FixYa.com
Tags:
RCA DRC8295N DVD Recorder / VCR Combo
Plays no DVD's of any kind or format
posted by leegreenleaf on Feb 23, 2008
I insert any kind of DVD, which all play fine in my JVC unit. The RCA takes about 30-45 seconds reading the disc, then gives me a "disc error" message. It is a reconditioned unit, but the VHS side works perfectly. Am I missing something in the set up?(I checked to make sure that parental controls are off). What else?
Comment by leegreenleaf, posted on Feb 24, 2008
Thanks.Seems possible. I'll try it.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Feb 23, 2008
Helpful (85)
clusterfx
Rank:Guru Guru
Rating: 88%, 83 votes
The disc may not be spinning when inserted into the player.
when you insert a disc, something holds it from the top and bottom and starts to spin it. If the upper and/or lower grips can no longer grip the disc strongly, the disc will not rotate or rotate very slowly or not in sync with the laser reading it.
to test this, put some double sided tape on the outer circumference of the middle hole of the dvd, don't go too close to the area where the data area on the dvd begins. do the bottom first.
if this works then you have to find a clever way of placing something on the grips so they can hold the discs stronger.
For my dvd player, i took it apart, cut a rubber sheet into a ring shape and glued it to the lower grip. Haven't had any problems so far.
Rating Locked! (?) leegreenleaf has rated this solution as Helpful
Can you Help with these DVD Players problems?
Will not read or play any DVD...
I place DVD disk in machine,... Answer This...
dvd freezes up
Dvd runs ok at first, then... Answer This...
Trying to copy a home video to...
Every time I try to do this, it... Answer This...
rca dvd recorder repair
where around zip 47529 can i... Answer This...
RCA VCR/DVD Recorder will not...
and, it keeps displaying,... Answer This...
Repair Service
Find DVD Player Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
