Question about Gigabyte GA-7N400E-L Motherboard
Ga-7N400E powerup problem
When i turn on the computer it only goes on for about 2-3seconds (fans run on cpu case and power supplie fan turn on power light on front and then shuts off.
Cheked:
Psu ok
Procesor ok
Memory ok
bat the nForce2 MCP became wery hot.
  • Deak Imre Feb 28, 2008
    Cheked bat the same problem
    Chek , no change, maybi its shorted the MCP
  • 152 Answers
VRM Circuit problem found there
disconnect only core voltage connetor and power on motherboard
if motherboard on so confirm that your vrm circuit is sort
replace vrm circuit mosfet
Posted on Feb 25, 2008
  • Harshad Patel
    Harshad Patel Feb 28, 2008
    replace PSU {SMPS}
    if replace psu and not solve your problem so your mobo
    any bridge get down or short
The computer won't start up
does the computer put anything on the screen?
does the computer one beep after self test?
what kind of lights or no power at all
any errors. windows boot up problems
Jul 08, 2015 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Turns off
I assume you have a desktop computer. It is either the CPU is overheating or the 'Power Supply" is overheating/failing. Put your hand at the top back of your computer where the power supply is to feel if the fan is blowing air out the back. If there is no air coming out the back, then I think the fan has failed and the power supply overheats and fails. Repair or replace the fan before the power supply totally fails and has to be replaced.
Also check the fan and heat sink on the CPU. If they are loaded down with dust, the CPU is not getting cool enough, With power OFF, remove the fan and heat sink, clen them and put them back. That will do wonders to cool the CPU.
Jun 08, 2009 | Intel Pentium 4, 2.8 GHz (bx80546pg2800e)...
Motherboard will not start
It seems like there could be a short in the system. Check to make sure that the board is tight in the case, and that no foreign objects are causing the motherboard to short. If there is no obvious problem and the motherboard is new, I would return it as a defect.
May 12, 2009 | Gigabyte Computers & Internet
Gigabyte GA-7N400 Pro fan makes tick noise after shutdown
i have a tick sound everytime my computer is on use.
Dec 26, 2008 | Gigabyte GA-7N400 Pro Motherboard
GA-7VRX Motherboard won't boot
Hi sebaswis, am I correct that this Gigabyte GA-7VRX is a replacement MB? (I read your other posted questions). http://www.fixya.com/support/t1399506-computer_boot_when_power You mentioned you put your old system back together & it worked fine. If mother board is shorted to the system case you will see the CPU fan spin for a second. Most motherboards use a green led which represents there is stand-by power running to the board.(This is normal). I am unsure why your led is orange. (Its not mentioned in your manual & manual does not show the led?s location). Was the other GA-7VRX MB led always orange or was it also green? Suggest you disassemble the heat-sink from the CPU. You mentioned you installed a new XP 2500+ CPU. If a pin on the CPU was bent during installation of CPU into the socket or if no thermal grease was applied or too little to the top of CPU, either would give you: CPU fan spins for a second & nothing else seems to run. Look over the link provided below. It is a guide to how to install a motherboard. (You may not need this but Its worth going over all the steps). http://www.hardwaresecrets.com/article/145 As far as the power supply. If the MB's are the same (GA-7VRX) & the old system ran with 220W, the newer one should also function. Clarify these questions for me sebaswis. Mike
Dec 18, 2008 | Gigabyte GA-7VRX Motherboard
Ga-m61sme-s2l motherboard always shut down within 5mins
It sounds as if the motherboard is having a temperature safety shutdown. This occurs when the temperature of the CPU exceeds a certain limit.
First off: Please check your CPU fan, power supply fan, and graphics card fan(if you have a gfx card) that they are working. If not, I would highly recommend replacing the fans or at least cleaning them and attempting to get them started by rotating them manually.
Please enter your BIOS (See Here for instructions) and navigate to "PC Health Status" - check the entry for the CPU temperature. While in the BIOS there is little strain on the system, but if the temperature is above 40 degrees Celsius in this state it may be prudent to check the fan setting. Also, check if there is a CPU Fan fail warning/CPU warning temperature - on average the limit should not exceed 60-65 degrees Celsius, max. Set any Fan speed or mode settings to maximum if able.
Try again.
If problem persists, and you are sure the temperature is not too high and/or the CPU fan is working, it may be the power supply itself. It is possible for the power supply to shut itself off in extreme cases such as when a power supply's fan stops working, and the temperature of the power supply rises to an unsafe level. Sometimes the fan will work initially but quit after a certain time. The fan requires replacement if this is the case.
Let the computer sit for a while and check to make sure it is at or near room temperature. Attempt to restart the installation process. When the power is cut, feel where the power supply meets the case to check whether or not it is particularly hot.
Replacement of the power supply's fan should solve that problem. I recommend taking it to a repair shop.
If that is not the problem, a last resort is that the harddrive is overheating and causing a system crash. With the case open, start the computer (mindful to be careful and always touch a large metal object such as the computer case itself before getting your hands near any components to prevent static damage), and wait for it to crash. Place your hand gently on the harddrive. If it is very warm or hot to the touch, most likely the harddrive's actuator arm, circitry, or data plate is malfunctioning and the drive should either be taken to be repaired or replaced.
If none of the components in your computer are particularly hot, please come back with more information on your computer, such as the parts, what you are cd you are booting, any new hardware, etc.
Dec 16, 2008 | Intel Motherboard
Hp pavilion 513n power up problem
replace the cpu fan if its not spinning fast enough the computer will turn off so it doesent over heat and damage the cpu
Oct 27, 2008 | HP Pavilion 513n (P9850A#ABA) PC Desktop
Turn on computer fans run a second shut off i unplug cpu power supply then run
may be the connection to the smps is not right
or may be the fan blew out
Sep 06, 2008 | Gateway 310S (2900621) PC Desktop
Auto restart
It may be overheating or the power supply may be failing.
Jun 22, 2008 | Microsoft Windows XP Home Edition
Gigabyte GA-7N400E-L Motherboard Logo
267 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
