Question about LG LRFD25850 French Door Refrigerator
Runs alot We just purchased a LG refrigerator freezer and it seems to run a lot of the time. There are two distinct sounds coming from the unit. Is this a normal operation?
  • 489 Answers
Yes, there is the compressor that has a tinny high pitch sound and the condenser fan motor running at the same time.  The compressor is a very highly efficient motor that doesn't require a lot of energy to run but it does run quite long and often to keep the temperatures cold.
Posted on Apr 29, 2008
Why wont my refrigerator & freezer get cold?
If all is running, the compressor is not pumping properly, or the refrigerant is low. or blocked.
Apr 26, 2014 | LG Bottom Freezer Refrigerator w/ Swing...
Food in the fridge part was freezing and the compressor seems to be always running. Did some google searching and found several articles about how to test the Thermistor, which seems to be a potential...
If it runs all the time with no cooling, your compressor may be insufficient or faulty. However, first check that there is no loss of charge on the refrigerant. This is the less expensive of the two problems to fix. If you find that the refrigerator runs continuously and is TOO cool, you either have a defective temperature control or this control needs adjusting. There may also be an instance where the unit runs excessively but the freezer and refrigerator are still not cold enough. This could mean issues with the evaporator fan, the defrost timer, or simply the sealing of the unit or could be compressor failure or a dirty or defective condenser.
Do you have any ice buildup in the freezer at all? Is the food in the freezer staying frozen?
Sep 29, 2011 | LG LRTN22320 Top Freezer Refrigerator
Kenmore elite bottom freezer 3 yrs old. buzzes, clicks and hums, stops and resumes the noise, runs through that cycle 2-3 times each time it comes on. It works well, but seems to be keeping things colder...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 01, 2011 | Kenmore Refrigerators
Freezer runs frequently, we don't open it very often but it seems to run more often then needed. Should I change the settings on the timer? How?
No timer...it goes on and off on a t-stat...if it is running alot it is not cooling properly...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Sep 18, 2010 | True 19 cu. ft. / 538 liter Commercial...
Our GE side by side model GSS25SGRE is leaking water toward the front of the unit. We have pulled it out to see if it was condensation and that is not the problem. At times there is a lot of water that...
okay, my name is marclavoris, what happens is your refrigerator goes into defrost, the heaters comes on and melts the freon off the coils, the water goes down in the drain, which you will see on the freezer side at the very bottom of freezer, you may need to take off inside back panel to access the hole. it is clogged up with alot of debri, so when it is backed up, it overflows under your bottom tray, it then goes into defrost again and it pushes water on your floor. To solve problem, clear the drain in the freezer
Sep 12, 2009 | Refrigerators
Whirlpool Fridge makes a loud dripping sound all the time G56SHE
Erin,
The water you hear sounds like it's coming from the automatic defroster in the freezer compartment. It runs down a drain tube into the pan you describe under the fridge. The pan is heated and evaporates the water.
Just some possible explanations if you are hearing "lots" of water"
* You may be in a warmer, more humid climate
* The temperature and humidity in your dwelling is elevated
* The door gasket on the freezer may be leaking
* The freezer is too full
* The freezer door is not closing properly
* The freezer door is being left open for extended periods
* There is a problem with the defrost cycle
If you are hearing water running all the time, check the ice maker water line and fill valve (if you have an ice maker) - there could be a leak or other malfunction.
Apr 15, 2009 | Whirlpool ED5VHGXM Side by Side...
Fan running, weak air, fridge not cold enough, freezer working fi
it sound that your fridge is cloged of ice if so defrost it by unpluging it for the day to defrost completlyb with freezer door open then replace defrost timer if to much ice is formed on coil air does not cuculate properly thanks from gille
Feb 15, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Unit runs a lot. Doesn't condense much water. Sometimes fan runs alone, sometimes compressor runs alone.
You may also want to check the coils and make sure they do not have dirt or dust on them. If they are clean you may have an issue with the refrigerant level which will cause the coils not to cool properly. For that you will want to contact LG. There could be an issue with the compressor also. LG backs alot of their models with a 5 year warranty. Contact them and let them know about your issue. Make sure you still have your reciept. Here is their contact number:
1 (800) 793-8896
Jun 27, 2008 | LG LD65EL Dehumidifier
LG LRFC22750 Bottom freezer french door refrigerator
6343ed3.jpg The problem is ice build up on the back wall. The noise you hear is the fan blades hitting the ice. On the back wall water gets trapped, it then builds up over time, and a big ball of ice forms and blocks the fan. Take off the back wall, defrost the build up and cut the insulation off as above. The water will no longer get trapped and the problem will not come back.
Sgt 48
Feb 13, 2008 | LG LRFD25850 French Door Refrigerator
Kenmore 13.7 Frost Free Freezer
You may want to check the compressor area of the unit.There may be something on the coil or fan blade.(Packing foam,paper, etc)
Dec 11, 2007 | Kenmore 13.7 cu. ft. / 388 liter Upright...
LG LRFD25850 French Door Refrigerator Logo
223 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
