Question about Kenmore Elite 45986 Front Load Washer
HE3 washer wont power up
I have an HE3 washer that appears to be dead, no power. I checked power and it is good. Any suggestions?
  • 770 Answers
WON'T POWER UP. (Touch-pads do not respond when pressed)
Check the line voltage and for blown fuses.
Check for voltage going to Central Control Unit ( CCU) by listening for a click in the CCU when unit is plugged in
lf no click
replaceCCU.
Unplug the unitb eforec ontinuing.
Checkc ontinuitoy f linec orda ndl inef ilter.
Checkh arnessc onnectiontso CCU.
Checkt ouch-pad/LEaDs semb
Posted on Feb 23, 2008
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
Kenmore Elite HE3 Front Loading Automatic Washer
Pull the plug and test the plug with a nitelight or lamp. Now try the washer. If the lamp lit and the washer. It appears there are many problems with the controlls of these machines. There is a leamon law for appliences. Sorry I think this is a Vista model made by microsoft and the best bet is to force the mfg. to return your hard earned money because it is defective.
http://www.complaintsboard.com/complaints/sears-kenmore-elite-oasis-washer-machine-c44278.html
Aug 17, 2009 | Kenmore Elite 45986 Front Load Washer
Machine dead electrically
hello have check the fuse in the plug also the is a glass fuse inside the washer on the circuit board good luck
shaun
Aug 02, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE3 f02 error
from what i read the presure switch is bad or the presure switch hose is clogged,one guy took the hose off and blew in it and no more f2-mike
Jul 21, 2009 | Kenmore Washing Machines
Kenmore front load He3 washer: door wont unlock
happened to me once - I just unplugged the machine - waited a minute and plugged it back - it - then used cancel button
Feb 27, 2009 | Kenmore Elite 45986 Front Load Washer
Dryer not heating he3 kenmore elite
repl/ thermal fuse if no heat if heating for a little while clean exhaust, and repl/ coils
Dec 20, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore eliete washer fails to do anything
probably bad main control under top left rear ..ck for bad connections first just in case
Aug 21, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore elite he3 - door lock
If sound like a lid switch issue. Open the top of the washer to get an access to the lid switch(located near the doorframe). Look for a loose wire or a broken switch. In case there is no loose wire or broken switch, you should replace the switch. Good luck!
Sep 05, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
279 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
