Easiest way is to connect the pS3 to your wireless network. If you don't have a wireless network, connect a ethernet cable from your PS3 LAN port (on the back of the PS3) to one of the numbered LAN ports on your router.
I would use a wireless router. Then you can use ps3 or laptop in the house. Or run ethernet from main router/modem to the ps3. You can buy the ethernet cables at amazon.com and newegg.com and they can go a few hundred feet.
Your PS3 should have WiFi built in unless you bought he 20GB version back when it first came out, that is the only one that dosn't have WiFi. But you can still connect it the way you want. You can use any type of ethernet cable, straight through or crossover. You need to go into your network connections in the control panel, select wired and wireless connection at the same time and bridge them. That should do it if you wanna go that route but you would have to have the computer on anytime you wanted to connect your ps3 to the internet. The best bet I think would be to just use the WiFi built into the PS3
you can go wireless, but personally wired is better. what router do you have? switch everything off, plug a ethernet cable from one of your ports on router to ps3 then then switch it all on. on ps3 go to settings - network settings - internet connection settings - then select easy - then whether you wanna do it wireless or wired (up to you) then let it do its thing, once its found all your settings you can test the connection.
Have you set up an account on your ps3 yet?
You can't. For wireless connection on the PS3 you need to have a wireless router hooked up to your modem. Once you have your wireless network hooked up with your PC. You can give your PS3 access and the PS3 will scan for any available wireless networks. Google will help you more if you need more detail on how to set up your PS3 wirelessly.
I have a problem. I have everything hooked up and when i go for a connection test it says my connection has failed because there is an DNS error. What is a DNS? and what do i have to do to fix it?
