Question about RCA P52960 52" Rear Projection Television
No Power This set has been working fine for a long time. Then one day I tried to turn it on, and nothing happened, either with the power on button, or the remote. No indicator lights lit up. It acts completely dead. I am an electrical engineer, and have repaired many TV sets. The incoming fuse is not blown. There is 170 VDC on the main power supply capacitor, and the board has DC voltages downstream from the transformer. There is 5 VDC at the power on switch. I checked the horizontal output transistor, the driver transistor, and the flyback. All check OK. I did notice that some parts of the board had no voltages, but I think those voltages appear after the set powers up. We did have a bad thunderstorm around this same time. Can you give me any ideas?
  • betty_jones1 Nov 21, 2008
    I have a RCA Home Theater Premium.Model #P52960 Chassis #PTk115y06B. I get NO power when Power button is applied. There was a power outage in the area when I lost power.The fuse is good.Please help.
  • RCA Master
  • 8,617 Answers
What is the cassis number to your set. RCA has to be diagnosed by the chassis as they have used different chassis depending on manufacturer. Should be a PTK number located on the back of your set.
Posted on Feb 24, 2008
Clock resetting and power button malfunctioning on my Gateway NV53A laptop.
Replace the CMOS battery. In the Control Panel, Power Options, set to High Performance, open Advanced power settings, set Sleep and Hibernate to Never, Adjust other settings to your preference. Set Screen Saver Time. Always turn off the computer and unplug when not in use, it will prolong life and a reboot every day will reset the computer. I would say you have a issue with the outlet connections/plug. If you have a multimeter you can verify.
Jan 18, 2013 | Gateway Computers & Internet
My haier htr20 tv wont power up..tv is completely dead.
Check the main power regulator section circuit.
May 20, 2012 | Haier HTR20 20" TV
My D-7 will not power up...when turn it on the power light weakly flickers (as well as the power sound) for only sec then nothing. Have cleaned battery connections, used charged batteries and even to
Sounds like electrolytic capacitor dried up needs curing, which is power on capacitor and left it absorb some moisture in humidity on power. Some time a few minutes, hard cases may take a few days.
Feb 08, 2012 | Konica Minolta Cameras
I got the xbox from a friend it was working fine when i turned it on the first time but then the next day i try to turn it on but it dosent. nothing happens when you turn on the power button,but there is a...
the orange light means that your power is working, there may be a problem with an ieral component that is linked to the power supply, does the system make any sound at all?
Aug 25, 2010 | Microsoft Xbox 360 Console
My laptop fell down and now my screen does not display anything
try to press and hold Fn and F8 - this is to toggle screen setting to ext and back to LCD on laptop. if nothing happens turn off computer by pressing power button, unplug the ac adapter, remove the battery. remvoe residual electricity from computer by pressing power button 10 times. just plug again the ac and leave the battery out. Pres and hold the letter D and while holding that press the power button once and release both of them. it will perform the built in self test on the lcd. if nothing happens, turn off computer. press anf hold Fn and while holding it press power button. it will perform diagnosis on computer. if still nothing happens need to repalce motherboard and LCD.
Mar 03, 2010 | Dell Inspiron 6000 Notebook
My hp ze4300 will not turn on
Has there been a power surge meanwhile? If so, try unplugging the power cord, press the power button, reconnect power and try booting. Sometimes works.
Oct 19, 2008 | HP Pavilion ze4300 Notebook
Power Issue
sounds suspiciosly like your chord fitting is damaged(loose wires at connection)and shorting.if possible try a friends power supply with same connecter type before renewing cos could be faulty(loose)connection at pc(inside)constant pushing and pulling of connections often causes 1. loose split or disconnected wires at male connection or 2.loose pins on motherboard female connection or broken housing (not difficult to repair)more difficult to find out how to get to internal connection.
Mar 04, 2008 | Toshiba Satellite M65-S9092 Notebook
"Install Yellow" Error - Machine is frozen.
Check all other carts. It might be that one (or more) carts are empty, too. Thats why the machine refuses to work properly.
Unplug from power, wait  two minutes and replug again.
If it doesnt come up correctly the maincircuit baord might be defective due to a defective electrical part.
Do leave the machine always on power connection. You can turn it off by pressing the stand-by-fax button, but you have to keep the machine with power supplied. Set date and time. The machine runs some automatic cleaning cyles every 20 days to keep the nozzles alive and that prevents the permanent ph from drying out!
Dec 31, 2007 | Brother MFC 240C All-In-One InkJet Printer
I can't turn the camera on anymore
I dont have a definite solution, but I would;
- clean the power contacts on the battery and the camera with a moist Q-tip
- leave the battery out for a day or so, maybe more if you have time. Make sure the battery is charged again (maybe just put it on for an hour or so) and re-try.
Sep 19, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
RCA P52960 52" Rear Projection Television Logo
60 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
