menu pops up. See that Automatically fix file system error box is checked. Then click on start.
2. If you decide to format the memory stick just right click on its icon and select format. But see that you move you vital files from it first else you will loose them.
Sep 04, 2009 | Verbatim VER95327 USB Hard Drive
Verbatim 1gb flash drive privacy zone lost space
try this link. http://verbatim.com/support/support-article.cfm?support_id=807E395C-1422-1392-A886DB00B24DFF68&supportType=Download
Aug 13, 2008 | Verbatim CORPORATION 94933 USB 2.1GB...
My windows 98 dell dimension 7500cx will not recognize my verbatim 256 mb memory stick
windows 98 need special driver from usb memory stick manufacturer.
if they dont have it then its not a compatible model for win 9x.
what i have done in prior is if high speed internet is saving it to online drive storage free website like xdrive.com if u have aim account youre ready to use it or others like yahoo mail yourself the files then retrieve in other pc.
Jul 30, 2008 | Electronics - Others
Logging into my memory stick
If you are running windows vista, try right clicking on the locker -select properties-select compatibility tab- check mark the run in mode box and run the application in windows xp service pack 2 compatibility mode or another mode listed. If this doesn't work then your drive might have become corrupted, either from static electricity from being plugged/unplugged with your computer on, or coming too close to a magnet etc... Always back up your data. Good luck.
Mar 06, 2008 | Electronics - Others
Using verbatim memory stick
connect the stick to your computer. Just copy the file and paste it in your stick.
Feb 18, 2008 | Electronics - Others
Electronics - Others Logo
536 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
